Question about Ovens
How do I replace a side oven lamp assembly?
I need to replace the side oven lamp. I have bought the correct part but can't work ou how to install it
    New Friend:
  • 44 Answers
Have you tried to unscrew the glass cover???
Posted on Nov 20, 2014
  • Mrs J Jones
    Mrs J Jones Nov 20, 2014
    It doesn't unscrew it just pulls off and I have replaced the bulb, with no result which is why I bought the spare part which now comes as sealed assembly, however I can't see how to unhook the old assembly unit from the wiring!
Replace light inside oven
Switch oven off and switch main oven switch on wall off if no wall switch, switch off at main switch board.
Open door and check glass cover if it screws off or has retaining screws. be careful as it could be hard to loosen, once loose unscrew lamp anticlockwise slowly as lamp my break off base if tight move side to side very little and unscrew. get replacement and replace opp to removal. Switch on main switch and test.
Oct 17, 2014 | Ovens
How to replace the thermostat on BP y-600
Turn off gas supply. Open panel on left side. Loosen the top and bottom unions. Remove thermostat capillary line from the oven. Now remove thermostat with 2 pipe wrenches. install new thermostat and attach assembly to the unions you loosened. Now insert the capillary line back into the oven.
Jul 27, 2014 | Bakers Pride Y-600 Gas Single Oven
My Kenmore Electric Range model 790.9661 seems to have a control board problem. Before replacing the $200 part, just wanted to make sure it was the problem. The clock works, but the oven temperature side...
From your description it sounds that the board is the problem. I found the control panel you need for a lot less than $200 though.
I found one online from a store that I have bought from many times. Part and shipping is about $153. They sell brand name stuff too and they have great service. I hope that this helped you.
Control Panel
Good Luck from a bored repair man!
Joey
http://www.pricedrightparts.com/products/Frigidaire-Control-Panel-316402715.html
Jun 11, 2011 | Kenmore Ovens
THE LIGHT HAS GONE WITHIN THE OVEN. HOW DO WE REPLACE?
WE MANAGED TO FIND THE CORRECT BULB & FITTING IN A LOCAL ELECTRICAL SHOP IN COLCHESTER. IT WAS £4.85 AND ALL WE DID WAS UNDO 6 SCREWS AND TAKE THE COMPLETE SURROUND OFF. IT TOOK MY HUSBAND ABOUT 10 MINUTES SO I WAS WELL CHUFFED!
Jan 15, 2010 | Ovens
Omega OF601XA Thermostat Light Not Working
if the oven is working ok , and cycles on and off when it reaches temp then it is just the lamp needing replacing or wiring has came lose
Dec 13, 2009 | Ovens
How do I remove the oven lamp assembly and replace
make sure you have voltage to your switch, it may be that you have a bad switch. If you have power to the switch make sure you have power to the light from the switch. If so its your socket. my light is in the back of the oven if yours is that way you'll have to pull the stove out and take the back off to get to the socket.
Aug 23, 2009 | Ovens
CAN BARLEY READ THE DISPLAY
You need to replace the display backlight lamp.
Enter model number here to find assembly diagrams and parts.
Contact the seller by phone if part is not listed on the website.
Jan 02, 2009 | Jenn-Air JJW8627C Expressions Collection...
Oven shut down
hi If the range or oven is receiving power but doesn't work, the unit may have its own fuse or circuit breaker assembly. This assembly is usually located under the cooktop of the range. In some units, lift the top of the range to gain access to the fuse assembly; or lift the elements, remove the drip pans, and look on the sides of the cabinets. Inside the oven, look to the back to spot the fuse assembly.
If the unit has this additional fuse or breaker system, components such as the oven light, the range heating elements, the timer, and a self-cleaning feature may be separately fused.
If these components or features fail to work, don't overlook the possibility that the fuses have blown. To replace a blown fuse, unscrew the old fuse and install a new one of the same type and electrical rating. If the unit has circuit breakers, push the breaker or reset button, which is usually located on the control panel.
thank u........
Sep 12, 2008 | Ovens
ECS130 - Possessed Oven
The fix is replacing the mebrane panel. Recent poster advised they where able to get Dacor to send a new panel and they would install (it's not difficult). I bought one online for around $175 and installed myself. Do a search for details.
May 23, 2007 | Dacor ECS130 Epicure Electric Single Oven
Ovens Logo
49 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
