Question about RISOGRAPH RP3700/3790 - 2-HI DENSITY BLACK INK, S4386
My rp 3700 keeps jamming. It is accepting too many pieces of paper. not sure what to do
  • preoffserv Dec 29, 2015
    It would pay to check your pressure pad assembly. If the small metal strip on the leading edge has worked loose or displaced, this will cause either multiple feeding or can cause sheet jamming. Also if the pressure pad is badly worn (hollow where the feed wheel rubs) this will interrupt the feeding as well. If in doubt it is worth replacing it, as they are easily removed and replaced. One other thing to check.... is the lever on the feeder, set to card and not paper? This can be easily forgotten when you switch from one grade of stock to another.
    New Friend:
  • 32 Answers
Risographs being high speed printers have the separation rollers which if dirty will pull more papers in. Clean the rollers well . Isopropyl helps.
Posted on Nov 29, 2014
Epson dfx9000 it gives me paper jam
My epson printer showed a paper jam light although no paper was visible.
I discovered my son had had a paper jammed and ripped the paper out and a tiny piece was jammed inside but was not visible easily.
***NO RESPONSIBILITY ACCEPTED FOR LOSS OR DAMAGE IF YOU USE THIS SOLUTION I USED TO FIX MY PRINTER*********
i cut an A4 sized square of cardboard from a cereal packet.
I inserted this instead of paper and attempted to use the feed paper button to eject the paper jam.
This did not initially work so as i kept pressing the paper feed button i forced the cardboard into the printer in the same direction that the paper feeds whilst printing.
The cardboard pushed the tiny piece of paper out.
Turn off the printer and then turn back on - you should find the printer now works.
I also found it helpful to clean the feed path and to try and keep dust from settling in the printer.
If it is in a dusty environment it helps to keep the printer covered when not in use - you can buy plastic covers for this or any large plastic will do but does not look as aesthetically pleasing.
Hope this has helped.
Oct 24, 2012 | Epson Office Equipment & Supplies
Canon pixma MP240: keeps flashing Error E3 paperjam but not paper can be seen inside the printer. Makes noises as though priniting but only puts blank pages through. If power is turned off and...
Hello thanks for using fixya
E3 error is mostly because of paper jam
. their may be small bit paper jam in side.
Even it feels that their is no any piece of paper inside the printer but actually it exist & inside of the printer makes paper sensor & its not function properly
To solve it
Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jan 28, 2011 | Canon PIXMA MP240 All-In-One InkJet...
On riso pr 3700 can not get the full image on landscape mode when I make a master
Maybe you meant model RP3700 ...
These questions may help to find a solution or at least a better understanding of your problem:
Have you set the paper size right?
Is the print drum capable of the desired imaging size?
Mar 31, 2010 | Riso RZ390 Duplicator
I keep getting a paper jam message but there is no paper jam. any idea????
There may be a piece of paper still stuck in the unit. If a paper jams in a printer, you should assemble the torn sheet and make sure all the pieces came out.
Forcing a jammed sheet out of a printer can damage the paper detect arm. This arm is usually near the platen (The roller the head prints against) to detect the paper as it passes.
Mar 28, 2010 | Canon PIXMA iP1600 Printer
Paper keeps jamming
try resetting by unplugging and then plugging back in, then make sure no paper is jammed in the rollers...make sure rollers are clean and they are not worn down, make sure your using the right type of paper.
Apr 05, 2009 | Canon imageCLASS MF5550 All-In-One Laser...
Riso 3700 - Error Code G064
1 Power  swich off/on
2 Open and close front cover twise
Mar 22, 2009 | Office Equipment & Supplies
Paper light will not go off
You may have a small jam or a piece of paper that is still inside the printer.  You may have to look for a smaller piece of paper.  I have had this happen to my laser printers before and it was because there was a plastic arm that is inside the printer that came loose during a paper jam and it wouldn't accept paper until I reattached the arm and then the printer would accept the paper.
Feb 02, 2009 | Brother HL-2040 Laser Printer
I have a rp-300 which just stopped printing its approx. 3 yrs old
first remove ink cartridge then check there is not any paper jam also check in back side of printer for paper jam.
then try if again problems then reset your printer to factory defaults.
Jan 05, 2009 | Partner Tech PARTNER THERMAL RECEIPT...
Open Questions:
See all RISOGRAPH RP3700/3790 - 2-HI DENSITY BLACK INK, Questions
RISOGRAPH RP3700/3790 - 2-HI DENSITY BLACK INK, S4386 Logo
162 people viewed this question
Top Riso Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marius Chiriac
paulfvincent
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
