Hello my Samsung automatic washing machine let's the water out as soon as I let it in. What can be wrong?
  • 34 Answers
I'm assuming it's no longer under warranty. We bought a new Samsung front loader. and even the factory rep couldn't get the dam thing to work right, so we swapped it back to Home Depot for a GE top loader. I'm thinking yours has a bad sensor, but I really have no idea where you should look. Sorry!
Posted on Nov 20, 2014
  • Jaco Lindeque Nov 20, 2014
    I put the outlet pipe higher than the machine and now the water is not running out anymore
  • TheQuartermiler660 Nov 23, 2014
    You may want to check out a website called "appliance guru"
2 Suggested Answers
  • 423 Answers
SOURCE: automatic washing machine plumbing requirement
The automatic clothes washing machine counts on a pressured water system - like what is provided in a town / city or from a well that has a pressure system to deliver water at pressure like when you open a valve for a bath tub, sink or shower.
You need to have a plumber provide valve/faucets for both hot and cold water. The valves are sometimes called a "hose bibb" with a threaded end that the hoses connect to and then are connected to the back of the washer. When the hoses are connected and the valves are open, the automatic washer will open a solenoid valve when the time is right to allow water to flow in, then closees. Some owners keep the hose bibb valves open forever after they connect the washer, others close the valves after they are done washing all loads for the day/week.
You will also need a drain provided that connects into the house plumbing. The Whirlpool Duet provides the drain hose from the washer which drops into the pipe the plumber provides. It is important that the drain pipe allow air to move past the washers drain hose, to allow proper draining.
Hope that helps. Please post back how things come out, OK?
Posted on May 21, 2010
Hi i have a 5.0 kg. samsung SW5OUSP washing machine as i turned it on it stopped in rinsing cycle and the message says 5E
5E. Water Drain Error.
5E is displayed if the water level frequency detected os 25KHz or less in the initial phase of the UNB - detecting cycle. The WATER DRAIN ERROR
can be rectified by turning the POWER SW OFF AND THEN BACK on.
Hope this helps you
Feb 01, 2012 | Samsung Washing Machines
I have samsung front loading f843 washing machine, when i start the inlet water and select the programs Cotton > 800 RPM > Prewash / Rinse / rinse hold, the water starts coming out automatically and...
SORRY but when you add additional water from a hose you are defeating the machines function .get the machine properly repaired by a repair service is all I can suggest .
Sep 20, 2017 | Samsung Washing Machines
While moving my samsung top washing machine, I think my drain hose pipe has moved down the water level. Now machine is not able to retain the water while washing/soaking. I need to pull the drain hose pipe...
Although a few modern washing machines can operate with the drain pipe at any height, most machines will drain the water as soon as the drain pipe is placed below the machine water level.
The simplest solution for your problem would be to ask somebody with some handy man skills or hire a plumber to add a 2 inch PVC pipe to your drainage pipe which extends to a point behind your washing machine & then points upwards, making sure it is long enough to be at a higher point than your machines fullest water level.
This should be a relatively inexpensive alteration & will ensure that water does not drain unless the machine is on its drain cycle.
Please let me know if you need any further assistance.
Best wishes,
Graeme
Mar 10, 2011 | Samsung SW62ASP Top Load Washer
Dear sir, I bought top loading fully automatic
you can contact appliancerepairplanet.vstore.ca for help in this matter
Dec 08, 2010 | Samsung Washing Machines
Water supply hose(cold) blocker dont work
i am sameer from india... i want whirlpool fully automatic washing machine pcb circuit diagram
Jul 28, 2010 | Samsung Washing Machines
I need a manual for WA13UP Top load(samsung) washing machine
water running out at the draining pipe the while the machine fill itself with water
May 04, 2009 | Washing Machines
Model no wa80b3 samsung washing mashine
My washing machine is Samsung Top loading Model WA80B3, the problem is that the water inlet valve is continuously working all the time during the washing cycle and it does not stop automatically, so I have to run additional drying cycle after washing cycle and after closing the water supply manually
May 02, 2009 | Washing Machines
Kenmore washer not draining water
check for defective lid switch or switch just out of adjustment.
Aug 24, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
