Question about 1996 Chevy C1500 Truck Black Textured Outside Door Handle Pair New
Check gauge light comes on
It runs rough and engine noisy
  • 22 Answers
OBD II CAN Code Reader with Multilingual Menu
Grab one of these to read the code. The codes should point you in the right direction. Without details its difficult to diagnose rough running or noise..
Posted on Nov 20, 2014
  • AM Auto Parts Master
  • 906 Answers
Check gauges light mean one of your critical gauges is reading low. look at all the gauges and see which gauge is reading too low and you know where to start.
Posted on Jan 29, 2015
2007 Aveo leaking coolant from around the entire engine where the top is bolted down. Iost a lot fluid but the temp gauge doesn't ever go above half way so I'm not sure if there's an issue there also
check your hose's for small pin leak's. also check your thermostat housing and gasket. might be leaking from housing. might need a tune up if running rough. does your check engine light come on when car is running.
Sep 18, 2016 | 2007 Chevrolet Chevrolet Aveo 5 LS
2008 saturn aura xe3.5 motor 56,000 mile just purchased having problems with it already. ..engine light came on had it check out at auto zone ..only one code p 330 knock sensor. Engine light is off..but...
Bad ignition module often will not set a code for itself. Hard to diagnose due to being so random. Also just possible tach feed wire is shorting somewhere, coming and going.
Mar 28, 2015 | 2008 Saturn Aura XE
Have just replaced plugs and leads and the engine light keeps coming on for 1 to 3 mins and when its warm and i go to start it again the engine light comes on and runs a little rough what could this be?
It must be from the rough idling. Check the spark plug gaps and the lead wires if they have good continuity. Check your car manual for the proper gap for the spark plugs. Set it with the use of a spark plug gauge.
Jun 17, 2014 | 2005 Mitsubishi Lancer
My 2002 a-6 3.0 suddenly started running rough-engine light is on and blinks at 45mph. runs doggedly
Check oil and coolant levels (at the radiator cap) first. Run fault codes to find which sensor triggered the engine light . The light is to tell you that the engine is in danger of failure so do not dismiss the light as not important.. Hot smells mean that the engine is very hot and you may not have any coolant in the system to activate the temp light or gauge.
Dec 08, 2013 | Audi A6 Cars & Trucks
2000 chevy truck k2500 running rough, no power and backfires. after replacing distrubutor assembly
Is the check engine light on, and have you checked base fuel pressure with a gauge ?
Jun 03, 2013 | 2000 Chevrolet Silverado
Engine misfiring, warning lights are coming in and out.digital dash trac control, overdrive off light,temp gauge shots up momentarily, and check engine light. car running rough. 2000 Grand Marquis 95k
Misfire condition on cylinder 5 (P0305) and cylinder 8 (P0308). There is a good explanation of it here :
http://troubleshootmyvehicle.com/ford/4.6L-5.4L/how-to-diagnose-misfire-codes-1
Mar 20, 2013 | 2000 Mercury Grand Marquis
Test Water Pump on BMW
Loosen of the tension on the belt. see if there is any movement in the pulley (up-down -in -out Spin the pulley and check for roughness in the bearing.; Check for water leaking from the small hole in the housing at the base of the pump housing . Refit belt and correctly tension if nothing found. Check when it over heats (idle at lights) hard runs (speed) starts when cold and temp gauge continues to rise after engine is hot check if fan comes on at all.. Is the engine actually getting hot or is it an indication from the temp gauge ( faulty temp sender). If all is ok engines run hot if they are running lean so check the o2 sensor in the exhaust
Jan 26, 2013 | BMW X5 Series Cars & Trucks
Engine Misfiring. Rough Idling. Losing power going up hills. Engine light flickered one day. I brought it to dealer. They said cyl 5 had a fouled spark plug. They replaced it, retuned and cleared code....
It sounds like it could be a bad coil pack that is used for number 5 cylinder. It could also be a bad spark plug wire. Does the weather seem to make a difference? Try this quick check once night time comes around. Open the hood and start the engine. Fill a bug sprayer with salt water and spray the plug wire while the engine is running. If the wire is bad, you might notice an electrical arc from the wire to the engine block. The engine will probably start running rough. If this occurs, then the wire should be replaced. If it doesn't, then the coil pack can be tested with an ohm meter. I hope this information has been helpful to you. Good luck with your problem and thank you for using Fixya.com.
May 30, 2011 | 2008 Chevrolet Silverado 1500 2WD
Oil pressure gauge on max - running rough
install a fresh set of plugs. make sure to check them for proper gap, even if they are " pre-gapped "
hope2help shack
Apr 19, 2009 | Jeep Grand Cherokee Cars & Trucks
2000 olds Alero shutting off while driving
Check the 02 sensor and the ignition switc.
Oct 10, 2008 | 2000 Oldsmobile Alero
1996 Chevy C1500 Truck Black Textured Outside Door Handle Pair New Logo
91 people viewed this question
Top AM Auto Parts Vehicle Parts & Accessories Experts
Todd Arndt
Todd Arndt
noagge
terry stevens
Are you an AM Auto Parts Vehicle Part and Accessory Expert? Answer questions, earn points and help others
