Question about GE Cooktops
I have a GE Profile 30" downdraft 4 burner cooktop (model JGP989). I cracked the glass top while cleaning it. I have ordered the new replacement top, but I can't find anything online instructing how
The glass replacement top that fits my gas GE Profile 30" (JGP989) is WB61X10001 if that helps with your response. Thank you in advance for any advice you can give me.
  • 338 Answers
SOURCE: GE profile 989 cooktop with cracked top
jacobyparts.com has it for 745.. i dont think you will be able to find them for much cheaper
Posted on Dec 25, 2008
SOURCE: Stained gas range burner grates
Hey y'all. I have the same lame GE profile gas cooktop with the gray grates and burner covers. I know this is the expensive way to go, but I use Easy-Off "self-cleaning oven" oven cleaning spray. For about $5, you get 3 cleanings. It is a pain to do, but I have better things to do than scrub these grates all the time. I don't know why, but the baked on crud just drives me crazy. I tried everything to clean them completely. I even tried to scrub the darn things with a kitchen pumice stone(sold at walmart)but it is impossible to get the curvy areas clean. Now the paint has started to wear off on the burner covers.
I do not use the oven cleaner on the cooktop itself. I use soft-scrub with baking soda, then cover the cooktop with a sheet of heavy duty aluminum foil and cut out holes for the burners. This keeps most of the spills contained, and helps with cleanup.
I visited to the GE parts web page, and they only sell gray grates and covers. I am going to buy black BBQ grill paint(spray can)from Home Depot and try it on the burner covers first. They are the least expensive to replace if it fails, and if it works, I will paint the grates with this high temperature paint. I will keep you posted on the results.
Regards,
Laura D.
Posted on Sep 29, 2009
  • 221 Answers
SOURCE: Have a four burner gas GE Profile cooktop. How do
The igniter module is working fine. One of the switches (which are on each valve shaft) is stuck or shorted out. Pull a wire off each one at a time to determine which one is bad. Careful! 120 volts to each wire. Also, this can happen after you spill water into the valve area, if that sounds right, let it dry out.
Posted on Jan 30, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: OK, I have a cooktop that is discolored. Three
Sorry to read about your problem, I hope this helps you out.
you have to disconnected everything from the range, then take the unit out of the counter..will take 2 people
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Posted on Dec 21, 2010
rickead1
  • 1998 Answers
SOURCE: GE cooktop model 326BEFIBB. I'm having
or you could also have a switch issue sometimes when the switches overload on the inside they arch from one side to the other this causes power when it is introduced into the game to go through the switch the switches are wired in a chain from one the next in order to check this you would have to test where the voltage goes through each wire around the switches if your not familiar with doing electrical tests i would strongly suggest you call a technician. I just recently had a ge cafe that was a 5 burner and when you turned on to light one all would try to ignite after doing tests on the switch for which one was letting power go through even when the switch was off i narrowed it down to one switch and sure enough on the inside of the switch it had overloaded at one point and arched the metal inside the switch from one side to the other and this caused all to try to ignite because the switch was first in the chain if you have any further questions message me back and please remember when our chat has concluded to rank how this opinon has helped Thanks again Rick
Posted on Jan 07, 2011
I have a glass 4 gas burner stove top and cracked the glass, can I replace it? Its a GE Profile with a stainless steel front lip
Yes the glass is replaceable, you will have to order a new one, and you could do so through an appliance parts store. They can even put it in for you.
Mar 22, 2011 | GE 30 in. Profile JGP932 Gas Cooktop
I have a GE Profile 30" Ceran Schot cooktop mottle black glass.One of the burners has burnt in partial ring that will not come off with the recommended cleaners. Is it possible that it has literally...
If there was sugar in the item that boiled over, it will not come off it etches the glass. If it was with out sugar you might try a razer blade to scrape it off it will not hurt the glass if you use it flat
Sep 27, 2017 | GE 30 in. Profile JGP989 Gas Cooktop
Downdraft fan nor igniters work Electric tested and ok - what else could it be?
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Apr 11, 2010 | GE 30 in. Profile JGP989 Gas Cooktop
How to repair cracked corner of black ceramic cooktop
Epoxy would not work. If it is a very small chip and is NOT STRUCTURAL or in the heated are you could TRY the adhesive used for rear view mirror to glass attachment.
Sep 13, 2009 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
Ignighter issues
gud day,try to clean the area wer the knob place by using vaccium try to remove the knob then claen by vaccium,coz the dirt inside coz of grounding.
Jan 08, 2009 | GE 30 in. Profile JGP989 Gas Cooktop
Dec 12, 2008 | Cooktops
Ceramic Glass broken
when ordering you would have to know the color also
Dec 05, 2008 | GE 30 in. JP340 Electric Cooktop
GE 30 in profile jp350kccc for sale
I have this cooktop with a bad burner. What are you asking for it?
T
Oct 23, 2008 | GE 30 in. Profile JP350 Electric Cooktop
Glass top
The cooktop will need to be removed from the counter. Turn it upside down and remove the screws. The biggest problem will be removing the cooktop from the counter. Sometimes it is not worth fixing as the part could cost around $400. NEVER use a cracked top as it could suddenly explode. This is tempered glass and very unstable if cracked or chipped.
Jul 10, 2008 | GE 30 in. Profile JP350 Electric Cooktop
Order in black w/matte finish grates & downdraft cover
No. If it is really important order the grates and downdraft cover as replacement parts. This will be expensive probably around $200 - $300.
May 25, 2008 | GE 30 in. Profile JGP989 Gas Cooktop
Cooktops Logo
102 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
