Question about Health & Beauty
Assembly instructions for Afikim Sportster Porter
The motor is turning but the wheels arent moving could it be the gears are disengaged or a problem with the transaxel??
hi Delores , you need to make sure the coupler that interfaces the gearbox to the motor is not broken, if that's okay then must likely the motor worm interface gear is spinning across the main Drive worm gear, I can engineer new worm gears but they can be costly, cheaper than a new transaxle in most cases ...
Regards
Rob
Dec 19, 2015 | Afikim Sportster SE
Motor is turning but wheels arent moving could it be the gears or transaxel
Hi Delores , you need to make sure the coupler that interfaces the gearbox to the motor is not broken, if that's okay then must likely the motor worm interface gear is spinning across the main Drive worm gear, I can engineer new worm gears but they can be costly,cheaper than a new transaxle in most cases ...
Regards
Rob
I need an afikim breeze 4 wiring diagram, speedometer quit and cant figure it out.
hi Tami, it 's a mini circult board , just make sure the cables to this board are a good connection, sadly that board will need to be replaced...if there is no improvement ...
Regards
Rob
Nov 03, 2015 | Afikim Breeze S 4-Wheel
Can I get a rplacement key please?
Have you tried your local key cutting service first if you have a key to copy. Failing that you will need to contact the scooters manufacturers or service centre to obtain a key.
Mar 19, 2015 | Afikim Sportster SE
Need kobalt work bench assembly instructions
I have been repairing compressors major brand Rol Air, Dewalt, Porter Cable, Jair, Jenny, Emglo, etc. and find, even with major brands,very limited information on assembly instructions. I havent seen any material on Kobalt, however find that their compressors are very much like the oil-less from cambell hausfeld, dewalt and porter cable. Parts are available on the net. The major problem that I see is that there is no easy / reliable way to install the drive belt. Without proper procedure or tools, the belt will tear. For the most part, you are on your own to experiment on repairing them. You can re-post a specific question on the Kobalt and I will try to answer. Good luck.
Nov 10, 2012 | Air Tools & Compressors
Where do I find the wheel kit assembly instructions - I cannot find them in any of the books
You have an axle, some washers, the wheel/tire assembly and a cap for the axle. Slide the axle through the frame and out the other side. place a washer on each end and the place the tire/wheel on each end of the axle. Put a washer on each end of the axle and then hammer the cap on the end of the axle to secure the wheel in place.
Aug 27, 2011 | Porter Cable 4,500 Watt 9 Hp Portable...
We have lost the instruction manual for a TGA mobility scooter. The numbers on the scooter are 991186017 and also, AFIKIM Electric Vehicle.
If you contact TGA 01787 882244 they would be able to provide you with a manual, it is chargable though.
Jul 15, 2010 | Health & Beauty
Porter/Cable 15 gauge angle finish nailer
The driver assembly can sometimes get bent or the tip can get a little deformed causing it to hang up in the nose. Other than that, not much else it could be if you rebuilt the whole thing
Dec 31, 2008 | Porter Cable 16 - Gauge Finish Brad Nailer...
Health & Beauty Logo
46 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
