Question about Kitchen Ranges
Asko rangehood - overhead light keeps falling out, any ideas on how to fix?
Bluetack, Alfoil
Torin E13 Rangehood. Blown light globe needs replaceing
Gee I think I could figure that out by looking at it .
Jan 17, 2016 | Kitchen Ranges
Technika rangehood parts
please follow the steps and fix it. God bless you
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
May 27, 2013 | Microwave Ovens
I have an ASKO D3251. Door free falls when opened. No longer has tension to control downward movement.
Your springs are faulty.you have two of them and will need to pull the unit out and inspect.usually on asko dishwasher you have to order the whole tension spring assembly .
Jul 29, 2012 | Asko 24 in. D3250 Built-in Dishwasher
My Asko dryer is thumping loudly. I am finding bits of rubber when the lower panel is removed.
You need to have your drum rollers replaced, they are making the noise because they are falling apart.
Also it could be or include the drum belt breaking down and falling apart...which means its about to break.
Normally pretty cheap parts can be found on the net...look around.
Its a pretty easy fix.
Jan 15, 2011 | Asko Dryers
I have a delonghi Beta90ss rangehood (No. 0238). Fan and lights not working but indicators light up. Any idea if this problem can be fixed please ? Some electrical repair people say on the phone that...
The DeLonghi model's problem appears to be the same as the Parex one found here:
http://www.fixya.com/support/t9437177-parex_beta_90_ss_rangehood. Solution is described therein.
Oct 26, 2010 | DeLonghi Kitchen Ranges
Problem changing halogen bulbs on perla rangehood
The more I worked with it, the more I discovered that the real problem was that a screw was not all the way screwed in and it was preventing the panel from sliding. Another problem I may have is finding the glass covered halogen bulb.
May 13, 2009 | Faber Perla 602599 Kitchen Hood
Lexmark E232 Load Paper
see my other solution, glue a bluetack on the rubber rollers, you will need to do that occasionally.
Feb 22, 2009 | Lexmark E232 Laser Printer
Help for my asko diswasher
Unplug the washer for ten minutes, see if this clears the problem.
Aug 28, 2008 | Asko 24 in. D3350 Dishwasher
Kitchen Ranges Logo
67 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
