Question about Frigidaire Kitchen Ranges
Frigidaire range model lfef3011lbd burners work but oven control panel does light up
Burners work but oven control does not light up
  • Official Brand Answer
  • 2,267 Answers
Good Afternoon Terry Fletcher, thanks for your post!
Based off the information you have provided your Frigidaire range control panel will not light up. Sounds like a possible short within your control panel that is causing the lights to not function properly. I would recommend consulting with a professional technician for proper diagnosis and repair to be completed to avoid any unnecessary part purchases. I hope this information is helpful. -Matt
Posted on Nov 21, 2014
SOURCE: Inglis electric freestanding range model #IRE3230- Oven no longer working
If the oven and the electric panel no longer work, this is an electronic problem. The burners and the oven light will not be effected, nor will the fuses. The electronics card will need to be replaced by an appliance technician.
Posted on Nov 25, 2008
jyackle5
  • 8197 Answers
SOURCE: kenmore range control panel not working
sounds like the control board blew on you replace it.
Posted on Dec 16, 2008
SOURCE: Frigidaire Range control panel DEAD
We tested the EOC and it will indeed need a replacement. Also, just a couple weeks prior we ran the "clean" mode on the oven as did another poster who experienced the "pop" and loss of the control board/oven function, but still had stove top function.
Posted on Dec 17, 2008
TheMobilian
  • 8220 Answers
SOURCE: Frigidaire FGF316WGSF GAS range oven won't work.
check this out
Posted on Mar 22, 2010
SOURCE: Frigidaire ES400 range - oven will not opperate, range will
Me too. Oven was on, big "pop" and breaker went. After re-setting the breaker (and setting the clock on the range), the stove top works fine, and the controller for the oven seems fine, just that neither the top or bottm elements will heat up in the oven. 240 V is getting to the control module, but it is not sending out any juice to the oven elements.
Any fixes out there?
Posted on Feb 04, 2011
Why won't the oven or the burners heat up on our brand new model CFEF3018LB range
Thank you for your inquiry, friend!
It could be a possible issue with the control panel or burner switches within the Frigidaire range. I would recommend performing a reset on your appliance which you can do by flipping the household circuit breaker off for ten minutes. It could also be an issue with your range not receiving sufficient power. You may want to seek assistance from a professional for proper repairs. -Matt
Oct 16, 2014 | Frigidaire Kitchen Ranges
No gas going to the burner in the oven of a frigidaire professional
What is the complete model number of your unit?
Dec 21, 2012 | Kitchen Ranges
WHERE IS MY PILOT ON MY FRIGIDAIRE FGF368GM
Hello, There is no pilot..It uses ignitors to light. number 19 in this picture is the oven ignitor http://lookup.bellparts.com/diagramenlarge/frigidaire/47877/00000358
If when you turn on the oven it doesnt glow bright orange chances are it failed and needs to be replaced. The top is electronic ignition. If this helps please rate me..Thanks
Jun 08, 2011 | Frigidaire FGF368GM Kitchen Range
My Frigidaire Oven display panel won't come on all of a sudden. Burners and oven light work. It could be from a surge in electricity. How do I 1) check fuses or breaker? Where are these located? How could...
If the burners and oven light are working, then you have power coming in. It's most likely a defective EOC. If you haven't tried turning off the circuit breaker for 5-10 mins to reset any glitch associated with a surge or spike, do so. If this doesn't reset the control, the EOC will need to be replaced.
Jan 05, 2018 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire electric stove, burners work oven does not. No clock
one of the stoves does not work. What could be the problem and how to fix it?
Thanks
Jan 06, 2010 | Frigidaire FEF336BC Electric Kitchen Range
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Dec 16, 2008 | Frigidaire FEF366EC 30" Freestanding...
Frigidaire self cleaning oven MODEL PLCF398DCC
you should be able to simply hold down the contro lock button for 3-5 secs, and it shoudl unlock for you
Nov 02, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven not working but burners are...
replace the glowbar just because it glowes doesnt mean its good the one you want to replace is the bottom one take the racks out and remove the bottom panel there are two screws remove the then under that will be a flame spreader remove that under that will be the burner bar and ignighter
May 22, 2008 | Frigidaire TGF317 Gas Kitchen Range
Kitchen Ranges Logo
116 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
