Question about IBM Netvista Intel Pentium 4 2.4GHz / 512MB DDR / 40GB HDD / DVD-ROM / 10/100Mbps LAN / Windows XP P (RBP42400XPP) PC Desktop
A Netware error was detected. Please verify that you are properly logged in. See the network Installation guide for more information. It shows when open PM5
None
    Habit-Forming:
  • 50 Answers
If you are on a net ware network logon
If not you have the netware client installed by mistake remove it
Posted on Nov 25, 2014
How do I Fix Windows Update Error 0x800F081F?
.NET Framework 3.5 installation error: 0x800F0906, 0x800F081F, 0x800F0907 Error code 0x800F0906
Error code 0x800F081F
Error code 0x800F0907 Resolution for Windows 10 0" style="box-sizing: border-box; outline: none;"> Error code 0x800F0906, 0x800F081F, or 0x800F0907
Error code 0x800F0922 More Information 0" style="box-sizing: border-box; outline: none;"> These errors may occur when you use an installation wizard, the Deployment Image Servicing and Management (DISM) tool, or Windows PowerShell commands to enable the .NET Framework 3.5.
In Windows 10, Windows 8.1, Windows 8, Windows Server 2012 R2, and Windows Server 2012, the .Net Framework 3.5 is a Feature on Demand. The metadata for Features on Demand is included. However, the binaries and other files associated with the feature are not included. When you enable a feature, Windows tries to contact Windows Update to download the missing information to install the feature. The network configuration and how computers are configured to install updates in the environment can affect this process. Therefore, you may encounter errors when you first install these features.
Error messages that are associated with these error codes
Error code Error messages 0x800F0906 The source files could not be downloaded.
Use the "source" option to specify the location of the files that are required to restore the feature. For more information on specifying a source location, see http://go.microsoft.com/fwlink/?LinkId=243077.
The DISM log file can be found at C:\Windows\Logs\DISM\dism.log
Windows couldn't complete the requested changes.
Windows couldn't connect to the Internet to download necessary files. Make sure that you're connected to the Internet, and click "Retry" to try again.
Installation of one or more roles, role services, or features failed.
The source files could not be found. Try installing the roles, role services, or features again in a new Add Roles and Features Wizard session, and on the Confirmation page of the wizard, click "Specify an alternate source path" to specify a valid location of the source files that are required for the installation. The location must be accessible by the computer account of the destination server.
0x800F0906 - CBS_E_DOWNLOAD_FAILURE
Error code: 0x800F0906
Error: 0x800f0906 0x800F081F The source files could not be found.
Use the "Source" option to specify the location of the files that are required to restore the feature. For more information on specifying a source location, see http://go.microsoft.com/fwlink/?LinkId=243077.
0x800F081F - CBS_E_SOURCE_MISSING
Error code: 0x800F081F
Error: 0x800F081F 0x800F0907 DISM failed. No operation was performed.
For more information, review the log file.
Because of network policy settings, Windows couldn't connect to the Internet to download files that are required to complete the requested changes. Contact your network administrator for more information.
0x800F0907 - CBS_E_GROUPPOLICY_DISALLOWED
Error code: 0x800F0907
Error: 0x800F0907
How to download the .NET Framework 3.5 outside of the Windows Update requirement
The .NET Framework 3.5 is available for customers with Volume Licensing or MSDN Subscription, as Feature on Demand Media is available.
Error codes are not listed when you install .NET Framework 3.5
When you install .NET Framework 3.5, you may encounter other error codes that are not listed in this KB, for more information, go to the following articles:
Dec 27, 2017 | Computers & Internet
Pm5 is not opening, asking netware error pm5.exe
A Netware error was dected. Please verify that you are properly logged in. See the network Installation guide for more information
Apr 04, 2010 | HP Computers & Internet
E10 code on my kenmore front loading washer
This can mean 1 or 2 things
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
If there is no water in the unit:
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operation
OR it could mean
Motor Control Unit (MCU) Heat Sink Thermal Trip
If the thermal protector on the MCU heat sink gets too hot, it will open the thermal protector on the heat sink which will stop motor functions and an "E10" will be displayed
  • Check for Proper Installation, verify the unit is not located near a source of heat and has proper ventilation.
  • Check Wire Harness connectors to the MCU, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check Motor
Oct 30, 2009 | Kenmore 46462 Front Load Washer
MY WELCOME SCREEN HAD BEEN DISABLED!! HOW DO YOU ENABLE IT AGAIN?
YOU MUST UNINSTALL CLIENT SERVICES FOR NETWARE
Start->settings->control panel->network connections.
For each network connection listed:
Right click and select properties.
Highlight the Client for Netware entry
Click Uninstall.
Once complete, go into the User control panel applet and you should be able
to set the Welcome screen and fast user switch options.
May 30, 2009 | Acer Aspire T180-EA350M (AST180EA350M) PC...
THANK YOU LEECOM72!!!
To resolve the problem , you would have to unistall client for netware protocol.
1.Click start>Click on RUN> Type ncpa.cpl and click on ok
2. Network connections window would open
3. Right click on Local area connection
4. Left click properties
5. Uncheck the box next to Client of netware
6. Click ok and restart your computer
Then try to select the Use welcome screen
Thanks
proton
May 29, 2009 | Acer Aspire T180-EA350M (AST180EA350M) PC...
How do I find out if someone from outside my home is using my wireless network
You need to log on to your router/s and look at the log.
You should also change your security settings in your router/s so this won't happen again.
Good Luck!
Apr 22, 2009 | Computers & Internet
WATER WILL NOT RUN IN WASHER. ERROR CODE hf showing up
The following link explains the "FH" error what steps to take to diagnose and repair:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
There's a lot of information, here, so read through everything thoroughly. This is one of those tricky problems that may have several causes. I hope this helps you. If you require addtional assistance, please let me know.
Nov 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Install of IBM infoprint printer drivers
make sure you are logged on a the Administrator to the computer then try installing..
Dec 26, 2007 | Office Equipment & Supplies
Drivers for novell netware 4.1x
I am not sure if you will be able to install Novell Netware 4.11 on this platform. Howver, please see the following link for the BroadCom BCM5721 drivers.
http://www.broadcom.com/support/ethernet_nic/netxtreme_server.php
Download the  Netware  (ODI32) driver. This supports Netware 4, 5 and 6.
Good Luck!
Mike McWhinney
Oct 16, 2007 | Broadcom BCM5721 NetXtreme Ethernet...
Novell Netware Users Guide.
Netware is a very complicated operating system so the manual may not help if you don't have other Netware experience. Nevertheless, Network 4.1 documentation can be found at http://www.novell.com/documentation/nw4/docui/index.html
Sep 01, 2007 | Novell NetWare 5.0 for PC
IBM Netvista Intel Pentium 4 2.4GHz / 512MB DDR / 40GB HDD / DVD-ROM / 10/100Mbps LAN / Windows XP P (RBP42400XPP) PC Desktop Logo
397 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
