PULL BLUE LATCH FORWARD
EVERY TIME IN OUR PROBLEM PULL BLUE LATCH FORWARD
2 Suggested Answers
et59232
SOURCE: HOW I FIX THIS PROBLEM
I think go through the http://income.com/2854/how-to-create-a-website/ , I hope this will resolve all your problems.
Posted on Nov 20, 2014
Testimonial: "MY PROBLEM THE PULL BLUE LATCH FORWARD"
The trunk release lever will not open the trunk. the trunk will open when the key is used but not by the release lever.
So, when somebody else pull the cable, do you see the latch move back and forward from the trunk? There is nothing complicated about a manual cable, it just pull the cable and there should be a reaction to it. If there is no action from the latch, no movement at all, then the cable is just broken. If there is a little movement, not enough to pull the latch to open the trunk, you still need to replace the cable.
Sep 28, 2015 | 2002 Kia Spectra
Nov 20, 2014 | Samsung SCX-5635FN All-In-One Laser...
It won't close, so it won't start, the latch doesn't click shut.
Seems to be a mechanical fault as only if the door closes the safety switch will latch on which will initiate the program to move forward.
What is require is to push the release many times , use a de-greasing spray into the door latch mechanism. if this wont work you might need to reassemble the door latch mechanism.- if mechanically minded.
Feb 04, 2011 | KitchenAid 24 in. KUDS02SR Built-in...
How do you take out third row seats
Follow the numbers on the latches. Step one fold the seat back forward. Step two fold the seat bottom forward. Step three pull the latch marked three towards you while pusing the seat away. This will allow the seat to disengage from the track and you can wheel it towards you and then lift it out of the truck.
May 14, 2010 | 2003 GMC Yukon
Trunk lid won`t close
make sure the latch isn't already in the closed position. next if you've already slammed the truck several times and haven't broke the latch yet, you may have bent the latch that's attached to the truck lid as the sheet metal in this area is very flimsy. using a flash light , slowly close lid while peering in to see if the latch is lining up. you should be able to tell if its bent and in which direction. i had this similar problem and i simply grabbed a hold of the latch and pulled it forward, bending it back into a position where it will line up and latch on bottom piece. ( the part attached to the body and not the truck)
Jan 11, 2010 | 1994 Buick Roadmaster
Need instructions on how to install a HP 6110 Cartridge Return Belt. The belt came off but does not appear to be broken.
Hello HP 6110 Cartridge
Issue : installing Cartridge on HP 6110 Printer
Printer :Desk jet HP 6110
Analysis : it seems that you are trying for Replacing the print cartridges
Solution : Please try the following steps to replace which is very simple and easy. The most important part is to understand and then apply without fear..
1) Turn on the power of the printer
2) Lift the print carriage access door on the front of the unit
Observe : the print carriage will move into the middle of the access area.
3) Release the cartridge to be replaced by pressing down lightly on the top of the carriage latch (You Need to Press Of force Single finger on the top of the Carriage Latch) and then pulling the lower section of the latch forward. Lift the latch.
4) Grasp the sides of the ink cartridge and pull the cartridge out to remove it.
5) NOW by
Holding the cartridge with the printed label up, slide the cartridges, one at a time, into the print carriage.
Insert the black print cartridge (HP 56) into the right side (with the gray latch) and the tri-color print cartridge (HP 57) into the left side (with the blue latch).
6) Latch the cartridge by pulling the lower section of the latch forward and pressing the latch down. When the latch is down, release the lower portion of the latch so that it catches under the tabs. Do not use force or damage might occur.
7) Close the print cartridge access door..
Now check the by running a test print
Click Start , click Settings , and then click Printers .
Right-click the all-in-one print icon and click Properties
On the General tab of the Printer properties, click the Test Page option.
Try the above steps hope the best out of it
Happy new year
Jan 02, 2010 | HP OfficeJet 6110 All-In-One InkJet...
The latch to my 2000 passat is broken. I guess I pulled too hard on the t-bar; it broke off. There was another little plastic piece that fell out too, but both pieces are not craked or broken. I tried a...
Yep you need to pull forward. The latch on those was made wrong. You shouldn't have to pull it forward to open. Use a light and see if you can find the cable to pull on, with maybe a long nose pliers?
Dec 17, 2009 | 1998 Volkswagen Beetle
I need to remove/replace cartridge,i dont know how?
Hi!
This link guides you on how to replace the cartridge:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00004340&lc=en&dlc=en&cc=us&product=79477
  1. Turn on the power.
  2. Lift the print carriage access door on the front of the unit, just above the output tray. The print carriage will move into the middle of the access area. Figure 1: Raising the front access doorc00004385.jpg
  3. Release the cartridge to be replaced by pressing down lightly on the top of the carriage latch and then pulling the lower section of the latch forward. Lift the latch.
  4. Grasp the sides of the ink cartridge and pull the cartridge out to remove it. Figure 2: Removing the cartridgec00004386.jpg
  5. Remove the replacement cartridge from its packaging. Touching only the black plastic, remove any tape covering the nozzles. Do not touch the gold-colored contacts. Figure 3: Removing the protective tapec00004387.jpg
  6. Holding the cartridge with the printed label up, slide the cartridges, one at a time, into the print carriage as shown below. Insert the black print cartridge (HP 56) into the right side (with the gray latch) and the tri-color print cartridge (HP 57) into the left side (with the blue latch). To install the optional photo cartridge (HP 58) for six-ink photo printing, remove the black print cartridge (HP 56) and insert the photo cartridge (HP 58) instead. Figure 4: Inserting the cartridgec00004388.jpg
  7. Latch the cartridge by pulling the lower section of the latch forward and pressing the latch down. When the latch is down, release the lower portion of the latch so that it catches under the tabs. Do not use force or damage might occur. Figure 5: Latching the ink cartridges in placec00004389.jpg
  8. Close the print cartridge access door. Figure 6: Closing the access doorc00004390.jpg
  9. A message will appear in the front panel display requesting that the ink cartridges be aligned. Press Enter to start the cartridge alignment. Two pages will print. Following the instructions printed on the second page, place the first page on the scanner glass in the lower-right corner and then press Enter to finish aligning the cartridges. Remove the page from the scanner glass when complete.
Nov 23, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Middle seat of 2000 Excursion moved forward, but now will not latch back in place It just keeps sliding back and forth.
It sounds like your latch has stuck on one side or the other. Get a flashlight and look under the seat, and at the same time pull on the handle that you use to move seat. Look for the movement of the seat adjuster, I bet that you have one that either sliped out of place, or some thing got between the adjuster and latch I.E. trash or one of your kids toys.
Sep 03, 2009 | 2000 Ford Expedition
k24674
jasbo
jasbo
