Question about Microsoft Computers & Internet
The power LED is on , but the notebook PC does not power on
  • Jack Denton Jr.
    Jack Denton Jr. Nov 22, 2014
    are you comfortable taking the ram out? First, unplug it, then take the battery out, turn it back over push the power button down and hold it. Remove the ram then turn it back over push the power button down. then insert 1 ram stick, plug it in with no battery. If it comes on turn it off and swap the other ram stick, and try it again. If this also works, turn it off put it back together with no battery,plug it in and turn it on. If it works turn it off and put it back together.I either ram stick doesn't work that stick is bad just leave it out and order a new one. if none of this works your computer needs a serious repair. My email is jack.jr2012@yahoo.com
    New Friend:
  • 13 Answers
Need more details, like model #
Posted on Nov 21, 2014
Testimonial: "it's hp elitebook 2540p"
  • nosa alattar
    nosa alattar Nov 22, 2014
    dear Jack,
  • nosa alattar
    the model # is hp elitebook 2540p
My notebook shows no sign of power
Remove battery turn the notebook on, does it works?
press the battery back in place, is there any lock on backside op the notebook?
is there any signs of charging? flashing led or so?
if not the internal plug to the power supply could be damaged.
Mar 24, 2016 | ASUS X200CA Black 11.6" Notebook 1.5 GHz...
How do i fix a problem of green power led continuously blinking in Hp compaq nc6320 laptop even when the battery is removed and the motherboard is outside the case?
HP Notebook PCs - Troubleshooting LED Blink Codes or ...
h20564.www2.hp.com/hpsc/doc/public/display?...na...
Hewlett?PackardHP Notebook PCs - Troubleshooting LED Blink Codes or Beep Codes During Startup or Boot ... HP Pavilion and Compaq Presario notebook computers built in 2009 or later use blinking LEDS to identify ... Press the power button to turn on the computer, and look for blinking LED lights on the keyboard. ... Continuous blink.Missing: green ‎nc6320
HP Notebook PCs - Computer Does Not Start and Emits an ...
support.hp.com/us-en/document/c01732674
This document pertains to HP and Compaq notebook computers. .... light next to thepower socket or the light on the AC power adapter and note its condition: off, blinking, or constantly on. ... Battery power LED off, and Caps Lock/Num Lock off.Missing: green ‎nc6320
HP 6735s won't boot, power LED blinks 7 times - HP ...
Feb 03, 2016 | HP Computers & Internet
My laptop is not powering on help
1.Connect the Ac adapter to a known good power outlet. Check the Power LED indicator on AC adapter (without plugging into the Notebook). We are only checking the power AC adapter to see if that is working.
2.If LED on the AC adapter is not lit (when unplugged from notebook), reseat the AC adapter brick and cable. If still there is no light on AC Adapter replace AC adapter and Power cord.
3.If LED on the AC Adapter goes off only after connecting to Notebook, the issue is with the motherboard. Replace Motherboard, DC-In port (AC adapter connector).
4.If the AC Adapter LED is always ON, take a technician's help and reseat the Power Button Board. You can refer to the Service Manual for details on how to reseat the Power Button Board. (NOTE: Before the notebook chassis is opened ensure all the power connections including battery and external devices are disconnected)
Jun 07, 2014 | Dell Inspiron Laptop 1440
Can noy ged moden check shows working t wireless to work ethernet works an- looking for button to turn wireless on . Lookig for actual button to turn wireless on. Do not know where it is at - Thank You
The location of the Wireless ON/OFF switch is on the right hand edge side of the Notebook. Please see image below, it is No. 8
moz-screenshot-2.pngPlease let me know if the information provided has been helpful.
11997_ov.gif 1. Easy Access Buttons (5) 2. Stereo Speakers 3. Touch Pad On/Off Button LED 4. Fixed Optical Drive 5. Touch Pad 6. Primary Battery 7. Wireless LED 8. Wireless On/Off Button 9. Battery Charging LED 10. Hard Drive Activity LED 11. System Power LED 12. Mute Lock LED 13. Volume Controls 14. Headphone 15. Audio In 16. 1394 Port 17. PC Card Slots (1) 18. RJ-11 (Modem) 19. Air Vent 20. Kensington Lock 21. Power Button LED 22. Caps Lock LED 23. Num Lock LED 24. Keypad LED
Aug 20, 2010 | HP Compaq nx9030 Notebook
I have a hp 6735s laptop. Its just out of warranty. When plugged into the mains adapter it is no longer charging the battery. This means it only works when plugged in. Have i inadvertantly set the...
best way is to just try out the battery on another laptop, or try another battery on yours. If the laptop is not very old, and I suppose yours isn't more than 2 years old, your battery shouldn't be dead.
Aug 16, 2010 | HP Compaq 6735s Notebook
My acer Notebook Does not switch on
Well you can reseat the RAM and check if that does not fixes the issue, it could be an issue with the system board . You can contact Acer support line, if the unit is under warranty you can have system board replaced.
Jun 29, 2009 | Acer Extensa 5420-5687 Notebook
HP DV2036ea i have a blank screen on the computer
Hello there
Description.
When pressing the notebook power button nothing is displayed on the screen or display. The cause of this problem may be a failed AC adapter, the memory modules (RAM) need to be reseated or a failed notebook system board component which will require an HP certified repair.
Below steps will assist in identifying the cause of the problem and suggest the best solution. Test the AC adapter Follow the steps below to determine whether the problem is related to the AC adapter or your notebook system board.
  1. Remove the battery and disconnect all external devices from the computer.
  2. Hold the Power button for several seconds, with all power sources removed. This drains residual power from the system, and may correct many problems.
  3. Connect the AC adapter to a wall outlet and plug the other end into the computer.
  4. Press the Power button to start the notebook PC.
If the notebook does not start or the display is blank then check the power indicator light or power socket LED. Check the power indicator light or power socket LED On newer models of notebook PCs, there is an LED or indicator light around the power socket on the notebook. Check to see if this light is on or off, when the notebook is plugged into AC power.The power indicator light or power socket light should turn on when the AC adapter is connected.
  • If the light does not turn on then the problem is most likely related to the AC adapter or the electrical source in your home or office. Go to the Light does not turn on section on this page.
  • If the light does turn on but the notebook does not start or the there is a blank screen then continue to the Light does turn on but the notebook does not start section on this page
The light does not turn on when the AC adapter is connected If the power indicator LED is off, the AC power adapter may need to be replaced. To determine if the AC power adapter needs to be replaced follow the steps below:
  1. Ensure that the AC adapter is plugged directly into a known working wall outlet.
    NOTE: To check the wall outlet, plug in a different known working device like a light, radio etc.
  2. Check all of the following connections:
    • The connection from the power cord to the wall outlet.
    • The connection into the power adapter from the power cord.
    • The connection from the AC adapter to the notebook power socket.
  3. Press the power button again to test the notebook PC.
If the power indicator light still does not turn on, then the AC Adapter needs to be replaced. Contact HP Service and Support for further assistance. Power socket LED or power indicator light is on but the notebook does not start If notebook power indicator light (LED) is on, the AC adapter is working correctly. The problem is a result of a hardware failure in the notebook itself. In some cases, reseating the memory module (RAM) may solve the problem.
Feb 02, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
On HP 530 notebook battery/power indicator is always on as long as battery is connected and even when ac power is connected the situation is still the same.
Clarification of your battery/power led indicator:
Solid amber:
Battery is charging at 0% - 89% capacity
Solid green:
Battery is charging at 90% - 99%
Blinking amber:
Battery is low
Led is of:
Battery is charged
Dec 04, 2008 | HP 530 Notebook PC
Computers & Internet Logo
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
