Question about Vehicle Parts & Accessories
Location of ect sensor
Volkswagen Passat 2.0 turbo 4 cylinder I need to replace engine coolant tempature sensor
    Problem Solver:
  • 18 Answers
Hope this helps:
https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=Volkswagen%20Passat%202.0%20turbo%204%20cylinder%20engine%20coolant%20tempature%20sensor%20location
Posted on Dec 02, 2014
Location of temp sensor on a 2007 3.6 cadilac cts.
Engine Coolant Temperature (ECT) Sensor (LP1/LY7)
In the engine compartment, in the left side of the left cylinder head, between cylinders #2 and #4
Engine Coolant Temperature (ECT) Sensor (LS2)
In the engine compartment, towards the front of the left cylinder head, near #1 spark plug
May 17, 2018 | Cars & Trucks
I have a 2009 Pontiac G8 Gt. Need to know the location of the coolant temperature sensor.
What engine ? could have come with 9 different one's .
Engine Coolant Temperature (ECT) Sensor (LY7)
In the engine compartment, in the left side of the left cylinder head, between cylinders 2 and 4
Engine Coolant Temperature (ECT) Sensor (L76)
Left front of the engine above the spark plug 1
Dec 12, 2017 | Pontiac Cars & Trucks
2001 Passat 1.8 Turbo engine sputtering and hesitating
My car was doing this and I had to get all new coil packs... Mine were replaced under recall at the dealership at no cost. If you take each code and google it, or even check a VW forum, I'm sure the members there can provide a lot more thorough information...... I have a 2001.5 Passat myself and when one thing goes out they all follow suit. I will help with some research for you and post back...... But I'd check the coil packs that sit atop the spark plugs.
Feb 05, 2013 | 2001 Volkswagen Passat
Replaced engine coolant sensor on 2003 volkswagon passat 4 cylinder w/ turbo and need to know how to reset the engine control module or reset all of the on board diagnostic codes
Try:
1.) Press wrench button in
2.) Press key to on position, but do not start
3.) Release wrench button
4.) Press 'M' minute button
May 12, 2012 | 2003 Volkswagen Passat
Location of engine coolant temperature sensor
Automobiles: 2000 Ford Escort ZX2 4-cylinder 2.0L MFI DOHC
NOTE
The "left" side of the engine is the driver's side.
The Engine Coolant Temperature (ECT) sensor is a thermistor (a device which changes resistance or voltage as temperature changes). The sensor detects the temperature of engine coolant and provides a corresponding signal to the PCM (Powertrain Control Module - aka "the car's computer").
The ECT sensor is mounted in the following locations (small Ford engines):
1.8L engines: in the cylinder head
1.9L engines: threaded into the heater hose inlet pipe
2.0L engines: at the left rear of the engine
2.0L Zetec Engine
(1) Partially drain the engine cooling system using a clean container. If coolant is in good condition, retain for reuse.
(2) Disconnect the battery ground cable.
(3) Disconnect the electrical wiring connector from the engine coolant temperature (ECT) sensor.
(4) Remove the retaining clip and the ECT sensor.
Fig. 1 Escort ZX2 ECT sensor - The retaining clip is removed (at the solid arrow). Withdraw ECT sensor by gently wiggling/pulling in the direction of the dashed arrow.
To install:
NOTE
Coat the ECT sensor O-ring with clean coolant prior to installation.
(1) Replace the retaining clip and the ECT sensor.
(2) Connect the electrical wiring connector from the Engine Coolant Temperature (ECT) sensor.
(3) Connect the battery ground cable.
(4) Refill the engine cooling system. An inexpensive plastic "Radiator Funnel" will help with this task.
Dec 05, 2011 | 2000 Ford Escort
Coolant sensor replacement
The exact locations and picture of Engine Coolant Temp (ECT) sensors on 2001 VW Jetta TDI:
1. ECT sensor 1 placed on cylinder head:
2. ECT sensor 2 placed on the left bottom side of the radiator:
Apr 28, 2011 | 2001 Volkswagen Jetta TDI
I need the location of the ECT
ENGINE COOLANT TEMPERATURE SENSOR LOCATION IS ON THE UPPER RADIATOR HOSE CONNECTION ON THE CYLINDER HEAD.
Nov 17, 2010 | 2003 Volkswagen Passat
Need exact location and picture of coolant temp sensor on tdi vw jetta 2004 please Thanks
The exact locations and picture of Engine Coolant Temp (ECT) sensors on 2004 VW Jetta TDI:
Sep 21, 2010 | 2004 Volkswagen Jetta
Need to fing location of ECT sensor on a 1.8L turbo 2004 jetta
Take off the two covers on top of your engine. The ECT sensor should be on your right side of the engine. It may be either black or green and has a 4 blade connector. There is a plastic clip you slide out to replace the sensor. Hope this helps. Only takes a few minutes to replace
Feb 06, 2010 | 2004 Volkswagen Jetta
How much is the motor for 1999 volkswagen passat?
OK, there are only two motors that are compatible with your engine compartment. i will list replacement engines and there respective prices as well below.
1. 4 cylinders 1.8 liter sfi turbo--$3,999.00
2. 6 cylinders 2.8 liter sfi dohc---$3,999.00
Please rate and have a great day:)
May 14, 2009 | 1999 Volkswagen Passat
Vehicle Parts & Accessories Logo
54 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
