(Electolux Dryer Model:T31200)Error Code E-17 Means what fault?
2 Suggested Answers
SOURCE: Bosch washer/dryer
I also have the same washer and same problem, and it is not due to clogged filters nor due to low pressure!
Any solutions so far?
I wish I had read these posts before buying it. :(
Posted on Nov 01, 2008
What is Error HI?
you didn't mention the model, but on the washer/dryer combo units, the H1 means the following:
Dryer temperature sensor error detected A fault has been detected with the dryer temperature sensor on washer dryer models.
  • Check connections to dryer sensor
  • Check temperature sensor
May 15, 2016 | Daewoo Washing Machines
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    What e54 error code mean on an electrolux dryer
    You have not specified Tumble dryer model so I can not say for certain that my answer is correct. Fault codes can sometimes vary depending on the platforms appliances because today some manufacturers release new models twice a year and thay have the absolutlly right to make changes and improve the efficiency of new appliances (also change fault codes).
    E54 - means the motor is inoperational.
    Could be:
    • Excessive wash load.
    • Voltage too low.
    • Motor/transmission system inoperative.
    Dado
    Aug 09, 2014 | Electrolux Dryers
    I keep getting error code F-14 on Hotpoint condenser dryer model CTD85
    Hi.
    F14 means that control board does not sense that machine is heating:
    F14 - A fault with the water heating has occurred
    When you get F14 the fault is usually either the thermistor or the heating element (electric dryer). Both parts are tested removing the part from the dryer and reading impedance at the part contact. If the part returns infinity, then the part is defective. If you need to contact a qualified technician use the phone number listed on your owners manual or check Hotpoint website.
    Regards.
    Ginko
    Sep 20, 2011 | Dryers
    I have a Maytag Neptune electric dryer model # MDE9700AYW and I have a fault code " FE " & the dyer doesn't dry the clothes. What is my problem
    Maytag Dryer and FE code means power source "Frequency Error".
    Invalid power... you will need a electrican to come out the power is not wired up right.
    I would replace the wall receptacle before buying any dryer parts
    Hope this helps (remember to rate and comment this answer).
    Jul 01, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
    OE Error
    The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
    LG themselves have some information on this error code..
    http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!!!!!!!!!!!!!!
    Jul 13, 2010 | LG WD-14124RD Front Load Washer / Dryer
    Whirlpool duet dryer error code pf
    The error code means that the unit suffered from a power failure.just make sure that all the wiring is good there is nothing loose and the circuit breaker is in good shape you should be able to turn off the dryer unplug it for a few minutes and the plug it back in this should clear the fault code.
    Feb 26, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
    Electrolux dryer error code e61
    There is a 'tech sheet' in the back pf the dryer. Unplug machine, Remove the access panel on the back to get to it. Reach in and it should be there. It will tell you how to do a button check. You have to enter a test mode through the buttons.
    The E 61 is a stuck button.
    Enter function test mode and perform key
    stuck closed (active). (button) test to determine which button is at
    fault. Carefully free the and perform the test
    again. If button is free but the key struck code
    still exists, replace electronic control.
    Sep 25, 2009 | Electrolux EIED55H Dryer
    Bosch washer/dryer
    Mar 27, 2008 | Washing Machines
    Washing Machines Logo
    35 people viewed this question
    Top Washing Machines Experts
