Question about Dell Computers & Internet
How do I fix problems of Dell computer 780 with power light yellow and black screen?
I restarted it so much times and I tried to reboot on safe mood.But no change
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Dell Master
  • 884 Answers
Hi
You don't mention which model of 780 you have and there are 4 different sizes. However several manuals (in pdf format so can be downloaded and saved to computer) can be found here:
Product Support Dell UK
Looking through them, using "light" as a search term I found these quotes below.
"Solid amber light when the computer does not
start indicates a problem with the system board or
power supply. Blinking amber light indicates a problem
with the system board."
and
"solid amber - indicates that the system
board is unable to initialize"
From these I would think that the main board (motherboard) on your computer has become faulty, and needs replacement.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Posted on Nov 20, 2014
    Sergeant:
  • 320 Answers
Yellow or Amber lights on the power button of dell computers generally mean power issues. This can be a bad power supply, or dead motherboard.
If the computer is under warranty you can contact dell for a free replacement of the part. Otherwise you may need to contact a local computer repair shop to test which part is defective and have it replaced.
In most cases the data on the hard drive is fine, so you probably have not lost any data due to this issue.
  • Official Brand Answer
  • 560 Answers
Getnet,
What do the diagnostic led lights show. The diagnostic LEDs are located on the front of the chassis next to the power button. These diagnostic LEDs are only active and visible during the POST process. Once the operating system starts to load, they turn off and are no longer visible. Below is the manual that provides information on what the led pattern shows to help resolve the issue.
Optiplex 780 manual
http://dell.to/1HqoNmD
Thank You,
Dell-Jesse L
Dell Social Media and Communities
  • 36 Answers
SOURCE: stuck in safe mode with black screen
spywaregard 2008 is malware, a parasite if you will
http://www.pcthreat.com/parasitebyid-7159en.html
the last 1/2 of this article will run down a list of files you need to delte to get rid of this nasty little bugger. You can also download various tools to remove it, but it is dependent on your comfort level. if you are comfortable searching for files and changing a couple of registry keys, then by all means, manually is the way to go. If not, you will not have a hard time finding a tool to get rid of this
Posted on Jan 09, 2009
SOURCE: Loud Fan, Three Beeps, Black Monitor and No Keyboard response
I have the same model after youlet it sit for a long enough period to cool down it will come back on and work normal, it is a cooling problem called gateway and they confirmed this theproblem I ran in to was what fan this computer has 3. temp fix I used was to remove the tower cover to allow better air flow try this till you can figure out what fan is messing up
Posted on Jan 10, 2009
Fixe_You
  • 1800 Answers
SOURCE: Computer monitor stuck in safe mode
the problem is with ur Computer's Graphic card.
u can put a new one in case if it is a built in graphic card Chipset.
check ur manufacturer support page for more details.
plz rate this post as good as u can
Posted on Feb 06, 2009
  • 28 Answers
SOURCE: I have a Dell Dimension 4600 and it won't boot up.
i would have to disagree with jerry, while that seems reasonable if the motherboard fan isn't running at all then whether or not the video card is ok is somewhat irrelevant.
I would agree somewhat though, i think the PSU might be a good thing to check to see if it is functional.
when you power it on does the CPU fan start or shudder at least ? that would be my first guess for a problem if you had been having any problems recently
Posted on Apr 17, 2009
  • 4 Answers
SOURCE: My dell xps wont start properly, yellow blinking light
I have an HP that does close to the same thing. Mine goes into a 'Perm-Sleep' mode that I can't seem to pull it out of. I have to remove the battery, then unplug the power adapter, not in that order. Leaving it in this condition for about a minute so that all the power stored in the RAM goes away. This is the same as holding the power button down for 10 to 15 seconds until it completly turns off, sometimes referred to as a 'Cold Boot.'
Once I have powered it down I have to go into the control panel and select the power settings and make sure that hibernate is not an option. If you close the lid on the laptop and the systems goes into a sleep state, it may be configured to go to hibernate after, say an hour or when the battery gets close to being drained. My computer does not like to come out of hibernate and I have to Cold Boot it, so I just don't let it go into a hibernation in the first place anymore.
Posted on May 10, 2009
What would cause my screen to go black and then can't reboot 8.1 on dell pc??
If this is a Laptop, remove battery, Plug in charger to PC and then try to reboot. A bad battery will suck all the power from charger and won't allow the computer to have enough power to boot.
Aug 18, 2014 | Computers & Internet
Error codes
Go to Dell Support > Optiplex 780 Desktop PC > Manuals & Documentation > Dell Optiplex 780 Service Manual,
http://www.dell.com/support/troubleshooting/us/en/19/Product/optiplex-780
Diagnostics > Diagnostic Lights,
"Problem Description - A possible expansion card failure has occurred"
"Suggested Resolution -
1) Determine if a conflict exists by removing an expansion card (Not a graphics card) and restarting the computer.
2) If the problem persists, reinstall the card you removed, then remove a different card and restart the computer"
Be SURE to follow Anti-Static Procedures.
Regards,
joecoolvette
May 13, 2013 | Dell OptiPlex 780 PC Desktop
Images of password chip dell 780
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer Windows Advanced Options Menu Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select safe mode with command prompt Click start run type cmd press Enter black screen should open DOS mode this will vary depending on your operating system type in net user username For eg. If you want to change administrator password , type net user Administrator It will prompt you to enter the new password. Enter the new password and the password is changed if this fails you will need to Select safe mode with networking to download you could download all of these or just one save them to a usb drive for later use if one fails to remove the password Windows Password Recovery Basic http://majorgeeks.com/CmosPwd_d239.html A CMOS BIOS password recovery tool Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus. http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free. Hope this helps.
Jan 22, 2013 | Dell OptiPlex 780 MT Desktop Computer...
Dell optiplex 780 i wanted to change from windows 7 to xp blue screen appears how to fix
You are going to need to start your computer in safe mode and find the XP drivers that will work for your motherboard manually from the web (Assuming that there are any created for XP for that board). That blue screen you keep getting is because you don't have the correct driver loaded for something on the motherboard that it needs to boot correctly and your XP install couldn't find it on the web to install automatically.
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking".
Now start looking for your drivers here:
http://www.dell.com/support/drivers/us/en/19/Product/optiplex-780
Aug 17, 2012 | Dell Computers & Internet
I have a black screen that says safe mode, safe mode with networkin , safe mode with command prompt and laast known good configuration but when i go to safe mode my computer just reboot all over again
This recycling/rebooting into this screen is normally caused an error (hardware or software).
You MUST turn off - Automatic Restart to see the error message.
Power down your laptop.
Press the power button to turn-on laptop.
Start pressing the F8 key immediately AFTER the DELL logo screen and BEFORE the windows screen.
You SHOULD be brought to the same screen as you described above but with an additional option: TURN-OFF automatic restart. Select this option and press ENTER.
Let laptop cycle and you should see blue background screen with white letters giving you information.
Please provide the ERROR message on screen BEFORE we can advise you any further.
Mar 30, 2011 | Dell Latitude D600 Notebook
Short Version: My Dell Inspiron 530 continues to get stuck on the Dell start up screen. Long Version: For 3 years my Dell Inspiron 530 had worked flawlessly, then all of a sudden it would continue to...
Try starting in SAFE MODE.
Restart the computer and push the F8 button repeatedly (before anything shows on screen).
(if you miss it just restart and try again)
When the options come up select START IN SAFE MODE NORMAL.
Wait for windows to start then:
RIGHT CLICK the MY COMPUTER icon on your desktop.
Then selct PROPERTIES
Then HARDWARE
Then DEVICE MANAGER
This will list all the hardware connected to your pc. If you see any red X 's or yellow ! 's next to their names then that means there's a problem with that piece of hardware and you can click on it to see what it is. Try RIGHT CLICKING on it and selecting PROPERTIES then DISABLE it if it's got a red X and then try rebooting normally.
If you still have problems booting normally, try booting into safe mode again...
Then LEFT CLICK on the MY COMPUTER icon on your desktop.
Then RIGHT CLICK on the LOCAL DISK C icon.
Select PROPERTIES.
Select the TOOLS tab.
Then select CHECK NOW in the ERROR CHECKING box.
This will check your C drive for physical errors and fix them if possible.
Once complete, restart and see if it will boot normally.
If you still can't boot then you either have a dead / dying hard drive or maybe just some bad RAM memory or maybe even a bad or loose cable connecting the hard drive to the motherboard. Either way more troubleshooting will be required.
Good luck and comment back if this was helpful and with how you make out.
Feb 02, 2011 | Computers & Internet
Operating system not found
Hi there. The thing that caused the shutdown is a software conflict. Go to the windows advanced option by pressing F8 key when you see the Dell Screen upon restart of the computer. Choose "Disable automatic Restart in system error" and press enter. That should fix your problem.
^_^
May 18, 2010 | Dell Inspiron Mini 10 Netbook
HELP!! (dell precision 340) im getting 4 screens when i turn on m
Reboot into Safe Mode by repeatingly tapping on F8 while in process of rebooting and then select "last known good configuration". If that fails reboot again to safe mode and select safe mode with command prompt and in the command prompt type "chkdsk /f /r " <enter>
If that doesnt work do place your Windows CD into the Cd-Rom, reboot and select option "Repair"
Jan 02, 2009 | Dell Precision 360n PC Desktop
Kds model 780 monitor no signal, power button does not work
My monitor does the same thing at times and sometimes shows "No Signal" and at other times the screen will maintain the images but the backgound color switches to mustard yellow. In each of these cases I have been able to solve the problem by unplugging the power cord from the electical outlet for about three seconds and plugging it back in. I have a KDS model 780 LCD.
GOOD LUCK
Dec 15, 2008 | KDS Radius RAD-5 15 in. Flat Panel LCD...
Computers & Internet Logo
136 people viewed this question
Alun Cox
