What is m2 code how cani reset in Konica Minolta bizhub 164
    Problem Solver:
  • 6 Answers
This is to display the count of the supplies life counter.
When the counter is reached to 0 life 1 will be detected and maintenance call M2 will be appeared.
The initial value is 40,000, and the countdown system is used.
Use Setting/Procedure
- To clear the count, use [CLEAR DATA] of the Service Mode.
Posted on Nov 20, 2014
  • 44 Answers
Menu/Select
Quick Setting
Quick Setting
+ or - & FUNCTION Menu/Select
+ or - & TCR AUTO ADJUST.
5 Suggested Answers
xeerie
  • 347 Answers
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
Posted on Jun 19, 2010
hamzaskilltd
  • 316 Answers
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Posted on Aug 07, 2010
xeerie
  • 347 Answers
SOURCE: Konica Minolta bizhub 163 Display
Code M2 means your photocopier machine require maintenance.In maintenance some old parts of your machine will be replaced with the new one and all this will be performed by technical services representative.
Posted on Jan 01, 2011
  • 3 Answers
SOURCE: Konica Minolta bizhub 210 error m2 appear on
Hi
You can reset (M2) by reset clear data
Enter to service mode By Pressing :
Utility - clear -0 - 0 - clear -0 - 1
Press ADJUST
Press CLEAR DATA
Turn OFF Copier and Switch it ON
Posted on Jun 26, 2013
Konica minolta bizhub 164 showing M2 maintanaince call
You need to replace 1st the consumables before simulation/reset to prevent further damage to Bizhub 164.
Dec 21, 2014 | Konica Minolta Office Equipment & Supplies
BIZHUB 164 error M2 what have I to do
Replace the developer and the drum make sure counters are cleared first and that Gradation adj is run along with Toner adj
Jul 10, 2014 | Konica Minolta PAGEPRO 1380MF All-In-One...
replace the drum and developer and then reset the counter
Konica mintola bizhub 164 maintainace call (M2)
replace the drum and developer and clear the counter also ensure you run the F8 after developer been replaced and new drum are installed
Mar 25, 2014 | Konica Minolta Office Equipment & Supplies
Konica bizhub 164 M2
1-Press "Menu
2-press Quick settings,
3-then press right arrow key 2 times
4-press Quick settings
5-then press left arrow then right arrow key.
Feb 26, 2014 | Konica Minolta bizhub Office Equipment &...
Konica minolta bizhub 164 reset code m2
Utility button then stop 00 stop 01. use arrows to get to clear data. then to maintenance counter clear/yes
Jan 13, 2014 | Minolta bizhub 180 Black and White Copier
Reset error m2 in konica minolta 164
Replace the drum and developer first. Resetting counters with out replacing parts is not good. The machine works on base on counter info you reset counters then not replace parts the copier will adjust voltages on certain items when in fact they are same items image problems and codes.
Desbloqueo del codigo m2 en konica minolta bizhub 163
May 18, 2010 | Konica Minolta bizhub 161f All-In-One...
How do I clear error message C-2558 for the Konica Minolta bizhub C253
tis error means abnormal tonder density in the balck image unit take the blacke image unit out and shake it while holding it level and put it back in the machine to reset the error code leave the machine on and open then close the front door
Nov 12, 2009 | Konica Minolta bizhub C250 All-In-One...
813 people viewed this question
k24674
