Question about Gaggia Coffee Makers & Espresso Machines
Hi, have a gaggia newespress006, gaggia expresso pure machine. I have descaled it and tried to do a backwash with the holder with no holes and it still continually leaks after using it for coffee? An
I have descaled it two or three times and I have also done a back wash on it a couple of times with the cup holder that does not have any holes.
  • 352 Answers
Look for easy stuff first. If you can get the top cover off, see if any of the piping/tubing joints are leaking.
If it leaks around the portafilter while making coffee, you need to change the portafilter gasket.
If water dribbles into the portafilter after making coffee, replace the three way valve.
If it is dribbling water in to the catch pan it is either the three way valve that needs to be replaced or the boiler gasket leaking and needs to be replaced.
Posted on Nov 25, 2014
  • 2039 Answers
SOURCE: expresso machine
descaling gonna improved the pressure = stronger coffee and clean the inner boiler =warmer coffee but use descaler only not vinegar descaler melt calcium vinegar remove some calcium in littlt piece 1 part descaler 1 part water fill the water container open valve for a few second close it leave it for 15 minute and repeat untill empty after rince very good that stuff is corosif
THANKS FOR USING FIXYA
FROM MONTREAL CANADA PIERRE
Posted on Feb 18, 2008
mirran
  • 515 Answers
SOURCE: My Saeco Aroma Expresso machine has water leaks
I think you have to replace the gasket in the machine where the portafiller fits on the machine.
Make sure your filter is clean before you replace any gasket.
/Mirran
Posted on Aug 23, 2008
  • 25 Answers
SOURCE: Keurig starts & stops without brewing coffee, just descaled
The pic is clogged with coffee or the air bladder is bad. Use the tool on the underside of the tray to clean out pic. If that doesn't work, the bladder will be bad.
Posted on May 14, 2009
  • 211 Answers
SOURCE: coffee ground are coming out of the k-cup area
Make sure the needle in the bottom of the K cup holder is not missing, broken or bent. Also, look at your used K cup when it comes out. Is there a hole in the top and the bottom? It sounds like the pressure is building up within the K cup due to a backup at the bottom of it. This could also occur if the bottom needle hole is obstructed. Be careful...the needles are sharp!
Posted on May 28, 2009
SOURCE: Keurig only brews about 2-3 oz. of coffee.
Doesn't sound like a descaler issue. I am having problems with mine and noticed that water is flowing back into the reservoir when it is pouring into the coffee cup. I think there is a valve that is not closing properly.
Posted on Mar 23, 2010
How do I clean the solenoid on my Gaggia classic?
Descale the machine or backwash the group, just make sure when you are backwashing the return tube is not in the water reservoir.
Jun 27, 2010 | Gaggia Classic Espresso Machine
Hi my Gaggia Classic is not pumping water out of the perculator head, I have flushed the screen and the motor is running ok and the steam attachment works fine?
If you can get hot water from the wand, then the problem is in the boiler fitting that feed the head, try descaling again, or remove the screen and diffuser and clean area or backwash machine.
Apr 09, 2010 | Gaggia Classic Espresso Machine
How to remove shower disc
You can use the filter holder blocked with a piece of nylon so water will make the coffee around the shower and screw to desolve. Just keep the filter holder with hot water for 30 min and then try to remove the screw. You can hold the small screwdriver with a plyer and by heating it a litle bit on the back try at the same time to turn it. This will loose the screw.
Dec 20, 2009 | Gaggia Classic Espresso Machine
THE TEMPERATURE ON THE EXPRESSO AND STEAMED MILK IS warm but not hot. Any thoughts?
Hi
There are a couple of things.
Your building up scale inside the boiler. DESCALE
Your steam boiler is dying. REPLACE
You can do this your self if your handy.
Nov 14, 2009 | Gaggia Syncrony Espresso Machine
I have a Gaggia Evolution expresso maker about 8 years old. When button is pressed to start motor it just hums and no hot water comes out. The motor only runs if I open the steam outlet
Try this, under the grouphead, there is a screw and screen, remove those, and check screen to see if it is clogged, when screen is removed press button to brew, if water flows freely then problem is at the screen, if no water flows, then it is on the inside of the machine. You will have to run a descale cycle to clear out machine. Check the folling pic for the screen location.2722dbe.jpg
Jun 27, 2009 | Gaggia Syncrony Compact Coffee...
Gaggia Classic - water not flowing
Remove the screw and shower in the group, then press the brew button, if water flows then clean shower. I will send instructions for descale and backflush. Cut time for backflush by half.
Dec 09, 2008 | Gaggia Achille lever operated espresso...
Hot water
Have you kept up with descaling?
Probably the water heater has failed. If you're technical then most parts should be replaceable but you may have to order them from Gaggia in Italy.
Oct 30, 2008 | Gaggia Titanium Espresso Machine
Gaggia evolution- water doesnt flow through the brewer
Make sure your filter in the machine and in the filter holder is clean, the filter in filterholder there you will see a little light in the middle if you head it to light, else you have to replace the filter.
Feb 23, 2008 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Coffee Makers & Espresso Machines Logo
99 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Michael Vincent Cruz
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
