Question about Alba Televison & Video
MY ALBA TV SAYS NO SIGNAL EACH TIME i PLUG IT IN
MY ALBA TV SAYS NO SIGNAL? eACH TIME i PLUG IN THE CO-AX CABLE tHE AREAL ON THE HOUSE IS WHAT DO YOU SUGGEST i DO?
  • 67 Answers
Either the TV has lost its memory and just needs retuning; or your coax and/or aerial is stuffed.
Posted on Nov 20, 2014
tvtek
  • 1284 Answers
SOURCE: "No Signal" on ilo-26hd
Call Dish Network at 1-888-284-7116 and they can walk you through the remote program setup. Or you can look in the instruction manual for code searching using the DN remote control.
Posted on Feb 26, 2007
SOURCE: IT ELECTROCUTES ME
Danger Danger Will Robinson!!!! Extreme Danger. Your TV has a "Hot Chassis" and when you connect the TV antenna you are Short Circuiting to EARTH. DO NOT USE IT. Take it to a TV repair place. THIS IS LETHAL!! A fault has developed and now the set is "LIVE". BE Careful please this is NO JOKE.
Posted on Aug 12, 2007
  • 4 Answers
SOURCE: I have a 52
try checking your connectors on the back,if your using hdmi,try scart,if your using scart change the lead or try tv on component connection.
Posted on Jun 29, 2009
  • 53 Answers
SOURCE: I have a tv sky box in lounge and 2nd tv in a
Check first that the Co-Ax cable is firmly plugged into your SKY box in your lounge.
(I'm assuming that the carpet fitters did NOT put a nail thru your co-ax cable or pushed the cable onto any metal carpet grippers???)
If they might have done this accidentally, then, that's why it doesn't work!
Then make sure that the co-ax cable is plugged firmly into your second TV. Sometimes the central connector within the co-axial socket becomes loose and needs nipping back together with a pair of long-nosed pliers.
I'm assuming that you have plugged the Infra-red remote eye unit back into the second TV aerial socket - before you plugged the co-ax cable back in?
If you have, press the SKY remote to see if the Infra-red LED can be seen in the remote pod.
Finally, make sure that you have selected the correct channel number (or Input) on your second TV remote to select SKY.
Posted on Nov 18, 2009
roety
  • 585 Answers
SOURCE: Can not get the listings for the TV Guide to load.
Hi my name is Roety,
I can help you with your issue ,
The cable box signal is received from a round cable called coaxial cable. The guide is sent to the cable box through the coax cable. The HDMI cables sends the picture to the TV.
The Tv does not download TV guide listings , just the box does. That would be a cable company/box issue not a TV issue.
Some TVs have a built in TV guide for when you recieve signals from an antenna (not cable).
If thats what you are referring to don't bother .
Use the cable box guide .
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Posted on Dec 01, 2009
What is the best method when using your antenna amplifier. Installing close to the antenna, or close to the tv? I have rca outdoor antenna mounted in the attic.
What I would try is replacing the co-ax cable from the antenna with the best quality you can find (not cheap), and make it as short as possible, then connect the amp. to this, then use another length of HQ co-ax from amp. to TV or recorder (if you are using one). In my own set up, I have two aerial amps, one for TV, one for DVD recorder, to ensure the best possible quality signal to each.
Feb 23, 2016 | RCA Ant751 Outdoor Digital Tv Antenna
No signal
What model is the TV? Are you using a HDMI input or is it a standard CO-AX Antennee cable?
Jun 09, 2008 | Insignia IS-LCDTV32 32 in. Television
Do they make a adaptor that goes from coax to hdmi or video plugs
No - co-ax is used to carry a signal at RF level while HDMI is audio/video.
A co-ax socket can be replaced by any qualified technician
May 04, 2015 | Televison & Video
I was given a wharfedale tv with serial number DC0VZ0E0100D776M0175, Model:L15T11W-C, 15*. i have tried all sorts of aerial but it's not working. what can i do.
Hello there,
The manual is here to download if you haven't got one.
http://dl.owneriq.net/8/89b8a3a7-ee44-49f2-8749-43d5b3c6722b.pdf
Try and narrow down the problem yourself like .
Did it work ok at the precious persons house.
Is your aerial different from theirs ?
Did your aerial ever work on antheer tv.
Does it work with another Video input eg DVD palyer ?
Are you following the instructions for auto search Correctly.?
Is the aerial connector AND cable ok ? (unscrew the co-ax plug that goes in the back of the TV and check co ax) Coax is notorious for bad connectors. They need to be terminated correctly or no puicture no matter what.
The bottom line with aerials is height height height and direction. for good pictures.
Sep 23, 2014 | Televison & Video
My TV has only one place to connect a co-ax cable...there are no other hook ups
The adapter they sold you is wrong. You will need a device called an RF modulator. This box will have video and left/right audio input plugs and then the output will be co-ax to connect to your TV set. Radio Shack does have them, they run about $30. You will probably have to tell them what it is called because usually they do not have a clue. Just tell them you want an RF modulator part number 15-2526
Apr 17, 2013 | Televison & Video
My Gateway NV78 looses the wirweless signal if the computer is more than 10 feet from the router. Three other computers can pick up the signal anywhere in the house. Any ideas?
Well the internal antennas in net books are not that universally functional,depending on strength of signal etc ,your brand of pc is not that hot either,I have known a netbook to function differently even frome different points in the same room.
one thing you can do is take your pc apart and solder in a reverse polarity sma connector ,then use a piece of the smallest co-ax you can find(rg 174) or try a military -spec rg 174 co-ax.The only problem then is soldering it to the internal co-ax linking your wi-fi card to the internal intenna,you might even find just cutting this very thin co-ax gives you a better pattern but if you do solder it in you can then link an external omni-directional antenna to your pc and this migh give you a connection just to the strongest signal and not sniff out irrelevant connections you cant connect to anyway---good luck!
Davey Snake!
Oct 23, 2010 | Gateway NV7802U Notebook
No sound, no picture--apparently power not getting to the tv
do you mean ,,into the areal socket, then the co-ax connectoins are fautly is the fuse in the 3pin mains plug okay
Jul 07, 2010 | Sanyo DS19310 19" TV
I have a tv sky box in lounge and 2nd tv in a different room connected by a co ax cable. I need a desription or a diagram to get everything working. It worked prior to having a new carpet fitted and the...
Nov 18, 2009 | Televison & Video
Is there such a thing as a co-ax cable to input converters?
Before you go that far, realize that the cable itself may be the problem. Usually poor picture quality can be traced to poor cable connections. Also, another possibility is poor connections inside the tuner of the set. I assume that you are using a cable box. Some of the newer boxes have direct video connections which will connect as you describe. Check the condition of all of the cables and connectors before yo invest in anything.
Keep us posted.
Dan
Feb 17, 2009 | HP Expresscard TV Tuner For Windows Vista...
Denon AVR1602
I know the avr 1602 well....What exactly do you mean "I have my TV cable service wired to the Denon".....Do you mean the actual co-ax cable ?....
The denon is only able to switch raw video and audio signals.
What do I mean by that ?....IF you are running your co-ax cable from your cable company directly into the back of the denon, it won't work. The Denon has an AM-FM tuner, but not a video tuner ( channels 1-121)....If this is what you are doing, then you want to run it to your samsung first ( as long as the samsung has a tuner so you can change channels ).
If the samsung operates like an old VCR, whereby you can plug the cable company co-ax cable into the back of it, and change channels with the samsung, then that is what you must do. You would then hook up the OUTPUTS of the samsing to the VCR or DVD inputs on the Denon receiver. ( use DVD inputs on the denon if the samsung has optical audio out, and use an optical cable as well for better sound ).
You would then use the Denon for the sound, and hook up your TV to the Monitor out jack on the back of the Denon.
The Denon is like a big switchbox. You plug your DVD, VCR, Satellite, video game, or what-have-you into the Denon. Then you use the denon to route the signal to your TV for the picture, and the denon takes care of the sound.
Hope this helps, and remember to always follow your owners manual.......Rob
Mar 13, 2008 | Denon AVR-1602 Receiver
Televison & Video Logo
331 people viewed this question
Top Alba Televison & Video Experts
Robert Crombie
Robert Crombie
Level 1 Expert
 Grubhead
Grubhead
Are you an Alba Televison and Video Expert? Answer questions, earn points and help others
