Question about Water Sport
What are the various technologies used for water and irrigation systems in dams and drainage systems?
5 Suggested Answers
SOURCE: Instructions for garden watering system Hardie Irrigation
WIRES CONNECTION
Posted on Mar 08, 2010
aquaman987
  • 927 Answers
SOURCE: Can you use a draper
Here's how to tell.
Connect a tee to the outlet of the pump.
Install a pressure gauge in the tee.
Install a valve after the gauge.
Open the valve and start the pump.
Once water flows, close the valve slowly until you get 50 psi on the gauge.
Have a 5 gallon bucket nearby and measure how long it takes to fill the bucket at 50 psi.
If it fills the bucket in 30 seconds, you can attach heads to the pump that combined consume 10 gallons per minute.
Let me know how you do.
Gary
Posted on May 29, 2011
hunter19_46m
  • 7482 Answers
SOURCE: Our auto irrigation system wouldn't turn off. We found the Davey XJ70 pressure pump was leaking so replaced the leaking pipe. Now the watering g system won't start. What do we do?
Hi Geralidine
Sounds like your pump is "air bound"...meaning that the impeller housing of the pump is full of air, and it cannot pump water.
Try bleeding the air out of the pump and put a positive pressure (garden hose pressure) and make sure that you shut the airbleed valve off after you start to pump.
Please take time to rate me
Bud
Posted on Mar 31, 2013
rahultiwa80238
  • 9 Answers
SOURCE: Is drip irrigation the best way of saving water in farming in India?
Advantages of Drip Irrigation:
1. Maximum use of available water.
2. No water being available to weeds.
3. Maximum crop yield.
4. High efficiency in the use of fertilizers.
5. Less weed growth and restricts population of potential hosts.
6. Low labour and relatively low operation cost.
7. No soil erosion.
8. Improved infiltration in soil of low intake.
9. Ready adjustment to sophisticated automatic control.
10. No runoff of fertilizers into ground water.
11. Less evaporation losses of water as compared to surface irrigation.
12. Improves seed germination.
13. Decreased to tillage operations.
Currently Chhattisgarh Agriculture Minister has launched micro irrigation scheme for farmers.
Posted on Mar 25, 2016
Tip
Drip it don't drop it
The popularity of Drip Irrigation Systems has been rising in the past years. It is true that this method of irrigation is usually a bit more expensive than sprinklers and isn't as resistant on the long run, but on the other hand the water saving and the system's efficiency definitely make it worth it. So why not giving it a try?
First of all, this system waters plants and flowers more slowly and the water goes straight to the roots, so no water goes to waste.
Moreover, it requires to be activated with less frequency than sprinklers.
In most countries it's one day of irrigation every week during the winter, two days during spring and fall and three during the summer.
Did you get one yet?
If you did here are two basic suggestions to start and keep up a satisfying drip irrigation system.
1. In order to figure out how long to leave it running, you can measure how much water your emitter produces and according to that and your plant's needs, set the system's timer.
So take a spoon and measure how many seconds the system takes to fill it up.
14 seconds = 1 gph (gallon per hour)
7 seconds = 2 gph
4 seconds = 4 gph
If your system is of the first kind, producing 1gph, usually you should leave it running for about 90 minutes, if it's the second (2gph) for about 60 minutes and if the third (4gph) for about 30 minutes.
(If your plants require a higher-flow emitter you can get one that produces up to 20 gph and leave it for about 12 minutes each watering.)
2. In order to keep your drip irrigation system in good shape check its line periodically for breaks, or its emitters for clogs.
Make sure that each emitter releases the right amount of water.
Also you should flush the drip irrigation lines and filters about twice each year. You can do this by uncapping the end cap on the drip line and letting water flush through the line.
on Sep 10, 2013 | Garden
What are different ways to increase water level in water well for irrigation?
Just pour more water in the well. You can do it by pouring more water into well.
Mar 25, 2016 | Computers & Internet
Do I place this at the faucet or after the pressure regulator on drip system?
Generally you put these timers at the hose bib (faucet). In my home, they'd be used for sprinklers or drip irrigation systems that have a limited controls on them. If I put them past the flow restrictor on the soaker hose, the unit would be on the ground and in the water.
I hope this helps.
May 10, 2014 | ACE Water Timer, Electronic - No. 7198476
What is a Drip Irrigation System?
According to Wikipedia "Drip irrigation, also known as trickle irrigation or micro irrigation or localized irrigation, is an irrigation method that saves water and fertilizer by allowing water to drip slowly to the roots of plants, either onto the soil surface or directly onto the root zone, through a network of valves, pipes, tubing, and emitters. It is done through narrow tubes that deliver water directly to the base of the plant."
Irrigation valve vibrates when opening.
Take apart and clean spring /diaphragm is sticking
Clean unt out
Feb 18, 2013 | Hunter Industries Hunter NODE-100 Single...
I have a 1/2 hp pump which I use to pump lake water to my irrigation system. The pump takes too long to turn on when the spicket is opened and sometimes too long to shut off when the water spicket is...
when using the spicket you use less flow than your irrigation system so a delay in the pump coming on is normal...otherwise if you are having the same problem when the irrigation is running..a pressure switch adjustment may be necessary...please follow the manufacturer instructions for your pressure switch.
Mar 31, 2009 | Flotec 1 - 1/2 Sprinkler Pump Composite...
Water Sport Logo
687 people viewed this question
Top Water Sport Experts
Bill Boyd
Tom Chichester
Are you a Water Sport Expert? Answer questions, earn points and help others
