Question about Samsung Cell Phones
Thank you so much for the help. I already knew that I could contact Samsung , that is how I ended up on your web site!!!!!
I never registered with myhealthyvet and yet it says I have an account. It says my user registration info is already being used and won't let me. My identity has been stolen by who and why? I would li
Instead of talking to fixya, who can do nothing to help you, you should be talking to myhealthyvet. You may have registered and forgotten (I've done that) or more likely, someone that has your same name has registered. Stop and think about it.. Identity theft to get on a pet site? not likely.
If, on the other hand, you are talking about the U.S. veterans health site: https://www.myhealth.va.gov/mhv-portal-web/anonymous.portal?_nfpb=true&_nfto=false&_pageLabel=mhvHome
then, perhaps you should be concerned. Contact information is here:
https://www.myhealth.va.gov/mhv-portal-web/anonymous.portal?_nfpb=true&_nfto=false&_pageLabel=contactMHVHome
May 25, 2014 | Computers & Internet
Error 502 - Bad Request when i connect to smart bro internet
Fixing 502 errors - general
This problem is due to poor IP communication between back-end computers, possibly including the Web server at the site you are trying to visit. Before analysing this problem, you should clear your browser cache completely.
If you are surfing the Web and see this problem for all Web sites you try to visit, then either 1) your ISP has a major equipment failure/overload or 2) there is something wrong with your internal Internet connection e.g. your firewall is not functioning correctly. In the first case, only your ISP can help you. In the second case, you need to fix whatever it is that is preventing you reaching the Internet.
If you get this problem for only some of the Web sites you try to visit then it is likely to be a problem at those sites i.e. one of their pieces of equipment is failing/overloaded. Contact the people at those sites.
Apr 18, 2013 | Samsung N150 Plus 101inch netbook
Hi The cable that connects the Mount to the hand held control of my telescope is too short. Do you get an extension and where can I buy it
You can probably make one if you knew the "pin" connections- contact Bushnell for help at this web site:
http://www.opticsplanet.net/bushnell-warranty.html
Oct 15, 2010 | Bushnell NorthStar 78-8846 (675 x 114mm)...
User guide for samsung s630 camera, as card locked keeps appearing
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
You can download a manual from the manufacturer's web site at
http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=US&CttFileID=1882879&CDCttType=UM&ModelType=N&ModelName=SAMSUNG S630&VPath=UM/200803/20080324103057703_English.pdf
Sep 12, 2010 | Cameras
My samsung s5230 tocco lite is asking me for a phone lock. i do not knw it. please help unblock it as i can not get into my phne
Hi , There are a lot of updates out there that will lock your phone .
This web site will give you the code
and help you unlock your Samsung phone .
Just click on your model or network,
Then you will be free to use any sims card from any network .
( or use the sims card that you already have )
I have used this web site many times for my friends .
Fast and Easy . 100% money back guarantee.
http://www.mobileunlocked.com/?affid=435
Oct 25, 2009 | Samsung SGH-S5230 Cell Phone
Time Lapse Recorder TLR-1281
Hi, Lucky for you there are only 1 set of audio in/out and video in/out so this is not difficult. If you want to hook to a monitor or tv use a standard set of RCA audio cables one connector on each end is white the other is red. The video output is a BNC male connector which you can easily adapt to an F connector which is the standard coaxial input you find on any tv or monitor. You can find this adapter to fit directly onto the BNC connectors and then use any standard tv cable. The same with the video in. The adapter is BNC female on one end to male F on the other end. You need 2. If you need any more help please ask but this should Fixya!
Mar 16, 2009 | Lorex SG-7964 VHS VCR
Can't connect to the web site to register my samsung camcorder to extend warranty
Thank you for replying quickly. I did solve my problem by contacting Samsung direct.
Again, Thanks!
Dec 02, 2008 | Cameras
ASH-0906ERX
The samsung web site does list this unit but has no related documents for it. The best thing I can find is the "contact us" page. On that page select the Air conditioner link under "home appliances" heading. Hopefully they can send you whatever you need. Good Luck!
Jul 02, 2008 | Samsung Heating & Cooling
Batteries
Suggest this a camera fault- return to seller or contact the Samsung web site Tech support Team
Jun 25, 2007 | Samsung Digimax S700 Digital Camera
Cell Phones Logo
54 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
