Question about Panasonic Televison & Video
Have a pt-50lc14 panasonic and replaced the bulb wit a cheap one and it burned out in a week so I bought a good one and it wont turn on light just flashes green the turns to flashing red after a bit.
Have a pt-50lc14 panasonic and replaced the bulb wit a cheap one and it burned out in a week so I bought a good one and it wont turn on light just flashes green the turns to flashing red after a bit. I took the back off and I can see that the light is coming on for a few seconds then shuts off
    Top Expert:
  • Panasonic Master
  • 45,144 Answers
The "good" replacement could be defective.
Posted on Nov 20, 2014
5 Suggested Answers
SOURCE: PT-50LC14
Hey Beestergirl, I just had my tv fixed for 385.00
Posted on May 02, 2008
spqr163
  • 37 Answers
SOURCE: tv will not power up Panasonic PT-50LC14
ok guy's i have the same tv and simular problems, first check the lamp light located next to the sd disk input (on the front). if it's not blinking then 2 things 1) more than likely it's the lamp if you haven't replaced it by now your one of the lucky ones, you can find them online for around $100, in which i paid over $300 for two differnt bulbs. the warrent only covers 1 bulb. 2) this happens to me once in a while try unplugging it let it set for a minute or two, replug it back in and try it again. but it depends if the light shines yellow (orange) and blinks twice, then try it again. you kinda have it cycle through and that should work. if not then unplug the unit, then take off the front cover and use a philips screwdriver remover the bulb (located behind the cover in the front) then i highly recomend doing this on a weekend pull out the shop vac and **** out the dust inside the lamp housing, then take off the back housing along with the left side speaker and first clean it out with a rag, then go through it with the shop vac. basically if dust builds up the unit will trap the heat and that it's why it will overheat and shut down.
Posted on Mar 12, 2009
  • 597 Answers
SOURCE: PT-50LC14 shut off on it's own and will not turn
count # of flashes...call tech support
Posted on Jun 01, 2010
SD Tech
  • 14553 Answers
SOURCE: My panasonic pt-50lc14 turns off the power light flashes red and temperature light flashes.
Examine the lamp first and be aware the model 50lc13 and 50lc14 which are almost identical had all sorts of problems----the lc13 was part of a massive recall/exchange that cost Panasonic tens of millions of dollars.
could be lamp or even the ballast which was the real issue involved in the recall.
Posted on Aug 27, 2012
Does my panasonic hdtv 1080i pt-50LC14 have a lamp
Yes it does! Behind the front bezel under the screen. you can buy it here. http://projectorlamps.com/panasonic-dlp-tv-bulbs-pt-50lc14.html PT 50LC14 Panasonic Genuine High Quality Original Projector Lamps now...
Refer to the manual or the instructions that are shipped with the lamp.
Apr 25, 2015 | Panasonic Televison & Video
Should I replace my lamp for my Panasonic 1080i htd t.v. pt-50LC14
Replacing a lamp won't work. There is not even one lamp in your TV. I'm afraid the lightening has done more damage than can be repaired. Even when some tech manages to repair te error, the TV can have the next error in days or weeks.
Try reading something about ESD. Electro Static Discharge and what it does to electronics. Electrostatic discharge
I have a panasonic pt-50lc14-k and my light bulb burnt out ..im wondering where do i buy the bulb to replace it and how much will it be?
Mats Electronics has Lamps for $89.00 1-800-628-1118
Encompass Parts Distribution will list Parts /Prices visit their website 1-800-638-3328
Dec 30, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT50LC14 Power issue
We have a PT-50LC14. We replaced the lamp 6 months ago with a TY-LA1000 bulb we bought from a company online (not directly from Panasonic) and it worked for 6 months. Then the TV started turning off on it's own...sometimes it would not come back on for an hour or so. We called the lamp company and we luckily had 1 day left on our 6 month warranty!! They sent us a replacement bulb and the TV would never power on. It would try to power up, but the bulb would never ignite. The power light would flash and then the lamp light would flash every 5 seconds. I had a friend that has the same type of TV and she ordered her bulb directly from Panasonic. I borrowed her lamp and it powered right up. We then called the online company and they sent us yet another replacement bulb, and I tried it today and it works. It seems like these TVs are very particular about the type of bulb used. Next time, we will be ordering ours directly from Panasonic and just paying the extra $100. We have been without our big screen for 2 very long months! I had called a local tv repair shop, called Panasonic directly, and read through countless internet forums, and I thought we were going to have to replace the ballast or get a ballast repair kit and start messing with the circuit board.
May 22, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT-50LC14 has evenly spaced vertical blue lines aproximately 1 cm apart
it's not the light engine it'sd the bulb, replace that first, then clean it all out then go from there........
Nov 07, 2008 | Panasonic PT-50LC14 50" Rear Projection...
PT-50LC14
Apr 21, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Plastic housing
moz-screenshot-1.jpgTry this link and download the manual. See page 81.
http://www2.panasonic.com/consumer-electronics/support/Televisions/LCD-Projection-TVs/model.PT-50LC14
Nov 16, 2007 | Panasonic PT-50LC14 50" Rear Projection...
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
