Leaking from a burner - Heating & Cooling
  • 3,368 Answers
Get service help immediately that is dangerous.
Posted on Nov 27, 2014
New Maytag MGC7430 gas cooktop leaks gas when lit
First it could be leaking from the control knob when it is on . There could be a leak at the base off the burner letting out gas or on the burner line . You need to get back on to your installer or where you purchased the cook top . This basic gas fitting leak detection .
Jun 15, 2017 | Maytag Cooktops
Tubes blow flames out the front of burner
Burner out of postion , gas leak on control on off . or burner is blocked try cleaning burner some thing could be in the burner causing the gas tO light back , or you need new burner.
Mar 26, 2012 | Nexgrill 720-0234 (LP)
Hello My side burner is leaking gas. I can hear the gas flowing even thought the knob is in the off position. But it doesn't click like all the other burners. Eddie
If the gas you hear is coming from the burner, rather than the side burner gas supply hos, the control knob may be stuck in the "IN" position. Turn the gas tank OFF, before attempting any repairs and disconnect the hose from the tank.
Now that there is no pressure on the side burner control knob, try using it as you normally would. What you're looking for is full function of the knob. Push it it and turn it to the light position. Does the knob pop back out when you release it? If it does, that's a good sign. If memory service me correctly, the gas supply line to the side burner as a quick connect on the hose to connect it to the burner. if so, disconnect and reconnect it to the burner. Does the quick connect slide back into place and connect properly? If not, that is what's leaking. But, to make sure, there needs to be gas going to the grill. Reconnect the hose to the tank and open the tank valve VERY, VERY SLOWLY (Slow motion, slow). Once the valve is fully open, test the side burner hose connection and the hose (squirrels like to chew on the hose) by brushing on a soap & water solution to check for leaks. If you see bubbles that grow in size, that's a leak. Turn the gas tank back OFF. The side burner hose will need to be replaced.
If there were no leaks on the connection, check the burner knob for operation. Does it operate like it should with no smell of leaking gas? If not, the control knob valve will need to be replaced.
The parts you may need can be purchased from Ducane Customer Service 1-800-382-2637.
I hope this helps you to troubleshoot and solve the problem. Thanks for choosing FixYa.
Aug 03, 2011 | Ducane 30400040 Stainless Steel Grill
Pilot light goes out when burner kicks off
Sounds like the pilot is dirty....when dirty it gets smaller and lazy...tends to go out easy...try gently tapping it with a screwdriver...make the pilot bluer and bigger....when it's dirty it has yellow tips or yellow completely , the pilot should fully envelope the thermocouple as well
Nov 01, 2009 | Desa International GWP20T GLOWARM Wall...
Gas flow
Your regulater connected on tank has a shut down safety inside of it. disconnect tank hookup, then reconnect, always open tank valve slowely when you open to fast regulator thinks there is a leak and starts shutting down valve to slow leak. Opening slowely will solve your problem.
Aug 17, 2009 | Weber Genesis Silver B Grill
4 burner gas cooktop leaking small amount of gas at front burners and underneath the knob controls. Flame now licks above the bottom of the pan.
Hi, It sounds like the tubing to the burner has got a leak in it. Please get me a model # so I cna look this up and give you better instruction on how to get to the tubing.
Vic
Jul 01, 2009 | Cooktops
Gas leak in my GE profile JGP336
Contact your local gas company and turn off the gas to the unit.
May 01, 2017 | GE 30 in.Profile JGP940 Gas Cooktop
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
