Question about Samsung SCX-5635FN All-In-One Laser Printer
HOW I FIX THIS PROBLEM
PULL BLUE LATCH FORWARD
    New Friend:
I think go through the http://income.com/2854/how-to-create-a-website/ , I hope this will resolve all your problems.
Posted on Nov 20, 2014
Testimonial: "MY PROBLEM THE PULL BLUE LATCH FORWARD"
My Bosh SHX7ER55UC door won't latch. Trying to figure out the 2-screwdriver method but can't figure out what part to push/pull.
HOW TO FIX YOUR BOSH DISH WASHER DOOR LOCK ...
? 11:11
https://www.youtube.com/watch?v=_uPK5mJmvZM
Jul 23, 2013 - Uploaded by Andrew Wallace
Dishwasher Door Latch (part #W10275768) - How To Replace ...Dishwasher Door Latch Replacement - Bosch DishwasherRepair (part ...
Nov 29, 2015 | Bosch 800 Plus SHX7ER55UC Fully Integrated...
Can't get our hood open
Hood latch or cable is frozen up (rusted). These can be a challenge to get fixed, because you don't have access. You can try to see if you have access through the front grille or go under the car and look up for the latch. Hopefully you can get to the latch and release it. My worst one was a mid 70s Corvette with the latch by the windshield (hood opens forward). This latch was above the cowl assembly and you had to work around the engine. Good luck...
Nov 11, 2011 | 2001 Ford Focus
How do you take out third row seats
Follow the numbers on the latches. Step one fold the seat back forward. Step two fold the seat bottom forward. Step three pull the latch marked three towards you while pusing the seat away. This will allow the seat to disengage from the track and you can wheel it towards you and then lift it out of the truck.
May 14, 2010 | 2003 GMC Yukon
I have a 2005 Pontiac Sunfire. The trunk will not lock/latch. When I have the trunk lid open, i can get it to lock with my fingers but cannot get it to latch when it is shut, how do i fix it?
Mine also had this problem within the first few months of ownership. I took it to the dealership and they said it was a "known issue" with the latching mechanism. They used some type of tool to pull the latch forward and it worked like a charm. It was free of charge at a Pontiac Dealership. Hope this helps.
Mar 31, 2010 | 2005 Pontiac Sunfire
Need instructions on how to install a HP 6110 Cartridge Return Belt. The belt came off but does not appear to be broken.
Hello HP 6110 Cartridge
Issue : installing Cartridge on HP 6110 Printer
Printer :Desk jet HP 6110
Analysis : it seems that you are trying for Replacing the print cartridges
Solution : Please try the following steps to replace which is very simple and easy. The most important part is to understand and then apply without fear..
1) Turn on the power of the printer
2) Lift the print carriage access door on the front of the unit
Observe : the print carriage will move into the middle of the access area.
3) Release the cartridge to be replaced by pressing down lightly on the top of the carriage latch (You Need to Press Of force Single finger on the top of the Carriage Latch) and then pulling the lower section of the latch forward. Lift the latch.
4) Grasp the sides of the ink cartridge and pull the cartridge out to remove it.
5) NOW by
Holding the cartridge with the printed label up, slide the cartridges, one at a time, into the print carriage.
Insert the black print cartridge (HP 56) into the right side (with the gray latch) and the tri-color print cartridge (HP 57) into the left side (with the blue latch).
6) Latch the cartridge by pulling the lower section of the latch forward and pressing the latch down. When the latch is down, release the lower portion of the latch so that it catches under the tabs. Do not use force or damage might occur.
7) Close the print cartridge access door..
Now check the by running a test print
Click Start , click Settings , and then click Printers .
Right-click the all-in-one print icon and click Properties
On the General tab of the Printer properties, click the Test Page option.
Try the above steps hope the best out of it
Happy new year
Jan 02, 2010 | HP OfficeJet 6110 All-In-One InkJet...
The latch to my 2000 passat is broken. I guess I pulled too hard on the t-bar; it broke off. There was another little plastic piece that fell out too, but both pieces are not craked or broken. I tried a...
Yep you need to pull forward. The latch on those was made wrong. You shouldn't have to pull it forward to open. Use a light and see if you can find the cable to pull on, with maybe a long nose pliers?
Dec 17, 2009 | 1998 Volkswagen Beetle
I need to remove/replace cartridge,i dont know how?
Hi!
This link guides you on how to replace the cartridge:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00004340&lc=en&dlc=en&cc=us&product=79477
  1. Turn on the power.
  2. Lift the print carriage access door on the front of the unit, just above the output tray. The print carriage will move into the middle of the access area. Figure 1: Raising the front access doorc00004385.jpg
  3. Release the cartridge to be replaced by pressing down lightly on the top of the carriage latch and then pulling the lower section of the latch forward. Lift the latch.
  4. Grasp the sides of the ink cartridge and pull the cartridge out to remove it. Figure 2: Removing the cartridgec00004386.jpg
  5. Remove the replacement cartridge from its packaging. Touching only the black plastic, remove any tape covering the nozzles. Do not touch the gold-colored contacts. Figure 3: Removing the protective tapec00004387.jpg
  6. Holding the cartridge with the printed label up, slide the cartridges, one at a time, into the print carriage as shown below. Insert the black print cartridge (HP 56) into the right side (with the gray latch) and the tri-color print cartridge (HP 57) into the left side (with the blue latch). To install the optional photo cartridge (HP 58) for six-ink photo printing, remove the black print cartridge (HP 56) and insert the photo cartridge (HP 58) instead. Figure 4: Inserting the cartridgec00004388.jpg
  7. Latch the cartridge by pulling the lower section of the latch forward and pressing the latch down. When the latch is down, release the lower portion of the latch so that it catches under the tabs. Do not use force or damage might occur. Figure 5: Latching the ink cartridges in placec00004389.jpg
  8. Close the print cartridge access door. Figure 6: Closing the access doorc00004390.jpg
  9. A message will appear in the front panel display requesting that the ink cartridges be aligned. Press Enter to start the cartridge alignment. Two pages will print. Following the instructions printed on the second page, place the first page on the scanner glass in the lower-right corner and then press Enter to finish aligning the cartridges. Remove the page from the scanner glass when complete.
Nov 23, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Door won't close/lock
Just had the same issue. The latch, which rotates up and forward, is spring-loaded towards the rear. If 'tripped' to closed position, it cannot rotate back down until it's carrier/hinge slides slightly forward. I bent a sturdy wire into a long 'U', then bent both ends down (~3/8in) and slightly outward to hook over the latch-hinges and pull both sides gently (its plastic) forward, while rotating the latch downward with a small screwdriver. be careful to keep what appears to be a brown plastic button raised, if it pops down from above the latch. Yes, having 4 hands would help, but the 'U' wire can pull from behind the two outer edges with one finger. Once the latch rotates down, release tension on the 'U' wire and extricate it - problem solved.
Jon (We don need no steenkin manuals)
'Build a more idiot-proof machine, and the universe will build a better idiot.'
"We don't take no s*** from no machines."
Colonel Jason Grant (Walter Koenig), Moontrap 1989
May 02, 2009 | Samsung WF337AA Front Load Washer
Tailgate on teh 2001 Chevy Siverado will not open,
Remove the molding surrounding the latch (gently) with a screwdriver by prying away from the tailgate. Remove the bolts from the tailgate on the backside of the latch assembly. lightly pull the lever assembly forward, but do not try to pull it out. The rod that came loose will be in the general area of the lever assembly. Most likely the retaining clip to the rod came off.
Feb 26, 2009 | 2005 Chevrolet Silverado
Samsung SCX-5635FN All-In-One Laser Printer Logo
103 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
