Question about Sharp Televison & Video
I am holding a Sharp-TV---21A-K91, but it is not working due to mother board problem. Where I a can get new board for Sharp- TV---21A-K91
Ybsnaidu@gmail.com
SOURCE: 250gb sata hard disk to 845 glad mother board
hi am sathya,
I have oner doubt in my intel p4 845 chipset board , what are the processors in suitable in 845 chipset board.. Give me solution
Posted on Aug 18, 2008
SOURCE: how to repair mother board in chip level
board has getting on but desply not come and cpu surrounding componant not get power
Posted on Nov 20, 2008
myjosh007
  • 530 Answers
SOURCE: IBM 300PL Mother Board
hi! im josh may i help u? i bought one of that. you can buy that at HMR surplus center in cebu near city hall and if u r in manila pioneer st. cr. reliance st.mandaluyong city or you can browse their web at hmr.ph./ to look for the branches near you.you can have the prices too.hope it can help u.good luck!
Posted on Feb 13, 2009
SOURCE: intel p4 fw 82801db mother board vga & sound
download driver vga y sound fw82801db
Posted on Jul 13, 2009
  • 8457 Answers
SOURCE: What is the TV Tuner Signal Board part number for the Sharp Aquos LC-52d64U?
That the board which it have a square aluminun box at the edge of the board with a rounded bolt sticking out for inputs like ANT. input and AV inputs for like wires components inputs like multi colors like YRW,YRWGP holes for AV inputs also have HDMI hubs inputs for the high Def Pic.There are 6 HDMI inputs hubs for the tv Sharp Aquos LC-52d64U.Tvs Tuner board signal boards are also have to been known names to called as the tvs Main Logic boards and the tvs Mother boards also.U are fixing ur tv u must have to take it parts already.U can also compare the pictures between the tv Tuner signal board u are taking aparts out of the tv and the tv Tuner signal board you are buying they'll look axactly alike.The sticker of the serial numbers of the boards a few numbers in the begining on the tv Tuner signal boards should be the same also.
Posted on Dec 06, 2011
Problem with Sharp LC40le700un
Contact the autthorised service center for Sharp at your town.
May 07, 2012 | Sharp LC Televison & Video
Dec 06, 2011 | Televison & Video
My sharp aquos 30 inch tv will not come on. what could be the problem
Hello; I have an similar LC30HV2U for sale in my TV repair shop for $350. This is a 2 piece unit. The AV box and the monitor. I am also a Sharp authorized servicer. In the monitor there are 2 inverter boards on the right side that have an 80 % chance of causing this problem. This set counts "lamp errors" due to one or more inverters not working on startup. Once the set accumulates 5 lamp errors, It will not allow the set to come on. The first thing Sharp tells us is to replace both inverter boards. About $90 each. If those don't fix it the cost will go much higher due to a bad power supply board or bad LCD Panel. Hope this helps, John
Jan 02, 2011 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Sharp CX80H6 Has sound, no picture for TV or AV OSD works
This style of failure with the CX80h6 and indeed other CX80 & SX80 series SHARP 80cm sets is usually due to problems with the PIP (picture in picture) sub-board. This small board plugs vertically into the main left hand PCB (seen from rear of set) and is sealed in tin-plate for RF shielding. I've had two CX80h6 sets recently with this exact failure and both had problems with the PIP sub-board. One needed a new regular on the board while the other had a dry joint on the connector. This sub-board is not available from SHARP anymore, but in most cases the failed component is a discrete that usually can be sourced in it's own right. So this sub-board is where I think you should start your fault finding.
Regards,
Romsey
Mar 15, 2010 | Sharp 32C-240 32" TV
Sharp lc-26dv12u about 2years old. All of a sudden
Sounds like the Main mother board is the problem. When the processor chip overheats, the programming information passing through the chip slows down. Most cases, replacing the main mother board will fix the problem.
Dec 29, 2009 | Sharp LC-26DV12U 26 in. LCD TV/DVD Combo
Lcd sharp tv flashing green light
Try unplugging the unit and while unit is unplugged hold the volume up button and channel down buttons down and while depressing both buttons plug the unit in. Let go of the buttons and the unit should come on in the service mode. There will be a small k on the screen. With the sharp remote press the channel up button once. This should bring up a menu that will show a lamp error line. If the lamp error is = to 5 the unit is in lamp error shut down. User channel down to highlight that line and curser right arrow to highlight the lamp error #. Hit the enter button to clear the lamp errors. Now unplug the unit and let it sit for a minute and plug back in. I hope this corrects the problem. If the unit does not come on by doing this or if it does and you do not find lamp errors the power supply pcb may have been damaged by the surge.
Jan 06, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
I have sound but no video at all
A defective backlight.  I've had the issue several times now with my sharp 32" lcd tv and in the process of trying to get a replacement tv.
Oct 27, 2007 | Olevia LT42HVi 42 in. LCD Television
Tv not working
i have the LC-26GA4U LCD TV & mine has the exact same problem. I brought it to an authorized sharp tv repair shop it turns out its the LCD panel. the panel costs $1700 & with labor installed it comes to $2055.43. almost exactly what I paid for the tv 2 years ago. good luck. Mike
Jul 11, 2007 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Televison & Video Logo
23 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
