Question about Sewing Machines
Used machine. I read the manual. The lever was all the way down, moved it up and down twice and then it got stuck.
The pressure lever will not go all the way down.
  • Sewing Machines Master
  • 1,860 Answers
If oiling is mentioned in the manual then try oiling the machine, and see if that helps, and if not, then it may need to be checked.
Posted on Nov 20, 2014
How can I run pressure foot selector switch
Pressure on foot is regulated by the screw on the top of the machine directly above the pressure foot bar. Make sure your lever on back of machine is down, then turn the screw by hand, left for less pressure and to the right for more pressure.
Has anyone adjusted the presser foot inside the machine? That can throw it off or sometimes you need to look under the machine head into the oil pan to make sure there isn't something stuck and holding the pressure up from there.
Is this a new or used machine? Does it have enough oil in the pan?
Jul 13, 2016 | Juki DDL-8700
When i release the leg lever to let down the presser foot ,the foot wont release all the way and now it wont stitch
Mine does this too sometimes. Lift up the head and look in the middle of the oil pan. The knee controller runs through there. Make sure the black knob is not stuck. Hit the knee thing a couple of times to make sure it is not stuck. It should move freely up and down. That may fix the problem. If not, look st the small post to the left and behind the oil intake. Move the manual presserfoot lever on the machine to see it move. It will be stiff, but it should still lift a little. Usually jigging these two parts will fix the problem. Good luck..
Mar 22, 2016 | Juki DDL-5550 Industrial Straight Stitch...
How can I move the machine lock button release lever stuck in right position?
take it to be check again, could be a broken part inside
Feb 24, 2016 | Sewing Machines
THe Pressure foot on my Baby Lock BL101 blind hemmer is stuck and won't go all the way down. I just got this. It is a used one. I Did move it to the top and down once but the second time it would no
without seeing the machine it's hard to tell what's wrong with it, look in the manual, check about the oiling of the machine, but if oiling doesn't help then you may have to have the machine checked, if you got the machine at a sewing machine shop, I would suggest calling them and telling them about the problem, if you got it from a individual, then it may need to be checked to see if it needs a adjustment or see if there is a broken part.
Nov 20, 2014 | Baby Lock Sewing Machines
Why won't pressure foot move up and down with lever? What could be wrong?
If in storage, the old oil has probably solidified. Clean and oil it. If still stuck, direct heat from hand-held hairdryer into internal mechanism to loosen.
Jul 12, 2014 | Kenmore 15218 Mechanical Sewing Machine
Presser foot lever is stuck in down position,and it want go up
not sure of make or model, but as a general guide loosen all pressure bar spring tension, open face and check for physical obstruction, lubricate area well and heat effected parts with a hair drier. work lever gently, keep fingers crossed
Feb 02, 2014 | Sewing Machines
What is pressure foot on sewing machine. where is pressure foot
This is the foot that comes down and holds the fabric layers under the needle.
There will be a pressure foot lever to raise and lower the pressure foot at the back of the sewing area, it usually operates vertically, although some makes have a lever that works horizontally.
The pressure foot needs to be lowered BEFORE you start stitching as it activates the top tension and also helps with the stitch formation by holding the fabric firmly as the needle moves up and down.
You can read some general sewing machine info at www.sewing.about.com too.
Mar 29, 2011 | Janome Harmony 2039 Mechanical Sewing...
Model 6230- presser foot lifter won't move presser foot
That's the problem seized up use a penetrating oil from the top and work it up and down and it should free up
Dec 31, 2008 | PfaFF Tiptronic 2030
Pfaff 6122 Problem
Your machine just needs to be tuned up an the part inside that lower and raises the presser foot needs to be re-lubricated.  Lint, dust, dryness and the machine not being used can cause this issue with most pfaff machines (including my 7570).  A standard tune up from your local PFAFF dealer will remedy this.
Sep 24, 2008 | PfaFF Creative 7570
Janome 8000 memory craft embroidery/sewing machine
on the backside of your free arm there is a small lever which can be moved to lower the feed dogs.
When you want them back up move the lever the other way.NOTE!!
They will not go up until the machine has made one revolution.
sewman7
Jun 02, 2008 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
