Question about Exercise & Fitness
I can't get the timer to start.The batteries are new and it displays but can't start
The other ( dist,etc.) won't start either
    Top Expert:
  • 34,089 Answers
The problem could be button failure or failure of internal connections to the timer mechanism.
Posted on Nov 20, 2014
We just put a brand new battery and terminals still won't start. What could be the problem with my 1991 ford tempo
Have your alternator tested. Check spark plugs and distributor/dist. Cap. Also if you post your problem under car and truck problems people would be able to see it. Right now it is posted under SLR cameras
Apr 02, 2013 | Photography
The timer won't turn lights on either with program timer or by using on/off buttons
1) Timer is not fully identified.
Copy following link for replacing CR2 battery in the Intermatic ST01c
http://waterheatertimer.org/ST01C-program.html#battery
2) If this is not your timer, then add comment and describe timer in detail, and/or include model number and attach photo
Dec 20, 2012 | Intermatic Inc. ST01C Digital In-Wall...
Westek TE06WHB Timer has been plugged in to charge for over 5 hours now and still now LCD display. It won't let me set the clock or program
Some of these timers use actual battery instead of rechargeable battery. Check back of timer for a battery door.
Press the reset button and see if this resolves the issue.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
Check outlet polarity using circuit analyzer.
Plug timer into another outlet.
Turn on light switch controlling outlet.
See if a light works on same outlet.
Check circuit breaker.
This timer has 1 year warranty against defects in workmanship.
I suggest always buying timers at local store for ease of possible return.
Lowes and Target sell same/similar timer under different brand name. Buy new timer and return defect in new package.
Sep 05, 2012 | RTO Westek Weekly Digital Timer, White
New plugs,new dist cap,new coil new ign. control module new fuel filter ,wont start
Fuel system checked? If OK, did you "reset" the ECC also called the ECM or PCM which is the computer of the vehicle? Do it by unhooking "both" battery cables, waiting 15 minutes, rehook then try to start and see if this helps. If not you may have to start on the ground floor by checking all fuses, crank and cam sensors, ICM, etc.
Sep 01, 2012 | Volvo 240 Cars & Trucks
I have a 1984 chevy truck 350. new battery, Forget start! It won't turn on ! I have power to dist. new ignition mod. and power to the steering col.
forget start it won`t turn on but you have power to distributor i don`t under stand what you have yet the engine won`t crank over?? or it cranks but no start let me know thank you
Sep 16, 2011 | 2004 Pontiac Grand Am
I have a timer that won't hold the program time set schedule? I have paid an electrician to come out and check to make sure i don't have any shorted out wires?? Electrician didn't find any...
Question posted under 120volt Intermatic Eh10 timer.
I do not have repairs for defective timer.
EH10 has 1 year limited warranty.
Located just below the digital display is compartment for AA battery.
Display is controlled by battery.
Replace battery, press and hold reset button for several seconds to reset timer, and try to program again.
http://waterheatertimer.org/How-to-wire-EH40-hot-water-heater-timer.html#EH10
http://waterheatertimer.org/pdf/eh10-manual.pdf
EH10 and EH40 timers are susceptible to line noise.
If timer is connected to water heater, there is no line noise. And electrician tested for shorting wires.
But when timer is connected to fan, pump, or other type of load, then interference can be a problem.
Intermatic can provide a filter.
http://www.intermatic.com/customer%20service.aspx
Digital timers, digital water heaters, digital washer and dryer, digital water softener, digital treadmill, etc are increasingly common, yet are not protected from surge.
People protect computers and TVs, but forget other costly items.
EH10 can be affected by surge.
Install whole house surge protection:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#surge
Aug 17, 2011 | Intermatic 7 Day Electronic Timer Eh10...
WOODS 59018 TIMER WIREING CORRECT INSTALLED WITH POWER OFF NETURAL GROUND UP TO CODE LOAD /LINE PROPER.NEW OUT OF BOX WON'T RESET. STEP 1 LAMPS LOAD SIDE GOOD. RETIRED CONSTRUCTION ELECTRICIAN
I don't have answer for defective timer. Buy another timer if everything below checks out:
59018 7-day timer has limited 1 year warranty, and appears to be made by Tork
Timer is for 120Volt single-pole only.
Rated for 1000 watt tungsten, 8A ballast, 1/4 HP
Push reset button with toothpick > not necessary to press-and-hold other button to accomplish reset.
After reset, 12:00 am Monday should display.
Programs are deleted. Reprogram timer.
To check, change and delete specific programming, press PROG key until selected program displays, and then set new programming >>> or press-and-hold MODE button and press PROG button again to delete selected program.
Timer has non-replaceable 30-day carryover battery and does not lose programming after power outage, and will retain programs until battery is depleted.
Review wiring:
Hot to timer black.
Neutral to timer white.
Load to timer red.
Ground to timer green.
Lights will blink if timer red and timer white are connected to load together.
Timer will not function if timer black and red wires are reversed. Display will not show.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
Aug 07, 2011 | Woods InWall 7 Day Digital Programmable...
I can not get my raindrip R673CT to program in the days I want it to go off. Lost my instructions. It puts in what days it wants and won't let me change them. Even removed the battery and let it sit...
Call raindrip 888-825-4716
I can post manual R673CT timer.
http://waterheatertimer.org/pdf/Raindrip-R673CT.pdf
Manual does not have troubleshoot steps
Try 2 new AAA batteries, and clean battery terminals.
The fact that you get display suggests that batteries are not the problem.
Manual says timer will no longer turn on with low battery, so timer is reset by removing battery.
Generally it is bad news when basic timer will not function after reset.
Aug 06, 2011 | Raindrip R673CT Digital Water Timer
Truck wont crank. we have put new distributor cap, rotor button, coil pack, plugs, wires, and fuel pump. we also checked our firing order.
you said you repl dist cap that means you don't have a crank sensor you have electronic ing module. remove your elec ing module have it tested most auto parts stores could test your module, or check your coil at the neg terminal. should have power. if not you lost your primary volt from your batt.your secondary power is coming from your electronic ing module from the module to the pos terminal on the coil, when the eng cranks,from the coil to the dist cap , from the dist cap center to the rotor then out to the plugs,this all happen pervided the timing belt or timing chain is ok. the cumbustion chainber needs 3 things , thats fuel, air, and spark.
Apr 17, 2011 | 1996 Chevrolet K1500
Require the internal battery what type is it?
Many of these timers have a built-in backup battery that is not replaceable.
If the battery goes out, then the display doesn't light up and you can't work timer.
The Woods replacement for 49112, TD 1000 etc is the Woods 59377
They sell the new Woods 59377 rascal on the internet for $15-23
Lowes sells similar timer made by Utilitec >>> I bought that one, and it doesn't have any instructions included, so I took it back
Oct 16, 2010 | Woods INDUSTRIES 59112 INDOOR DIGITAL...
Exercise & Fitness Logo
149 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
