Question about Hitachi Gst Hitachi Cpx3021wn Hitachi Cp-x3021wn Lcd Projector
I have a Hitachi CPX3021WN projector I rarely use and a few days back when I put it on there was a large pinkish purple blob on the screen. This blob starts from somewhere in the mid lower area and th
I have a Hitachi CPX3021WN projector I rarely use and a few days back when I put it on there was a large pinkish purple blob on the screen. This blob starts from somewhere in the mid lower area and the size increases and goes to the upper middle edge of the screen. Is there any way to rectify this?
    Sergeant:
    Champion:
  • 282 Answers
It sounds like there are some magnetic fields around your projector. Similar to what used to be degaussing in an older tube TV. Sometimes it may be that the speakers are to close to the projector or even the earths magnetic field that may be effecting it. Try turning the projector in a different direction and see if that helps your problem.
Posted on Nov 20, 2014
Testimonial: "I have tested the projector in my office and residence, and there are no speakers near it. Is there any other way to rectify this?"
Purple spot which goes larger and stays on the boundaries of the display All text displayed has purple shadow
light chamber is over heating. when they do this you need a new chamber. I did find out that you can bring it back but you need heat tape. take the cover off and you will see the chamber. find were it is out of line. have it switched on and a good range rang on the screen and push the side in if the lines go back into place that is were it needs the tape putting. keep it on for a while to get the area warmed up. when hot put the tape on and make sure it stays in place. on the screen out. heat tape is the tape with silver cover on it use a few strips on top of each other. also clean the fans out. they get coated in dust and this is how the chamber over heats.
Sep 10, 2013 | Hitachi Projector lamp - for ED-X50,...
I have a Hitachi CP-S240 projector. It works fine but now projects a yellow blob on the screen. It looks as if someone took a highlighter and colored on the lens - I cleaned the lens and that is not the...
I work for a company where we take care of around 7,000 projectors. We have recently come across this same issue in this model and several other Hitachi models. We have figured out that it seems to be a main board issue, after testing and checking of the lenses and other things. The main board ended up being the fix. Hope this helps!
Apr 12, 2011 | Computers & Internet
Have changed the bulb because of yellow blob on the picture and it has made no difference
the yellow blob is from a fried polarizer on the blue lcd panel due to excessive dust and heat. you'll have to replace it, but hitachi doesn't sell individual optical engine parts, so you may have to replace the whole optical engine.
Jan 18, 2010 | Hitachi CP-X440 LCD Projector
Sony KF-50WE610 Power Standby light blinking and will turn on seemly randomly for a few seconds with sound and display the shut off and begin blinking again. A purple blob appeared a couple of days ago in...
Sounds like lamp is going out, if when you get lamp replaced, you can do it yourself, the purple blob is still visible, call Sony this may be one of the sets that have an extended warranty on the light engine.
Aug 10, 2009 | Televison & Video
lamp has probably gone out, but, if when you replace lamp purple blob is still on screen then light engine is bad, need to call Sony and see if is on extended warranty.
Greenish/Yellow spot
Sounds like a scorch mark on the polerising filter, this can only be replaced by an engineer cost around £70 ($150).
Marc Engineer
Apr 05, 2009 | Mitsubishi LVP-X300 Multimedia Projector
Yellow circle
there is a light filter on the blue lcd panel that is fried due to excessive dust and heat. unfortunately, you'll have to replace the entire optical emgine.
Nov 21, 2008 | ASK Proxima DP6860 Plus Multimedia...
Screen
Sounds like you LCD has gone bad... Its like a calculator LCD when you press down on the screen of it it get like a blob. My projector also has done this... Half of the screen is all blue
Sep 06, 2007 | Hitachi Performa CP-RS55 Multimedia...
Dark piece on screen using JVC DLA-SX21
Can any1 help me with this problem...i have a purple blob in centre of projection screen.
is this a burn mark on the lens..maybe due to over use?
Any input would be great!
Aug 20, 2007 | JVC DLA-SX21 Multimedia Projector
Philips 28PW6515-05 flat screen TV
You have a bad connection on the CRT board thats mounted on the end of the picture tube it sounds like, or the socket on that board that plugs into the TV set is intermittant or has a bad solder connection on it. Good Luck
Mar 27, 2007 | Philips 28PW6506 28" TV
Hitachi Gst Hitachi Cpx3021wn Hitachi Cp-x3021wn Lcd Projector Logo
140 people viewed this question
Top Hitachi Gst Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Hitachi Gst Office Equipment and Supply Expert? Answer questions, earn points and help others
