Question about LG OPTIMUS G E975 32GB BLACK ANDROID FACTORY UNLOCKED LTE 4G 3G 2G 2G & 3G HSDPA 900/2100 & 4G LTE 800/900/1800/2100/2600
My lg e975 does not read any sim card.how can i solve this problem?
There is no network and the camera says cannot connect to camera when launched.If I upgrade it to 4.4.2 kitkat will it solve the problem?
Bajanguru
  • 7752 Answers
SOURCE: lg kg800 will not connect to ATT
you first need to know the network coming with the first before buying it...and what network AT&T works on.
for example
LG KG800 works on these networks
850/1800/1900 or 900/1800/1900...you need to look at the box to see which network your phone comes with.
Posted on Dec 23, 2007
SOURCE: my LG VU is not reading my sim card
The sim card goes in the other way. The cut should be on the bottom left facing up. Try it and see if it works.
Posted on Mar 18, 2009
  • 24 Answers
SOURCE: LG KS 360 Unlocking
search google or another search engine for a website where you can get the unlock code for the phone. it's usually 20 bucks...but some carriers give you the unlock code for free if you email them depending on if you're a customer or not
Posted on Apr 25, 2009
SOURCE: My LG Vu does not read my sim card
I had the same problem with mine. I took it to an at&t store and they put a new sim card in it and it still didnt work. I ended up having to get a new phone sense for some reason at&t said they didnt know what was wrong with it.
Posted on Jul 13, 2009
cubataman
  • 178 Answers
SOURCE: No signal when I insert my fido sim card to my lg tg800
Fido, although owned by Rogers, doesn't have quite the coverage or signal strength as it's owner. You are probably in an area where Fido's signal is a little weak. If it does get better when you are in a different location or area, then its a problem that you really can't do much about.
Posted on Jul 26, 2009
Where the sim card insert in lg lu6800
The LG Optimus Big LG-LU6800 is a CDMA (Code Division Multiple Access) unit. A network (usually a Korean network) connects directly to the unit using its unique code. It doesn`t have a sim card slot. If you want to use it, you need to contact a network provider and register your LG LU6800 for it to get signals in your area, either by prepaid or postpaid service. The device can still be used but without the network call and messaging feature since you will not be getting signals from a network unless you register it. There is a rumorred Mini-sim card slot on a model of the unit. Users use a micro-sim card instead for those unit since there is an issue fitter the prior sim card size. If you are unable to find the sim card slot (visible when you remove the battery) then you most probably have the CDMA version.
Apr 09, 2014 | LG LU6800 Optimus Big
My lg phone has a network service problem my sim card does not read pls help me
Hi, maybe there's a problem with the SIM card or the SIM card is not compatible. Also, your phone might be network locked. You may check that in the following guide for LG phones: http://www.fastgsm.com/en/page/how-to-unlock-lg-gt540-optimus-gs290-kp500-cookie-gd510-pop-ks360
Jan 15, 2014 | LG CU500 Cellular Phone
How to unlock the lg xemon (instructions)?
You can Unlock the LG XENON GR500 model Phone using the Unlock code,You can get the Unlock code and instructions from here
Classicunlocking.com and Unlock it from Network Lock....
LG GR500 Xenon Unlocking Instructions
Warning : Do not enter any wrong unlock codes on your LG GR500 Xenon mobile phones. If you enter over a certain amount of wrong unlock codes on your LG GR500 Xenon mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your LG GR500 Xenon with a NOT ACCEPTED* SIM Card.
2 - LG GR500 Xenon will display "phone restricted" Select "Cancel".
3 - LG GR500 Xenon will display "phone restriction code" Enter the Unlock code. Select "OK".
4 - The handset is now successfully unlocked.
*NOT ACCEPTED : We mean, to use a sim card from a network other than the network your LG GR500 Xenon is locked to.
(OR)
1 - Switch ON your LG GR500 Xenon with its ORIGINAL SIM Card.
2 - Enter2945#*9701#.
3 - A menu will pop up, Select Sim Unlock.
4 - Enter your Unlock Code and press OK.
5 - The LG GR500 Xenon will then reboot and the unlock is complete.
ORIGINAL: We mean, to use the sim card that was originally given to you by your network/service provider along with the LG GR500 Xenon.
(OR)
2 - Type *#865625#.
3 - Enter the unlock code twice.
4 - LG GR500 Xenon should say: Network Lock Deactivated.
5 - LG GR500 Xenon may automatically reboot and is now unlocked!
Aug 03, 2011 | LG Xenon GR500 Cell Phone
I cannot put a starhub sim card phone in a LG phone
you can check it with other sim card ,if it remains the same problem ,it may be locked to particular network wont accept any sim card other than the particular network ,you can unlock it and used to other network,try here
Jan 17, 2011 | LG BL40 Chocolate Black Label Series...
Got phone inserted sim card but phone not reading sim pgone is lg gr500 blue
you can check it with other sim card ,if it remains the same problem ,it may be locked to particular network wont accept any sim card other than the particular network ,you can unlock it and used to other network,try here http://www.mobile-unlocker.com/lg-gr500-xenon/rs2wp9/
Jan 10, 2011 | Cell Phones
Is not accept airtel network LG ce168 cell phone on no. 8109211149
Jan 05, 2011 | LG GD510 Cell Phone
Why does it show insert sim card if its already insterted?
becauyse it doesnt recognize it... clean the contacts on the sim card, and the phone, if theyre worn.. you could need a new sim card, also simcards can **** out after a couple years... mmine only took 5, might need to order a new one..
Jan 09, 2010 | LG Xenon GR500 Cell Phone
LG KS200- My internet wont connect
plse reive gprs setting plse call your sim card customber care
Jul 10, 2009 | LG KS20 Smartphone
Lg kg800 will not connect to ATT
for example
Dec 13, 2007 | LG KG800 Cellular Phone
My Motorola ROKR E6 fell in sewage water
If i am not wrong E6 of Motorola was launched recently , U will need to approach Service Center . As no one Online will be able to solve u r problem. The problem is between u r sim reader & Main Circuit , so it is better to approach Service Center
Aug 15, 2007 | LG Shine KE970 Cellular Phone
LG OPTIMUS G E975 32GB BLACK ANDROID FACTORY UNLOCKED LTE 4G 3G 2G 2G & 3G HSDPA 900/2100 & 4G LTE 800/900/1800/2100/2600 Logo
35 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
