Greetings all. I'm buying a Technics SE A909 power amp and was wondering if it can be used with another pre amp. Any answers would be appreciated. Many thanks.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 924 Answers
Yes. Pick one; any one. :-) All preamps will provide this amp with the voltage and switching ability it needs.
Posted on Nov 28, 2014
Technics 1080 pre amp volume control is not functioning correctly
Technics SE CA1080 Service Manual
there is a chip called an operational amplifier under a heat sink on the pcb,that fails when it get top volumed for two long theres regulators with heatsinks.
it is listed as,
Technics SE -CA1080 amplifier F61 fault,
May 13, 2015 | Technics Audio Players & Recorders
Greetings. I'm thinking of buying a Technics SE- A 900 power amp but the lights don't work. Does any body know where I can fix and approx how much. Many thanks
Personally I wouldn't buy it. A power failure could indicate a serious problem. Most amp power failures are caused by power transistor failures. Sometimes these transistors can cost a lot of money if they are not common type. I once had a amp where one transitor would cost £50 to replace, and it need 3 of them!
Nov 12, 2014 | Audio Players & Recorders
I have this turntable but can't get sound from my technics dv290 . There are 2 leads which I have plugged in the back . I can fainted hear the record.every thing else works well.what do I need for my...
I rather suspect that your amp might not have a "magnetic cartridge pre-amp". If you check your instructions book it should state if the amp has a dedicated "phono" socket with inbuilt pre-amp. If it does use that. Otherwise you can buy a pre-amp online that will do the job.
Aug 12, 2013 | Technics SL-1200MK2 Turntable
Did Technics make a pre-amp suitable for putting between my SL1200Mk5 and a Technics SL-EH790 stack which has no external turntable in socket to the internal pre or power amp, just an aux in thn needs the...
Mail me and i gave you the parts you have to buy for a good self built one, which is way better then a pro-ject phono box s, which i also have and not diy becomes interesting comparing it to 400euro+
hi-fi brand phono amp. Only those hi-fi brands just but chines capacitors in their gear.... sad
Jan 19, 2013 | Technics SL-1200M3D Turntable
I HAVE A BSR 3000 EQ, A TECHNICS POWER AMP SE-9021K,AND A TECHNICS SU-9011K PRE AMP HOW DO I HOOK IT ALL UP?
Very easy.
SOURCE > PRE-AMP > EQUALIZER > POWER AMP.
Not sure why you want to do it, though. Your pre-amp already has an abundance of sophisticated tone controls and filters.
If I might venture a guess, you are trying to correct some serious deficit in your speakers or in your source. If you need sophisticated tone controls, filters, AND an equalizer, you need to ask yourself why ... and fix that problem.
Oct 12, 2012 | Audio Players & Recorders
I have a Pioneer VSX-520 receiver and was told I need a pre-amp to hook up my record player.I purchased a technics integrated power amplifier from a flea market and was wondering if it is compatible with...
IF the unidentified new Technics Integrated Amp has a PHONO section it will support the turntable.
IF the unidentified new Technics Integrated Amp has, say, a Tape Output, that could feed any Line Level input on the Pioneer. OUT to IN.
Aug 07, 2011 | Pioneer Audio Players & Recorders
SURROUND AND CENTER SPEAKERS WORK FINE BUT NO SOUND COMING FROM FRONT SPEAKERS. WHAT COULD BE THE PROBLEM?
Can you fill in something about the speakers and how you have them attached? Since this is a stereo amplifier one wonders how you have anything but the front speakers powered unless you're using THIS amp for just the one pair and driving it from an AV receiver pre-out.
http://www.hifi-pictures.net/amplifiers-home/Technics%20SU-V500/amp.htm
What else is missing from this problem description?
Feb 02, 2011 | Technics SUV500 2-Channel Amplifier
No cable for technics
I had the same problem with my sua900s pre-amp.
If it's the same cable, you need a (I think 6 pin) mini din cable, male to male. It's sometimes called a PS2 cable (nothing to do with Play Station!). It's the same cable that runs from your mouse into your pc and is readily available for about £5 from online computer retailers. Check the number of pins first though!!
Feb 08, 2009 | Technics Audio Players & Recorders
Technics SH-AC300 Connection to Power Amp & Pre-Amp
Hi!
The problem is, that your SH-AC300 needs an amp with 5.1 input (but no decoder). For this purpose technics delivered SA-AX710.
So if you'd like to use your current equipment it would be impossible.
The only option is for you to buy 2 more Power Amps (SE-A900S), so that each of 3 amps would take care for one part of music. (one for FL, FR; one for RL, RR; and one for sub and center).
Another option is for you to buy SA-AX710. Then all the problems would be solved with it.
Jan 15, 2008 | Technics SA-DX950 Receiver
37 people viewed this question
 Grubhead
Grubhead
