How to change setting to cable or antenna mode
  • kakima Nov 20, 2014
    What make and model?
    Top Expert:
  • Televison & ... Master
  • 14,162 Answers
Posted on Nov 20, 2014
When in antenna mode why does it freeze then turn off and come back on in HDMI1 mode?
[PDF]USER MANUAL - Vizio
www.vizio.com/documents/downloads/hdtv/.../UM_E550iB2.pdf
VizioAny other voltage than the specified voltage may .... Do not locate the antenna near overhead light or power circuits, ..... the instructions that came with your mount. ...WIDE. Switch the display mode. MUTE. Turn the audio off or on. BACK ..... Zoom. Normal. Note: Aspect ratio settings may vary by Input source. HDMI-1. HDMI- ...
[PDF]USER MANUAL - VIZIO
cdn.vizio.com/documents/e40c2/um-e40c2.pdf
setting and this is the setting in which power savings will be .... electric shock, do not perform any servicing other than ... connected to the TV, make sure that the antenna or cable system .... Locking and Unlocking the Custom Picture Modes ..... ...... .....BACK. Go to the previous on-screen menu. MUTE. Turn the audio off or on.Missing: freezes
Connecting Cable Service, Satellite Service, or Antenna ...
vizhdtv.com/connecting-cable-service-satellite-service-or-antenna-chann...
Jan 21, 2016 | Vizio E420VA 42 in. LCD HDTV
How do I change from cable to antenna?
Without knowing the make and model it is difficult to answer your question accurately. In general you would change either the source or input option. Usually the antenna option is called TV.
Sep 08, 2015 | Televison & Video
How do I change from cable to antenna input
Its in the menu for the set--on screen and is done with the remote---you want to move to antenna/air.
Even if in cable mode it should pick up any active channels 2-13.
Dec 03, 2012 | Insignia 32" 720p Flat-Panel LCD HDTV
How to tune channels first time when you purchase a new Sony Kdl 32EX600 LED tv?
Hello
Do connection to the antena if you wants to set the TV auto tuned.
During this initial setup, you can perform the following:
1 Select the language for the on-screen display text.
2 Select HOME or Retail mode. [Here you have to select "Home" mode if the set displays "Retail"
3 Connect cable or antenna, then select OK to run Auto
Program
• If you have cable and antenna available, please connect cable first.
• IMPORTANT: Auto Program is only effective when cable or
antenna is connected. If you cancel Auto Program before completion some channels may not be
available.
4 Auto Program will scan for available channels from the signal source directly connected to
the TV's CABLE/ANTENNA input and may take sometime to complete the process. Follow
the help text provided on the screen to run Auto Program.
OK.
Feb 23, 2011 | Sony KDL40EX600 TV
Can't change TV to CATV mode
You must unplug the cable connecting the television and the cable box. Then turn the television off and then back on. Do not turn the cable box off or disconnect the cable in wire from the cable box especially if you use Cable Vision. It will take up to 20 minutes before the box comes back on. Now turn the television back on. When you access the Channel System menu, you have the access to the submenu choices. Change the Antenna option to CATV and the Current Channel to 3. Reconnect the cable box to the TV.
Also those that are having problems with the TV turning off periodically, make sure the sleep mode option does not have a number in it. For example, if the number is 10, it will turn off every 10 minutes.
Sep 05, 2009 | Memorex MT2206 TV
Emerson ewv404 catv to antenna
There is an option in the menu which changes the tuner from cable to antenna (off-air or broadcast) mode. On many/most late VCRs, you must have the remote box to access these functions.
Old VCRs (15 years +) might have had a switch to make this change.
Nov 01, 2008 | Emerson EWV403 VHS VCR
Cable setuo for model 27r410t
Get an antenna hooked up, even rabbit ears should pull in a few analog channels. Set top boxes will only output Ch 3 (switcheable to ch 4 on the back if needed) and cable may be dead or only give you scrambled CATV channels. You need to set your tuner to "antenna", not CATV, IRC,HRC, or ATSC (if you have a digital tuner) and do the setup again. You could have a bad tuner at worst, and all is not lost, just hook up a VCR via RCA cables and use the VCR tuner to change channels. Keep TV on Ch3.
Feb 12, 2008 | Televison & Video
27 inch symphonic
with the set turned off press the game
button and if it comes on it should be
in game/cable mode
Oct 31, 2007 | Symphonic ST419E TV
Going from antenna to cable off the remote
Can you tell me what the remote code is for this unit
Sep 29, 2006 | Symphonic SC3813 13 in. TV/VCR Combo
Televison & Video Logo
293 people viewed this question
Top Televison & Video Experts
