Question about AT&T Unite 4G LTE Mobile Hotspot
I have uniteand it has not reset from the previous billing cycle. How do I get it to reset?
I removed the battery for about ten minutes.
I WOULD LAKE TO KNOW WHAT ECM B ON A 2001 BLAZER
  • Electronic Control Module
  • Here's how to reset the ECM after you've replaced the fuse.
  • 1 Remove the nut from the negative battery cable using a socket set or wrench. Slide the cable off of the battery and set it aside.
  • 2 Turn the headlight switch to the "On" position to drain the ECM of any remaining power. Wait at least 10 minutes, then turn it back to the "Off" position.
  • 3 Replace the negative battery cable by reversing the previous steps. Tighten the nut until it feels secure, paying attention not to overtighten it. The ECM has now been reset
  • I'm not sure what the question was, but I hope this helps you some. Good luck ,
    Bill
    Jan 11, 2015 | 2001 Chevrolet Blazer
    How can I reset service engine light on 2000 buick lesabre ltd
    Disconnect the battery! Ten seconds doesn't work, ten minutes doesn't work, two hours doesn't work, leaving it disconnected over night worked.
    Apr 02, 2012 | Cars & Trucks
    How do i reset check engine light
    Take the negative side of the battery off for ten mins , that should work good luck
    Mar 26, 2011 | 1999 Lexus ES 300
    Gas cap indicator light stuck on; gas cap is on-checked it ten times. 2007 Nitro, about 40,000 miles
    There are a number of things that the computer system will reset automaticly, but, it usually requires 2 drive cycles.
    A drive cycle includes, accelerating, highway speed, local speed, stopping. If you have already done that, you may try to reset by removing the ground cable, ( black wire ), from the battery for a minute or so.
    I hope this helps you.
    Feb 16, 2011 | 2007 Dodge Nitro R/T New Cars
    Replaced ignition lock cylinder and new key has no chip so it will turn over but now wont start. what to do?
    CHARGE BATTERY / TURN KEY TO RUN POSITION FOR TEN MINUTES
    SECURITY LIGHT SHOULD GO OUT / TURN KEY OFF FOR 3-5 SECONDS
    TURN BACK TO RUN FOR TEN MINUTES / REPETE / USALLY TAKES
    3 TEN MINUTE CYCLES / THAN TURN OFF / TURN ON SECURITY LIGHT
    SHOULD GO OUT AND ENGINE START AND RUN
    Dec 08, 2010 | 1996 Oldsmobile Cutlass Supreme Coupe
    My problem is I can not phone out with my phone which is a Uniden DSS3455 it seems as if it is locked. I was changing the ringing tone when it happened I must of pressed the wrong code.
    try a simple reset first. just drop the charger into the base and watch the charger light. when it flickers that has reset it. if that does not work try resetting the handset by removing the battery for about ten minutes. remember to drop it into the base after you have put the battery back in to sync it with the base. if neither of those methods work which they should... unplug the base for about ten minutes.... make sure you also unplug the phone line as well. after it has reset plug it all back in and place the handset into the base again for a few seconds
    Jan 14, 2010 | Uniden Lands Phones
    2005 e machine laptop m622uk8x wont turn on after removing battery and reinserting it and now all the lights are on and it wont turn on
    hold the power switch down for ten seconds then remove the battery hold power switch down for 30 seconds replace the battery hook up the charger to run on external power let charge for five minutes then restart if this dont work have to reset the bios by removing the motherboard battery for 2 minutes then startt
    Nov 04, 2009 | E-Machines M2105 Notebook
    2002 Monte Carlo Security system has shut car down completely unable to start car
    the process takes about thirty minutes. in three ten minute key cycles. here is how you do it . make sure that the battery is fully charged. step on parking brake pedal and leave it down this will keep the head lights off. turn the key and try to start it then leave it in the on position. you have to leave the key in the on position for ten minutes. you will see the security light on. after the ten minutes the light will go off then turn the key to the start position. turn the key all the way back to the off position and count to three. then try to start it and leave the key in the on position for another ten minutes till the security light goes out. you have to do this same process three times to reset the security system. sometimes you get lucky and it will start after the first ten minute cycle.
    Oct 31, 2009 | 2002 Chevrolet Monte Carlo
    Mitsubishi Pinin 1800 GDI Automatic Year 2000 Had to remove battery for recharging. We now have problem with intermittent low revs on tick-over and stalling. Please advise.
    try resetting the base idle,disconnect the battery,leave for ten minutes,reconnect the battery,start the car and do not rev the engine for ten minutes.hope this helps
    Sep 13, 2008 | Mitsubishi Montero Cars & Trucks
    AT&T Unite 4G LTE Mobile Hotspot Logo
    275 people viewed this question
    Top AT&T Computers & Internet Experts
    Computer Repairing
    Computer Repairing
    Prashant M
    Prashant M
    Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
