Question about GE Kitchen Ranges
I have a GE Electric stove/oven. The stove works completely fine, but the oven is not working at all. When I set it to bake or broil, the oven doesn't heat. An interesting side note as well
I have reset the fuse that the stove/oven is on, and that did not appear to do anything.
    Genius:
  • GE Master
  • 2,494 Answers
Check the element and the switch .
Posted on Nov 20, 2014
Testimonial: "The heating element looks fine. There aren't any weird discolorations or dirt/grime on it. When you say "switch", what are you referring to?"
  • 833 Answers
SOURCE: Oven will not bake or broil
bann...why did you replace the element? It is possible that the relay or the control circuit were the problems and still are. The hi limit switch is a temperature 'box' which is designed to open the circuit in case of overheating. Rarely a problem. First, these units are 3 wire units. That means 220 volts ... two breakers. They may be part of a linked unit or separate. Turn them BOTH off and then on. Do all of your burners heat properly on high? If you have a voltage tester, you can test to see if the voltage is there. Unplug the unit. The vertical slot is neutral. Each of the other slots with the neutral should light the tester. If not, your problem is outside the stove.
Posted on Dec 12, 2007
  • 198 Answers
SOURCE: Electric stove elements stopped working
Circuit breaker is tripped duel breaker 1 of them is tripped, maybe an electrical problem causing this.
Posted on Feb 20, 2009
leroyal
  • 2120 Answers
SOURCE: Oven won't heat. No gas smell. Broiler and stove work.
Bad oven control circuit board. Look up on eBay
Posted on Feb 21, 2009
beachin
  • 6 Answers
SOURCE: GE Profile Electric Stove - Buttons for oven don't work
We had a bunch of storms roll through the area and we figured a surge must have fried our control panel. We decided to buy a new oven rather than spend $200 fixing this one. Luckily, our local Sears rep wasn't in it just for the commission and suggested we flip the circuit breaker off for 10 minutes to allow the range to reset itself. Works good as new! So, try this first before you make a decision. Good luck!
Posted on Apr 03, 2009
2coolrick
  • 560 Answers
SOURCE: Frigidaire Gallery stove, oven won't heat up (electric)
With the oven OFF, check the resistance of the bake element with a ohmmeter on the lowest scale. Rx1. If your reading is infinate, replace the element as most elements will open circuit when they burn out. They don't short out.
Posted on Jul 30, 2009
Oven will not heat at all. Stovetop works fine
Phillip, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Oven Wont Heat or Not Working Bake and Broil Element Testing Oven...
Electric Stove Troubleshooting Oven Not Working
Top 6 Reasons Electric Oven Wont Heat Electric Range Troubleshooting
Stove Terminal Block Replacement Frigidaire Electric Range Repair part...
Jun 17, 2016 | Kitchen Ranges
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
JKP86-27 neither heating element (broil or bake) is working. Other controls and microwave work fine.
having the same problem, microwave works however oven does not heat up. The controls work, I can set the temp and bake, the fan turns on but the oven does not heat.
Nov 25, 2010 | GE JKP86 Electric Double Oven
Gas oven won't work on "bake" setting
If the hot surface ignitor is very red in the middle of it when turnig on the oven, it is faulty. Replace it.
Jul 18, 2010 | GE Kitchen Ranges
Bottom filament on bake not working but broil and
FAULTY ELEMENT OR THERMAL SWITCH. HAVE IT CHECKED OUT BY AN ELECTRICIAN.
Sep 07, 2009 | Stoves 720EF Electric Double Oven
GE Profile Stove baking option not working
Possibly the bake igniter, the temperature sensor or the electronic oven clock/control. Does broil mode heat properly or does it run cool also? If broil heats to the proper temperature then the temperature sensor is probably ok. That leaves the ignitor or the controller which takes some more troubleshooting. If it is the controller, we repair them at www.fixyourboard.com.
Aug 31, 2009 | GE JGRP17 Gas Single Oven
My broiler works - but the oven does not - GE Dual Fuel range
Thanks for providing the full model number, which allows us to look up part numbers and see exploded views of your product.
Most likely the bake ignitor is bad (even if it still glows, it may not draw enough amperage to allow the gas safety valve to open). One way you can test this on your model is to swap out the broil ignitor for the bake ignitor, as they are the same part number on your model. (part number WB13T10045) The broiler is normally used much less than the oven, so the part does not fail very often on the broiler. You will have to take the cover off the floor of the oven, then the flame spreader, to reach the burner area. The ignitor is the rectangular part at the back, on the side of the burner. (only two wires to deal with) (By the way, for future reference, your model number ends is SS, as in stainless steel, not a 55)
Jan 15, 2009 | GE Profile JGSP44 Dual Fuel (Electric and...
JBP26 Oven broil and bake do not work and the oven light is flash
If you have 240Volts to the range and BOTH elements don't work, it sounds like the L2 OUT relay on the oven control is bad. Bake and Broil share this line and this problem is not un-common. Make sure you have proper incoming voltage first. Turn breaker off and back on to make sure both poles are set.
Dec 15, 2008 | GE JBP24 QuickClean Electric Kitchen Range
Electric Oven not getting hot enough
Sir, I think the top oelement is for broiling ONLY. It should not turn on when baking. The clicking may be the oven heating up.
How far apart were the oven temp instrument and the digital?
Don't expect them to match...they are inaccurate.
1. Heat water until it boils. Place digital therm in boiling water until it comes up to 212deg. If it is not at 212 in boiling water, record the error.(this gives a rough calibration to the digital)
2 Turn on oven, set to 350 deg, place digital therm on rack. Wait until oven reaches 350 (on stove) and read the digital. Note the difference between the two
Mar 30, 2008 | GE Profile Spectra JBP95 Electric Kitchen...
Kitchen Ranges Logo
134 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
