Question about DeLonghi Heating & Cooling
My heater keeps cutting off after 10 seconds? What is wrong?
Resetting my receptacle
    Top Expert:
  • 6,702 Answers
Could be more than one cause. The thermostat can be faulty. It could be it is asking to much current (a shortage for a part of the heater element) or another defect is noticed in the heater. Something is wrong, but I should see the device, to do a correct diagnose. Perhaps you can consult a technician close to you?
Posted on Nov 20, 2014
Ac unit keeps resetting
Good Morning Friend,
I understand that your Frigidaire air conditioner keeps resetting itself. First, be sure the electrical service is adequate for the model you have chosen. This information can be found on the serial plate, which is located on the side of the cabinet and behind the grille. Secondly, be sure the air conditioner is properly grounded. To minimize shock and fire hazards, proper grounding is important. The power cord is equipped with a three-prong grounding plug for protection against shock hazards. Lastly, your air conditioner must be used in a properly grounded wall receptacle. If the wall receptacle you intend to use is not adequately grounded or protected by a time delay fuse or circuit breaker, have a qualified electrician install the proper receptacle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 20, 2014 | Frigidaire Heating & Cooling
My lifesmart infrared heater cuts of when on ecno
Its eco mode aka turns off and on to save energy.
Dec 23, 2013 | Lasko 5132 Ceramic Compact Heater
I am trying to fix a printer for a friend it originally had an error with one of the ink cartridges i looked online and found out how to reset the system but now it is seems to be doing a sort of functions...
Try resetting it again.
After that, unplug the power cord and disconnect the printer from the computer. Once everything is unplugged, press the power button and hold it for 10 seconds to remove any remaining charge in the computer.
Then reset it one more time. Turn it back on but do not connect it to the computer yet.
Also make sure that the cartridges are already replaced before resetting it.
Hope this helps.
Apr 11, 2011 | Office Equipment & Supplies
No heating and hot water
sounds like overheat stat easy job to replace and do,nt cost the earth best of kuck
Oct 14, 2009 | Water Heaters
Draper dhs80i space heater cutting out after 25 minutes if you turn off/on again at wall it turns back on for 10 minutes,then cuts off again any ideas what wrong thanks
Does this heater have a fan,forced heat? If so, the unit will shut down if the fan is sluggish or stops. It could be getting too hot or the rhermal safety is weak.
Oct 10, 2009 | Heating & Cooling
Half way through cuttig a 2*4 my crAFTSMAN table saw cut out. Hitting the trip switch had no effect. Power source is good. Is there something I'm missing
The trip circuit has a time delay for resetting. Wait about 30 to 60 seconds and it should work when resetting.
Oct 06, 2009 | Craftsman 10" Table Saw
Cuts out in 10 seconds
you may want to replace the regulator
Sep 09, 2009 | Endless Summer (GA200209) Stainless Steel...
Trips GFI circuit brakers
First of all, lets clarify what is going on. You say it trips the GFI breaker, so I'm assuming that it is not a GFCI receptacle that you are plugging into. So you are going to the electrical panel and resetting the GFCI breaker.  If it were a GFCI receptacle, have you tried other loads in this receptacle for 30-40 seconds, ie: Toaster, hairdryer, coffee pot? If everything works fine then there is something wrong with the ESP8XL. It would seem that there is a leakage path to ground from one of the conductors. If it is new, bring it back.
Jul 30, 2009 | Breville ESP8XL Espresso Machine
My iphone was all working well then it froze so i pressed the home button and the power button for 10 seconds to reset it. i turned off then i held down the power button and the apple came up then my phone...
Hey! no need to panic, it seems you have jailbroken your iphone just like me!
This thing has happened with me a lot of times but i keep resetting the iphone by pressing the home and power button for few seconds and it works maybe not the first time or second time. I keep repeating this unless my iPhone comes back to normal
Hope that helps!
Jun 20, 2009 | Apple iPhone Smartphone
Electric hot water heater keeps throwing reset button
You most likely need to replace your thermostat. If your thermostat isn't cutting the supply to the element at the preset temperature, as it is meant to, the unit will keep on heating until the over-temperature cut-out operates. This is what the "reset button" is resetting. You should get an electrician or qualified service bloke to replace it so you dont go hurting yourself.
Mar 03, 2009 | Water Heaters
Heating & Cooling Logo
284 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
