Question about Home
I have a triton Amber 3 shower and last niht the water just stopped coming out mid shower. I turned it off and back on again no water at all .. thenit came back ok for a bit then went off again.. jus
I have a triton Amber 3 shower and last niht the water just stopped coming out mid shower. I turned it off and back on again no water at all .. thenit came back ok for a bit then went off again.. jusy no water what so ever.. what can be the problem please this is very odd !
  • 4 Answers
Sounds like it is clogged. Buy a bottle of CLR, put some in a bowl that the shower head will fit in, remove the shower head from the pipe and let it sit in the bowl of CLR for a few minutes. If you run a search, there are regular household items that you can buy instead of the CLR. Might be cheaper.
Posted on Nov 20, 2014
Testimonial: "HI oh no.. its not a clogged shower head its clean.. the water just stopped completely .. then started again after id turned it off and back on a few trimes.. but then stopped again the water just completely stops with force. instantly .."
  • Paul Doty Nov 20, 2014
    If you have a single valve instead of separate valves for hot and cold, it may be clogged. Unfortunately, it will need to be removed from the back side.
4 Suggested Answers
  • 297 Answers
SOURCE: 1/2 water through shower head 1/2 through tube
patmac make sure the clear hose is a overflow first. then make sure all connections are correct,sounds like an areator problem,some after market shower heads don't come with one you can purchase one at your local plumbing store.
Posted on Jul 27, 2009
SOURCE: My Triton Millenium shower just
there is a cut out unit on top of the element *** unit which is to prevent damage to elements if the water supply fails but i have 3 of these fail down to use have checked the triton spares and the only show it with the element unit cost over £100 you can bi pass it with out any problems just make sure always turned off at pull cord when not in use or phone to see if you can just buy the cut out if you cant its shame on them good luck spares number 08449800745
Posted on Jan 24, 2011
SOURCE: triton topaz t80i. Power to unit ok, but no water flow.
I fitted my new triton amber 3 electric shower but no water comes out when turned on. The plastic inlet has a copper compressible fitting and the light comes on when the setting is at stop position so there is power going to it. When I turn the setting no water comes out. The fuse is only 30 amp at my fuse box, the shower is 8.5kw,do you think this is the problem? It worked for my last redring shower. Or would it not work if i;ve tightened the compressible fitting to the inlet too tight?
Thanks for any help.
Gary.
Posted on Mar 09, 2013
I have a triton Amber 3 shower. No water flows when switched on - but the mains LED is lit and water is available
the solenoid has failed,thus not opening up to allow water flow,i have found that spares are fairly expensive for tritan. if you find out the rating ie 7.5 kw etc then buy a replacement shower from wickes their showers are tritan and are normally like for like fitting,also a lot cheaper than showers that have tritan marked on them.
Sep 05, 2011 | Home
My Triton Millenium shower just stopped working mid shower. Power lights went off. Have checked fuse, power ok but will not switch back on. Any ideas.
Jan 10, 2011 | Home
Hi, I have a Triton Power shower, it has worked fine for the last few years but today the water stopped. The pump is still running but nothing is coming out. Would you have any ideas. Thanks, Gary
Hi Gary, Sometimes things like pieces of worn out faucett washers get in the shower head water line and clog things up. The only alternative is to disconnect the plumbing starting from the shower head back to the wall and start removing the pieces of rubber. There could be a problem with the impeller in the power shower pump but again you would have to gain access to the pump impeller and inspect it for damage. An impeller can fail in may ways... most of the time it is either broken blades of a broken hub of the impeller. Other times the housing for the impeller can be broken and water bypasses inside of the pump vs exiting the pump.
Thanks for using FixYa.
Kelly
Jun 03, 2010 | Home
My Triton (Jade) electric shower has abruptly stopped supplying hot water. The pressure appears unchanged and altering the temperature control dial has no effect on the heat. Is it likely that, if needed,...
I have a Triton Ivory 111 shower, twice this week the water as just stopped flowing mid flow, presure ok and power still on what could be the trouble??
Stew.
Apr 05, 2010 | Home
I have a Triton Rapide R2 electric shower problem
you can check the pipe lines there are normally more thane one way to set the pressure of the water one by the shower knobs 2 by the behind the head in the wall there are some water valves that may need to be opened up or by the water heater there are some valves there one coming off the heater one just on a pipe by the heater they may need to be opened. try that if that doesnt work come back and let us know and see what else you can do to fix it
Nov 11, 2009 | Water Pik Waterpik& Elements& Fixed Mount...
My triton martinique electric shower low pressure light comes on and the water goes cold but there is nothing wrong with the pressure
I had a brand new Triton Rapide 3 with this issue, we had good water pressure but the light on the front would keep coming on.
I found there was a micro switch located at the front almost dead center of the shower, couldn't miss it when you removed the cover. A plastic arm below this switch is raised when the water pressure increases tripping this switch and allowing the heater to come on.
I found two things wrong with this, one this plastic leaver was thin and bent easily and secondly the switch did no line up overly well with the lever. Easily fixed, I cut an inch off the end of a zip tie or panduit strap, and super-glued it to the top of the lever (not the switch as the glue will probably ruin the micro switch.) 5 minute job later and with the shower back together it works beautifully. My wife will be happy, you wouldn't believe the torrid of curses I got this morning having only replaced the old unit last night.
Probably don't need to say this but, make sure you isolate the power before removing the cover.
Jun 03, 2009 | Sony Playstation 3 (PS3) Console
Triton electric shower T90si ran dry and not now working.
pump needs attention and the heating element has burnt out
pump needs water to run and the heater element needs water to keep it cool
Sep 07, 2017 | Heating & Cooling
Home Logo
164 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
