Question about AEG Dryers
I have an aeg lavatherm tn 95570 When I have started tumbledryer it will just go through the program without the motor running. The belt is ok and the only thing I can think of is, that the capasitor
I have disassembled the back side of the dryer but I could not find where the capacitor was placed.
  • AEG Master
  • 5,323 Answers
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Posted on Apr 26, 2015
  • 7 Answers
SOURCE: AEG lavatherm T3
check to see if the air flow is not blocked on the exhaust
Posted on Jul 20, 2008
TheMobilian
  • 8220 Answers
SOURCE: AEG lavatherm condensor dryer error
Make sure the water is completely out of the catch pan.
Posted on Dec 15, 2008
SOURCE: AEG Electrolux Lavatherm 57800:
try cleaning the drum contact on the rear of the machine. It is a carbon brush that contacts the drum spindle. It can get covered in carbon from the brush.Remove the plastic cover containing the contact brush, clean out all carbon dust and lightly sand the drum spindle to remove any surface build-up and ensure a good electrical contact then reassemble.
Posted on Jan 01, 2011
SOURCE: how do I understand the dial on the dryer AEG lavatherm 335?
How do I change (DIY) the belt in "AEG Lavatherm 335"
Posted on Aug 13, 2011
SOURCE: I have AEG Lavatherm T-300-W
If it spins, it's your element...but if its your element, it could just be your thermal fuses...which can be repaired rather than replace the whole element which is very expensive. operations@handyman.co.za or www.handyman.co.za
Posted on Sep 02, 2012
Have mislaid the manual for AEG Lavatherm protex plus. Where can I find it online? Can't access the model number as machine set in.
User's Manual - AEG Appliances
www.aeg-appliances.ca/wp.../AEG_LAVATHERM-T65179AV-_manual_070913.pdf
LAVATHERM T65179AV Dryer - ... In the AEG webshop, you'll find everything you need to keep all your AEG appliances ... read this user manual carefully, in-.
AEG - Tumble Dryer user manual, operation instructions
www.usersmanualguide.com/aeg/tumble_dryer 4, Lavatherm 310 A; Instruction Manual - Product Number Code:607625125. 5, Lavatherm 310 w; Instruction Manual - Product Number Code:607625014.
[PDF]LAVATHERM 75280AC EN User manual - User Manuals
www.electrolux-ui.com/DocumentDownLoad.aspx?DocURL...pdf LAVATHERM 75280AC. EN User ... Thank you for choosing this AEG product. We have ..... Dry Plus. Extra Quick. Mixed. 3 kg. To dry cotton and synthetic fabrics,.
[PDF]LAVATHERM 76280AC EN User manual - AEG
www.aeg.co.uk/laundry/laundry/dryers/.../downloadpdf/?...User%20Manual... LAVATHERM 76280AC. EN User .... this user manual carefully, including its ..... Dry Plus . The wool drying cycle of this ma- chine has been approved by The.
AEG LAVATHERM 75470AH USER MANUAL Pdf Download.
https://www.manualslib.com > ... > AEG Manuals > Dryer > LAVATHERM 75470AH View and Download AEG LAVATHERM 75470AH user manual online. ... filter, er filters DISPLAY Symbol On/Off Dry Plus Reverse Plus Anticrease Buzzer Time ...
AEG LAVATHERM 65270AC USER MANUAL Pdf Download.
https://www.manualslib.com > ... > AEG Manuals > Dryer > LAVATHERM 65270AC View and Download AEG LAVATHERM 65270AC user manual online. LAVATHERM 65270AC Dryer pdf manual download.
User Manuals ' Service & Support ' AEG
www.aegaustralia.com.au/support/manuals/ Search for user manuals for your AEG products online with our finder tool.
manual for AEG Lavatherm protex plus Google Search
Jun 25, 2017 | AEG Dryers
I have a 14 yr old AEG 3200 dryer. The drum has stopped turning.Could this just need a simple belt replacement or wld you recommed a new dryer. Thanks
If you can hear the motor run when activated replace the belt. You should check or have checked the rollers that the drum is supported by. Check the belt tension-er replace if worn. While the unit is disassembled the rollers are easy to replace.
Vacuum all loose lint out from around the motor while disassembled.
These simple older machines are reliable and very durable and only have a few moving parts.
Hope this helps?
AEG LAVATHERM 60750225500 Tumble Dryer Section Spare Parts Diagram
Jun 21, 2017 | AEG Dryers
Why is my AEG Lavatherm TN 95479 running but the air is not getting hot
The problem could be heating element failure.
Sep 04, 2014 | Dryers
Lavatherm tn 55460
Sound like limit switches are tripping, and that could be because there is a lot of lint build up. Need to dis assemble and check the inside conditions.
May 19, 2014 | AEG Dryers
Lavatherm tn 55460 the program stops shortly after starting. All filters are clean.
Again sound like limit switches, machine needs to taking apart and inspected.
AEG Lavatherm 33600. I replaced the belt
the felt is to stop rubbing you can get it from a craft shop. I changed the felt bearing cover with a nylon type washer works better and now don't get static discharge when taking out the clothes. under a 5ver for the lot.
Sep 30, 2013 | AEG Dryers
Got new tmbledryer week old no digital display checked fuse on plug
Cheapest price search results for AEG T58840- Tumble dryer- Technical details, features, compare prices, AEG T58840 buying guide, reviews, tests, d and buy a AEG Lavatherm T58840 Electric Dryer from 419 at Deal Time UK.See images, features, check best price and 2 reviews and ratings by people who have bought this Aeg T58840: "A lot quieter than my old tumble pare prices for the AEG T58840 Washer d impartial reviews and buy online for speedy delivery only denser tumble dryer with Silent pare the UK's best prices for AEG T58840 and other Washer-Dryers from 100s of online shops.
AEG T58840 AEG Tumble Dryer Condenser, FREE DELIVERY, Buyers and Sellers offer the widest range of domestic appliances from top of the range to budget items at the most.7Kg Drying Load, Condenser Dryer, Sensor Drying, Large LCD scree, 20hr Delay rn everything you need to know about tumble pride ourselves on our customer service and the best prices on internet for the AEG Appliances Tumble Dryer Condenser Freestanding T58840 from BHS pare prices from across the web and read product reviews on AEG Lavatherm t58840 compare prices on Aeg t58840 from online T58840 Condencer Dryer- 7kg Load in White.
T58840: 7Kg Condenser Tumble Dryer in White: 433.97: AEG: T88840: 7Kg Condenser Tumble Dryer in White: 535.00: AEG: T35850: Vented Tumble Dryer: 264.97: AEG: Electric Shop supply AEG T58840 7Kg Condenser Tumble Dryer in White from leading manufacturers at discounted T35850 Vented Tumble Dryer- Special T58840 review, price comparison and where to buy online at Compare Store Prices UK for cheap T58840 White Freestanding condenser tumble T58840 Condenser tumble Price: 448.85.Tumble Dryer Models from AEG: T35850; T58860; T88840; T58840.
Aeg T58840 Condenser Dryer, read the latest user reviews and compare prices on Aeg T58840 Condenser T58840 review, price comparison and where to buy online at Compare Store Prices UK for cheap T58840 Condencer Dryer- 7kg Load in T58840 from Chantry Digital AEG 7kg Load Condenser Dryer with White T58840 Colour WhiteManufacturer AEG7kg Drying LoadCondenser DryerSensor DryingLarge LCD Screen20hr Delay StartCondenser duct information and details for AEG Lavatherm T58840 Electric AEG T59800 Dryer is in stock at several UK k the green box and well make sure that more people get to.
Find out more about the amazing AEG Lavatherm T58840 tumble dryer condenser in p with dryer hotpoint tumble problem on AEG T58840 Condenser Tumble Dryer Electric and free tech support for dryer hotpoint tumble d out more about the amazing AEG Lavatherm T58840 tumble dryer condenser in rything you want to know about the T58840.491.00: NEW AEG T58840- MANUFACTURE a better deal by comparing prices on AEG T58840 Washing Machines to save money online and guarantee Christmas T58840 3) Tumble Dryer Spares and T58840 3) Parts- Page 2- Belt, Door, Drum, Filter, Seal, Heater, Hose, Knob, T58840 Tumble Dryers Condenser In White Aeg The number one appliance specialist in the UK.
Condenser Sensor dryer
Large LCD Display
Sensitive Option, Leisure Programme
21 programmes including Microfibre, Jeans, Bed Linen
Easy Iron, Extra Dry, Storage dry, Hand Iron
Machine Iron, Intensive Dry, Extra Dry, Wool Care etc
Large 36cm porthole opening
Interchangeable door hinge
Manual timer up to 40 minutes
Stainless steel drum with Internal Light
Drum Light
please comment on these on how helpful.
Dec 21, 2010 | AEG T58840 Dryer Electric
AEG Lavatherm 58800. Errors E54 - the motor cannot turn the load (but very little loaded) E51 - door suddenly opens
Hi if the drum is not stiff and runs free and the motor is energised but not powerful enough it can be thr start capacitor located nearby the motor. its a small cylindical silver can rated at 8 microfarads (125 00 20-33/4 approx £8.50 .) You cant measure it the best way is to try one known to be good. If its not that it is more likely to be the electronic board. You can look for cracked soldered joints and resolder (lead free solder) otherwise its a new electronic.hope this helps
Nov 19, 2010 | AEG T57800 Electric Dryer
Squealing noise on start up drying still works
This dryer needs to be taken apart to lubricate any and all moving parts. Idler pulley and rollers, if they are worn out in any way, replace them.
Also, consider a new belt.
Nov 16, 2009 | AEG T58840 Dryer Electric
How do I understand the dial on the dryer AEG lavatherm 335?
it should show a full sunshine for high and half a sunshine for low
Jun 23, 2009 | Dryers
Dryers Logo
303 people viewed this question
Top AEG Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Gaark
Are you an AEG Dryer Expert? Answer questions, earn points and help others
