Question about Ovens
Hi I have a 720GRa rotostar double oven and grill when I turn the top oven/grill knob it turns but nothing works eg lights on the front the fan or the ignition but the oven works fine it worked this morning could something of moved on the inside of the knob??
    Sergeant:
  • 330 Answers
I suggest that if you have more than one knob of the same type, these knobs are usually removable by pulling straight out. Pull the knobs out and compare the inside. I would not be surprised if a metal insert is missing or the inside is stripped. Hope this suggestion is helpful.
Posted on Nov 20, 2014
  • 1462 Answers
SOURCE: creda reflection double oven and grill
if fan inside oven starts but no heat, then the probability is that the element is open circuit and needs replacing
Posted on Jun 29, 2008
SOURCE: MAJIC CHEF DOUBLE OVEN NOT WORKING
I just had a model 976-4CX put in...I have no manual...I'm trying to find one. I thought I had a problem with the element, dial or thermostat. The bottom worked, but the top stopped working. There are 2 timers with dials next to the clock labeled Start and Stop, and Push for Manual. Come to find out my problem was solved by adjusting the Start and Stop dials and/or pushing in for manual!?!
If I had a manual I'd know how these timers worked.
Posted on Dec 18, 2008
  • 1214 Answers
SOURCE: bottom oven not working
A tripped breaker or blown fuse on an electric oven or cook-top, combined with an element that has stopped working, is usually a sign of a shorted, then blown (if the fuse or breaker no longer fail) element.
If you know how to use an ohmeter, you can pull the element, disconnect the wires from each end, then measure the resistance between each end of the element, and each element to the outer sheath.
A good element has just a few ohms of resistance between the wire connection points, and infinite resistance from the wire connection points to the outer sheath. Any readings other than that means the element is bad and need's to be replaced.
Posted on Jan 14, 2009
gasman44
  • 83 Answers
SOURCE: My grill won't light
Hi
Forgive me for asking this, but you have read the instructions haven't you?
If you have, and it's still not working, then the likelihood is that there is a fault, this could be one of the following:
Faulty solenoid valve to grill (some grills had a safety button fitted to stop you from closing the door if the grill was being used)
Blocked pipe inside unit
Either way you need to get a qualified gas engineer to take a look at it, if it's under warrranty call the manufacturers first!
I hope this helps
Steve :)
Posted on Jul 14, 2009
  • 12 Answers
SOURCE: indesit fde20 main oven wont heat up
sounds like the circular element at the back of oven has blown.
Posted on Oct 24, 2009
Why does grill ignition click when bottom oven lit
ignition probably serves both, if clicking when not lighting, fault or sticking button
Jan 04, 2016 | Stoves Premier 720GRa Gas Double Oven
Both lights on the top oven work when using it as an oven but when using it as a grill, they don't! There doesn't appear to be any other fault as the oven and grill still work fine. Any thoughts...
The unit is working as it should. The top oven lights will only come on when the top oven control knob is turned on. The grill control does NOT turn the lights on. If you want to see what you are grilling, then you should turn the top oven control on to its first position. This works even if the grill is operating.
May 10, 2011 | Stoves 720EF Electric Double Oven
Hi Guys I have a Stoves 720EF Double Oven and Grill. Whilst halfway through cooking some sausages on the grill this evening, the grill suddenly stopped working (plus the LED for the grill knob showing...
If the element and the indicator light both stopped working this suggests a problem with the power supply for the grill control. Either the grill control has no power going to it or it is faulty and requires replacement. If you are not sure what you are doing you'd better get a tech. to look at it, it can be fairly complicated for the untrained person.
Feb 24, 2011 | Stoves 720EF Electric Double Oven
My 900GRa Rotostar Gas Double Oven & Grill . When i switch on the Grill it continues to spark but the gas seems to cut off after few moments then the green light flashes on the turn on switch ? Please...
I had a problem with my gas double oven not lighting some time back !
The problem was solved when i took the oven out and cleaned out the Air Fan duct which was clogged up with fiber & Dust stopping the intake of Air !
Dec 22, 2010 | Ovens
Stoves 720 EF Electric Double Oven Model No 059040415 -when you turn the grill knob there is no light and it doesn't do anything at all - the grill is not working. However, the element must be working as...
First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set.
The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control).
To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
So if you have done all that and it still doesn't work, then the micro-switch could be faulty.
Best of luck
Nov 23, 2010 | Stoves 720EF Electric Double Oven
I have had 3 engineers out to try and fix my stoves 720gra cooker and has changed all the printed circuit boards ,and all other parts but still the top oven and grill doesnt work and has now been classed...
check the voltage on the spark generator,should be 240dc or 110 ac.
or it could be the harness(wires fron spark generator to ignition) to check harness do a continuity test,an electricion will know,or get a electirc tester and do it with the instructions.
Oct 01, 2009 | Stoves Premier 720GRa Gas Double Oven
Hi i cant seem to get my grill or oven on can any one help
thanx for the site guys i got the no for the co and they going to get back to me thanks again
Dec 28, 2008 | Stoves Premier 720GRa Gas Double Oven
Stove 720g Grill
HI YOU MIGHT HAVE A SAFETY THERMOSTAT THAT COULD BE FAULTY.BEST YOU HAVE A TECH TO HAVE A LOOK AND REPAIR.
GOOD LUCK.PLEASE RATE THE SERVICE.
MOHAMED
Sep 28, 2008 | Stoves Premier 720GRa Gas Double Oven
Stoves 720 / 900 GRa GR DO gas electric dual fuel oven
Our oven had the same fault.
It turns out that the air intake was blocked.
The air intake is at the front, just below the bottom oven door. Some liberal sucking with a hoover sorted the problem instantly.
Apr 06, 2008 | Stoves Premier 720GRa Gas Double Oven
Ovens Logo
89 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
