Question about Bernina Sewing Machines
I have a bernina 801 sewing machine. I am unable to dis engage the wheel to reload the bobbin, it will not turn
Bernina 801 model unable to adapt the wheel to thread the bobbin its just stuck
    Sergeant:
    Champion:
  • 282 Answers
Have you ever lubricated it? Sewing machines must be periodically cleaned and lubricated or they will get stuck and freeze up
Posted on Nov 20, 2014
  • Bernina Master
  • 9,583 Answers
Cleaning and oiling (a drop or two of good quality sewing machine oil--not 3-in-1, WD-40, cooking oil or anything of the sort) will keep your machine happy. Be sure to oil the upper and lower mechanics. In your case, there are usually some oil holes near the handwheel. Be sure to give a drop or two. If it's still stuck, try directing a handheld hair blower set on hot into the interior mechanism, concentrating on the handwheel area. Frequently, that will loosen things up. In the meantime, if you are unable to wind your bobbins, look at picking up a stand-alone bobbin threader at the local fabric store. Last time I looked, they are around $30 and actually save wear and tear on your machine.
Posted on Mar 02, 2015
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
SOURCE: singer sewing machine model 6012 c
hi
i want to know how i put thread in the sewing machine
thank you
Posted on Aug 23, 2008
  • 19 Answers
SOURCE: Bernina Bernette 65 sewing machine
Presumably neither of you has or knows how to adjust your bobbin tension so, I'm going to presume it's your hook. Make sure you are threading the machine coorectly then you'll need to remove your needle plate by removing the two screws, pull out your hook (this is the part your bobbin sits in) but make sure you note which way it sits inside your machine. Have a look at the plastic hook for any sharp edges or burs, you may need to replace your hook or try and gently sand (400grit) the plastic if possible. The key part of the hook is the small blunted point as this is what catched the loop of thread behind the needle. Please make sure that when you put your hook back in, that it is on the left side of that little guard sticking out on the lower right of your machine.
Posted on Dec 10, 2008
RickE1
  • 202 Answers
SOURCE: I have bernina sport 801 machine and need to know
You can oil any two metal parts that move togeather or through each other. Do not oil bearings and do not oil gears. Do not use 3 in 1 oil or WD-40. Use regular sewing machine oil.
801's were made from 1979 - 1982. The way Bernina dated these on the machine is by the serial number. Your number would probably start with a 0 or a 1. 1970 is a 0, 1971 is 01, 1980 is 1, 1981 is 11, 1990 is 2, 1991 is 21 etc. etc.
Rick
Posted on Oct 08, 2009
SOURCE: bobbin singer stylist zig zag model 477
Check this web page
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_477_threading_diagram.htm
Posted on Jan 23, 2010
Instruction Manual for Bernina 801 - need instructions for oiling the Bernina 801
Hi Jim&Bev, The link below in a 23 page user manual for a Bernina 801 Sewing Machine, I hope this helps.......CHEERS..
Bernina 801 Owner Manual
Apr 16, 2016 | Bernina Sewing Machines
The handwheel will turn manually but it will not move using the foot pedal. The sound it makes when I press on the foot pedal *sounds* like I am filling the bobbin.
foot pedal not moving needle - Home Forums - GardenWeb
ths.gardenweb.com > Home Forums > Sewing
Nov 8, 2013 - We have a Brother Limited Edition Project Runway Sewing MachineRefurbished LS2250PRW. I was trying to sew on a button and was turning the hand wheel to do ... front near the needle where you can run the machine with foot pedal ...just what I would experience when my Bernina was running, or not, ...
Sewing Machine Repair ' ThriftyFun
www.thriftyfun.com/tf/Home.../Machines/Sewing_Machines/index.html
The thread is being picked up from underneath, but will not form a stitch at all. ... Butwhen I push my pedal down my needle won't move, the motor runs, but nothing happens. ... I have a Bernina machine which is sewing OK with the normal foot. ....The hand wheel, the wheel at the end that manually turns to make the needle ...
Help me diagnose and fix a problem with my sewing machine - Sewing ...
artisanssquare.com > ... > Sewing Machines
Jan 11, 2016 | Bernina Sewing Machines
How do I clear cotton in bobbin case of Bernina 830E
take the needle out of the needle holder
remove the needle plate, be careful not to damage the screws
take the bobbin out and use a small brush or a can of computer air to clean dust, use a pair of tweezers to pull the thread of the bobbin area if needed
Apr 16, 2015 | Bernina Sewing Machines
Sewing machine wheel won't turn, motor whirrs also the wheel seems to be jammed, it cannot be turned either clockwise or anticlockwise
Make sure your bobbin winder is not engaged. Ten check to see if you have thread stuck in the bobbin race area. That's where I would look first.
Sep 12, 2013 | Bernina Sewing Machines
I have a bernina Sport 801 and my bottom tension is off. I'm not sure how to fix this. Adjusting the tension setting doesn't seem to work.
On the bobbin casing is a screw to adjust bobbin tension when upper tension will not solve the problem. Check your manual for location of the screw.
Aug 22, 2013 | Bernina Artista 180
Bernina 830 Record foot pedal won't engage sewing unless I turn the hand wheel.
your motor is going out. time to replace or rebuild your motor. both are high skill and should be attempted by a professional. take it to your nearest bernina shop.
Feb 07, 2013 | Bernina Sewing Machines
Hand wheel will not release on my bernina sewing machine what should I do?
If handwheel is difficult to turn manually, it most likely needs cleaning and oiling.
Oct 11, 2012 | Bernina Sewing Machines
Rick
Sep 20, 2009 | Bernina Sewing Machines
Sewing Machines Logo
186 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
