Question about Ovens
I have a 720GRa rotostar gas double oven and grill this morning the knob to turn the top oven/grill has stopped working. It let's you turn it but nothing happens it feels loose to turn and no fan, ignition or light on the front to say it is on comes on. The bottom oven works fine
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    barkencoa
    • 3463 Answers
    SOURCE: just brought a bosch oven and there no life in the bottom oven
    If it has a timer, then make sure it is set manual and not auto, or the oven will not work.
    Try pressing 2 buttons at the left of timer and one button on right of timer to set it to manual, if it does not work this way, then try another combination of buttons.
    Hope this helps.
    Plz rate my solution.
    Thanks.
    Posted on Jan 03, 2009
    • 1214 Answers
    SOURCE: bottom oven not working
    A tripped breaker or blown fuse on an electric oven or cook-top, combined with an element that has stopped working, is usually a sign of a shorted, then blown (if the fuse or breaker no longer fail) element.
    If you know how to use an ohmeter, you can pull the element, disconnect the wires from each end, then measure the resistance between each end of the element, and each element to the outer sheath.
    A good element has just a few ohms of resistance between the wire connection points, and infinite resistance from the wire connection points to the outer sheath. Any readings other than that means the element is bad and need's to be replaced.
    Posted on Jan 14, 2009
    gasman44
    • 83 Answers
    SOURCE: My grill won't light
    Hi
    Forgive me for asking this, but you have read the instructions haven't you?
    If you have, and it's still not working, then the likelihood is that there is a fault, this could be one of the following:
    Faulty solenoid valve to grill (some grills had a safety button fitted to stop you from closing the door if the grill was being used)
    Blocked pipe inside unit
    Either way you need to get a qualified gas engineer to take a look at it, if it's under warrranty call the manufacturers first!
    I hope this helps
    Steve :)
    Posted on Jul 14, 2009
    ianem
    SOURCE: Top oven and grill of my Diplomat ADP4520 double
    there is a problem in the wire connection that can cause a short circuit.
    Posted on Nov 11, 2009
    Why does grill ignition click when bottom oven lit
    ignition probably serves both, if clicking when not lighting, fault or sticking button
    Jan 04, 2016 | Stoves Premier 720GRa Gas Double Oven
    Hi I have a 720GRa rotostar double oven and grill when I turn the top oven/grill knob it turns but nothing works eg lights on the front the fan or the ignition but the oven works fine it worked this...
    I suggest that if you have more than one knob of the same type, these knobs are usually removable by pulling straight out. Pull the knobs out and compare the inside. I would not be surprised if a metal insert is missing or the inside is stripped. Hope this suggestion is helpful.
    Nov 20, 2014 | Ovens
    My 900GRa Rotostar Gas Double Oven & Grill . When i switch on the Grill it continues to spark but the gas seems to cut off after few moments then the green light flashes on the turn on switch ? Please...
    I had a problem with my gas double oven not lighting some time back !
    The problem was solved when i took the oven out and cleaned out the Air Fan duct which was clogged up with fiber & Dust stopping the intake of Air !
    Dec 22, 2010 | Ovens
    I have had 3 engineers out to try and fix my stoves 720gra cooker and has changed all the printed circuit boards ,and all other parts but still the top oven and grill doesnt work and has now been classed...
    check the voltage on the spark generator,should be 240dc or 110 ac.
    or it could be the harness(wires fron spark generator to ignition) to check harness do a continuity test,an electricion will know,or get a electirc tester and do it with the instructions.
    Oct 01, 2009 | Stoves Premier 720GRa Gas Double Oven
    Hotpoint cooker, grill doesn't work but top oven does
    If the elements 'look' okay, they probably are. The 'infinite control switch' is probably the problem. With out the use of a meter, it's guess work. Unless you can see a connection problem.
    Sep 03, 2009 | Ovens
    I cant work out how to switcg my stoves newhomes gl706 grill oven on
    this product is made by encodex. No manual could be found online. Check if pilot light is on and you don't smell alot of gas. encodex is a sub company of GFK group. Here is there number, Tel. +49 911 395-0
    Dec 28, 2008 | Stoves Premier 720GRa Gas Double Oven
    Hi i cant seem to get my grill or oven on can any one help
    thanx for the site guys i got the no for the co and they going to get back to me thanks again
    Stove 720g Grill
    HI YOU MIGHT HAVE A SAFETY THERMOSTAT THAT COULD BE FAULTY.BEST YOU HAVE A TECH TO HAVE A LOOK AND REPAIR.
    GOOD LUCK.PLEASE RATE THE SERVICE.
    MOHAMED
    Sep 28, 2008 | Stoves Premier 720GRa Gas Double Oven
    Ovens Logo
    55 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
