How many papers can cannonir3025ncopy per day
    New Friend:
    Problem Solver:
  • 6 Answers
This is to display the count of the supplies life counter. When the counter is reached to 0 life 1 will be detected and maintenance call M2 will be appeared. The initial value is 40,000, and the countdown system is used. Use Setting/Procedure - To clear the count, use [CLEAR DATA] of the Service Mode.
Posted on Nov 20, 2014
How do I find out a percentage of a number
You likely mean this to be the 'Average' number of employees per day rather than percentage. However you need to work out based on hr's per day that each employee can work. Lets assume though that they work full time, 8hrs per day. Then you would work out as follows:
3223.5 /8 /28 /306 = 0.047 employees per day
If they only work 1 hr per day it would be:
3223.5 /28 /306 = 0.376 employees per day
Each employee would need to work:
3223.5 /306 = 10.53hrs per month
Mar 02, 2015 | Office Equipment & Supplies
Purchased a Keurig B70 in June 2010, I usually have 2 coffees per day or 4 per day on weekends. Water is "softened". After placing K-cup in holder, selecting the brew button, I can only...
Patricia Cross Aug 06, 2017
possibly your keurig is clogged and water can't get pass the grounds...what you have to do is check the area where the water drips out and unclog it...stick a paper clip up it or maybe even a safety pin and move it around to loosen up and unclog ...
Lift up the latch and see where the water comes out,easy fix...
Aug 05, 2017 | Keurig Single Serve Ultra Brewer
Paper jumping problems
kindly set the page length in printing setting just press the pause button and go to configuration setting mode and set the parameter as per your software or print file.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 17, 2010 | Epson LX-300+ II Matrix Printer
MY LEXMARK T632 IS JAMMING MULTIPLE TIMES PER DAY BUT JUST OUT OF ONE OF THE TWO DRAWERS
Probably the pick up tires are worn. Try replacing them. Partnumber 40X0070.
The arrows on the wheels should point in the direction the paper goes in to the machine.
Apr 16, 2010 | Lexmark T632 Laser Printer
How many pages per minute on a InfoPrint 1332
The InfoPrint 1332 has a maximum output speed of 35 pages per minute. This speed can be less if you are using thicker paper or paper that's not 8.5" x 11", and other factors can affect the speed as well.
Apr 14, 2010 | IBM Infoprint 1332 Laser Printer
What is 230 microns in gsm?
230 microns is thickness of paper. gsm- grams per square meter is weight of paper per size, so varies even if remains at 230 microns, you need to stipulate paper size
Mar 31, 2010 | Audio Players & Recorders
My printer shows out of paper, but I loaded more paper, and it won't reset
1. Turn the printer off and back on to reset the printer, that possibly might relieve the problem.
2. Sometimes there is something "stuck" in the printer over or around the switch that alerts for paper outages. It happened to me... it was a black twist-tie that could not be readily seen since inside the printer is dark.
3. Believe it or not, sometimes the paper thickness is TOO MUCH for the printer to handle.
4. Make sure the paper is not DAMP or WET as this can have an adverse affect on the printing process.
5. Clean the printer, as it may be inundated with paper dust and other debris.
6. Questions for Clarification:
a. how much printing do you do; i.e. number of reems of paper per day?
b. how old is your printer?
---Rob
Dec 19, 2009 | Office Equipment & Supplies
Sir, I, have developed my application on windows 98 but now a days everywhere set the WindowsXp but my printer Epson LQ-2090 have not a Custom paper setting. Please tell me how I can solve this problem for...
have you created same paper size as per windows 98 custom paper size ..... if not create as same please create the same and select the printing area also in the server properties ...... in the printing preference change page size to your created page size in layout tab advance option and in paper/quality tab advance option ... and check it ....
Nov 20, 2009 | Epson LQ-2090 Matrix Printer
Paper feed problem
With that many labels I would replace the paper feed roller, RL1-0266-000, about $8.00
it will save you lots of headaches and a spare will fix it next time it happens.
Sep 01, 2009 | HP LaserJet 1022 Printer
k24674
jasbo
jasbo
