Question about Frigidaire 30 in. Electric Gallery Series Self-Cleaning Double Wall Oven
Accidentally hit clean button on a Frigidaire Gallery Oven. Hit Cancel button. Oven door won't open.
Hit the cancel button and waited but door still won't open.
  • Official Brand Answer
  • 2,267 Answers
I appreciate your post, C Maury!
From my understanding your hit the clean button on your Frigidaire wall oven and now the door will not open. I would hold down the cancel button for at least ten seconds, this should unlock the door. If that does not help I would recommend disconnecting power from your wall oven by flipping the household circuit breaker for ten minutes. I hope this information was helpful to some degree. -Matt
Posted on Nov 21, 2014
Corster
  • 79 Answers
SOURCE: My oven is beeping!
Try turning it off at the mains, then whilst turning it on, press and hold the cancel button.
Check the fuse and any other electrics on the same ring; eg. Washing Machine - this can indicate that the circuit breaker has tripped, replace any fuses and check integrity of electric on that circut, then flick it back on.
Posted on Jan 28, 2008
  • 17 Answers
SOURCE: Frigidaire Gallery Series Oven Locked
Not familiar with this particular stove, but it sounds like you activated a child protection lock. To turn these on and off, you have to hit that lock icon and hold it for 4-8 seconds for anything to happen. This is so that the kids won't have sense enough to unlock it, assuming that you locked it to keep them out!
Also, frequently they work  in stages. Hitting it one time (for 4-8 seconds) will lock the panel, hitting it another time will unlock it, hitting it a third time might lock the door, and so on. So RTFM, or just keeping hitting it multiple times for 4-8 seconds each, and see what does what. But the manual should tell you everything you need to know. You can go to the GE website, or to managemyhome.com, which is maintained by Sears, and you should be able to find a PDF copy of the manual if you don't have the manual that came with it.
Posted on Feb 09, 2009
SOURCE: Oven locked so I can't shut door/operate oven
Thanks a million, solved the problem like a charm. For those that can't find it, it is on the left side orf the OVEN, not the stove. Once you open the door, you'll find it on the frame's upper left side corner, can't miss it. Good luck
Posted on May 05, 2009
  • 10865 Answers
SOURCE: door locked after shutting down cleaning cycle earlier than
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
Posted on May 20, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Frigidaire double oven beeping and showing f8 code
Hello there
First i would unplug it for 1 hr to allow the oven internal reset to reset it'self than plug it back in and see what happens but if this doesent help than here is a listing of the code and what it means
F8 Lock motor relay watchdog is ative when it should be off Microprocessor checking the operation of the EDC lock relay after self clean is selected, relay failed. Replace EDC.
Lock switches Check or Replace component
Posted on Dec 31, 2009
I went to clean my oven and it locked I pressed cancel the door opened but my oven doesn't work when I hit bake locked signal comes up what do I do
Your oven got locked by a hook that gets initiated when the "Clean" button\option is depressed. Even though you hit cancel and the door opened, it is possible the hook didn't completely recluse back into it's housing.
Might I suggest trying to hit clean and let it take it's course, and try to verify the unit DOES heat up during the cleaning process? This may be the only option you have without calling out for a service call.
I really hope this helps.
Aug 16, 2017 | Ovens
I hit the clean button in error and then cancel right away. I shut off the breaker for 15 min and the oven door still won't open
Hello there and welcome to fixya
Well you are in the right direction but here is the thing you need to unplug the oven for at least 1 hour to allow the internal reset feature to erase the previous command.
Then only after the hour is over plug in the oven then you may hear a audiable click sound simply wait 5 min then press the cancel button then attempt to unlock the door it should now open ok?
Hope this is very helpful for you
best regards mike
Feb 15, 2011 | Frigidaire GLEB27S7A Electric Single Oven
I was able to clear the locked door message, and get over working following steps above, but cannot get the lock mechanism to release, and therefore cannot close the door
Check out these steps at the following link... http://www.geappliances.com/search/fast/infobase/10004586.htm
Range - "LOC DOOR" flashes in the display
If "LOC DOOR" is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
Motorized Switch
    1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
    2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
    3. While you hold the door jamb switch in this position, complete the following steps.
    4. Press the Clean pad, wait 10 seconds.
    5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
    6. Wait 10 seconds for the display to clear.
    7. The door should unlock and there should not be a need for service.
Manual Switch
    1. Press the Clean pad.
    2. Close the door.
    3. Slide the latch to lock the door.
    4. Hit the cancel button immediately.
    5. Unlock the door.
Motorized Switch
Manual Switch
    2. Close the door.
    5. Unlock the door.
Nov 24, 2010 | GE Profile JTP18 Electric Single Oven
How do we unlock the oven door! Accidentally pushed a button in front. We have no manual or SS#. Oven was in house when we bought it. We unplugged it to turn off and was able to open the door. Please...
IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com
The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock. IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can un-lock (safety feature).
Good luck with this!!
Aug 18, 2010 | GE Profile JTP18 Electric Single Oven
Pushed the clean button, the oven locked, and the screen started beeping and flashing f9 or f7. I hit cancel, and the oven is still locked and the clean button is sill flashing.... It has been 10 hrs!
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%^%$
Jun 21, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Door will not open after self cleaning cycle
I tried a suggestion found on this site.
Turn off the light button and hit cancel. Cancel did not work for me.
Turn off the light button and hit clock. Worked for me. Technology?
Apr 11, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
F8 Displayed
F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock).
Apr 01, 2009 | Frigidaire 27 in. Electric Gallery Pro...
Oven Door Locked
the oven door does lock during self clean, otherwise it will not work. however, the door is supposed to unlock after the oven has cooled. if it is still locked, turn the oven to self clean and wait about a minute and then hit cancel and see if the door unlocks. if not, there may be a probelm with the door lock mechanism. Joe
Nov 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire gallery self cleaning convection oven
Press and hold the "clean" button for 5 seconds.
May 11, 2008 | Ovens
Frigidaire 30 in. Electric Gallery Series Self-Cleaning Double Wall Oven Logo
333 people viewed this question
Top Frigidaire Ovens Experts
Oloyede Monsuru
ashburton
Starnley Johnwells
Starnley Johnwells
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
