Question about Canon Office Equipment & Supplies
Hi, stationary jam indication with no error code in canon irc3170; why it shows like this. Can enybody help me.
    Sergeant:
  • Canon Expert
  • 224 Answers
Check paper pice in the paper feeding unit and chech p f unit sensor switch may be broken
Posted on Dec 01, 2014
Cogz
  • 1326 Answers
SOURCE: Code E-000004-001 on Canon IRC3170???
You have to get in to service mode. Press the "*" botton once then the numbers "2 & 8" togather, then the "*" botton once and the screen changes. On the top of the diplay touch "Funcation" then "CLR" 2nd colum 3rd one down, then press "ERR" hi light it in blue then press the "OK" on the bottom right of the screen and turn the main power switch OFF on the right side and see if it was cleared. If not you may have a bigger problem.. Good Luck...
Posted on Dec 13, 2008
Ajkill
  • 2035 Answers
SOURCE: E3 error code
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Jan 31, 2009
SOURCE: canon mp600 printer repeated error code 6B00
After reading through earlier problem fixes, I inserted a piece of Card right through the feed system then taped all the covers and loose paper feed trays closed with masking tape. Picked the whole unit up, turned it upside down and shook it up and down and side to side quite hard. Put it back in place on the desk, undid all the tape and plugged both cable back in and switched it on. It went through a long startup process, spat out the card sheet and has worked OK since then (about 15 sheets printed).
Thanks for all the ideas in earlier fixes.
Posted on Nov 13, 2009
pineworks
  • 4041 Answers
SOURCE: canon pixma ip1980 service error 6000
Hi there
You can try this may help you.
These are the steps:
1. Turn On iP1980
2. Push and Hold Resume button about 2 minutes
3. Release Resume button
4. Printer back to normal again
To get Permanent , follow the steps here :
Manual Resetter canon Pixma iP1980/1900 Download
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 07, 2010
SOURCE: Canon GP 405 print error
please give service code of canon gp405
Posted on Mar 22, 2011
When I turn on my Canon iRC3170 I receive an error code E0748 - 4150. What is wrong?
I have a Canon iRC3170 photocopier, when it is switched on it shows this error message E0748 - 4150. What is wrong? Thank you.
Mar 13, 2014 | Xerox DocuColor 12 Printer
Canon irc3170 errror code 0020-01a8 how can i rectify?
this is error code for atr sensor's reading. Probably on sensor there is toner dust so he can't read the true value. It needs to be cleaned or replaced.
Call service.
Also this error can occure if the developing clutch is rotate constantly, so he is stiring out too much toner.
Aug 21, 2011 | Office Equipment & Supplies
Erro 6A00
The 6A00 is a Canon code for paper path jam. In the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 .
The purge unit is stuck and not able to move freely .Move the purge unit back and forth for around 10 times and then restart printer ,it should work fine .
If you still get the error code then purge unit needs replacement.
Hope this helps .
Mar 27, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Error 6A00 code showing. Tried to use printer, this code was showing on display panel. Tried turning off and resetting. checked for any paper jams...none. Checked ink cartridges and there doesn't seem to...
Hi there
This answers with a titch more detail.
The 6A00 is a Canon generic code for paper path jam.
Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move.
Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
And yes I have found all those things in a purge unit.
The offending item needs to be removed or the purge unit needs replacement.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model.
And it’s always a paper path error or purge unit.
The purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Also clean the purge unit out make sure all is clean.
Mar 01, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Hi, our Canon mp830 is showing an error code of 6A00, could you please confirm that is it a Paper Feed sheet error, any ideas of how to fix this problem. Thanks
Hi
Error 6A00
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Nov 29, 2009 | Canon MP830 All-In-One Printer
What does 6A60 error message indicate and how do I resolve on my Canon MX700 all in one machine.
6A60 error is an APP (Application Printer) position error. It means that an error has occurred when the motor was running during the purging operation on start up.Check the sheet feeder and purge unit.Sometimes pieces of paper stuck in purge unit.
Thank you!
Nov 02, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Paper has jammed showing error code 0000064 and inform to restart
canon3000 err code 64 restrt machine 10 to20 copy after code please help me
Dec 16, 2008 | Canon MF8180C Color Laser MFC Printer
PRINTER ERROR CODE 6A00
Hi
Good Luck
Solution 1:
Solution 2:
Solution 3:
Jun 23, 2008 | Canon Pixma iP6600D InkJet Photo Printer
Eo-10 code
hi im jules_09,no the copier is not dirty or jammed,if there is a paper jam it will indicate paper jam there is no error code for that,if the copier is dirty you can see it in the print.reset the error code in the program,if the error code is still there checkfusing unit then the optic sensor
Nov 02, 2007 | Canon PC-940 Black and White Copier
41 people viewed this question
old marine
old marine
