Question about Canon imageFORMULA DR-G1100 Production Document Scanner
Canon DR-G1100 Intermittent scans half of page vertically. Sometimes half of page is very light vertically?
  • 24 Answers
The problem you described will probably warrant a technician to check out. It very well may be a shading plate hanging up, or a reading unit connection loose. There is no short answer for that problem...however, anyone looking for the "cartage drum" ram kumar verma mentioned can relax. You have a scanner and not a printer.
Posted on Jan 18, 2015
    Problem Solver:
  • 18 Answers
First off all change your cartage drum and after that you can chek it and post your question again dear
Posted on Nov 23, 2014
mohanchennai
  • 490 Answers
SOURCE: DR-9080C intermittent stops during scanning which last 3 to 5 minutes
Do you have enough hard disk space? Reinstall your driver software. Run Scandisk on the Comp.
Is the problem coming on after a set time interval, any heating smell?
S. Mohan
Posted on Jun 23, 2008
mohanchennai
  • 490 Answers
SOURCE: Not scanning full page Canon DR-3080II/CapturePerfect
U should select 'Scanners maximum'  and try this. I have found this does not work midway, after some scans. So close and exit out of captureperfect, re-enter and try. This should work.
S. Mohan
Posted on Feb 02, 2009
mohanchennai
  • 490 Answers
SOURCE: The scanner pauses half way throught the document
May be the location where it is writing the data is not 'free'. Do a 'deframent' of the drive where you intend saving the data. Ensure there is enough space on the Hard Disk
S. Mohan, Chennai, India
Posted on Feb 17, 2009
mohanchennai
  • 490 Answers
SOURCE: Canon DR 2580C Scanning issue
In Captureperfect, select page size as 'Scanners Maximum'. Select automatic paper size, check the output now. If you select bigger paper size and smaller paper, you will see lack output, outside the paper area.
Posted on Mar 18, 2009
SOURCE: My Canon DR-2050C keeps jamming when I try to scan more than 1 page???
I finally solved my problem. Now it works like new.
Cause:
- The spring that returns the next sheet detector (small black plastic rocker arm between the two rollers on the back side) came off. So the scanner cannot detect transition from one page to the next. This spring is located inside the device and you cannot fix it from the outside.
- You know if you have this problem if you don't hear a "click" sound after each page is scanned. Without the spring attached the rocker will not return on every page. When it doesn't return the scanner think it is still on the first page and will not scan the next page. The "click" after each page is NORMAL. Without the click is the first sign your spring came off.
Solution (Only recommended for people handy with hardware and the unit is no longer under warranty)
1. Turn off power and unplug the device.
2. Pop off the plastic cover to the back of the scanner
3. Remove the screws that holds the plastic cover to the back.
4. Remove the screw by pushing on the retainer clips. DO NOT loosen any gears or motors.
5. Locate the rocker arm and re-connect the (very small) spring
6. Warning - if the LED light pipe falls out be careful how you put it back. This is a transparent widget at the top to route a LED light to the top of the device to indicate the power on status.
Sorry I didn't take pictures. If this sounds too complicated, send it to Canon for repair. Took me about a day to figure out exactly what was wrong and how to disassemble the scanner to fix it.
Good luck.
Posted on May 26, 2009
Scanning half a page
You will need to check your page settings. As each program is different, the page setup will generally stay the same. It will also change if you are scanning at 0, 90, 180, or 270 degrees as well.
Mar 04, 2014 | Canon DR-7580
Canon DR-2580C scanner only scanning half the page. What could be the problem?
Select Auto for page size. The scanning software displays scanned image in many options, including 'fit'. Choose 'fit' so that you see complete image.
S. Mohan
Dec 29, 2011 | Canon DR-2580C Path-Through Scanner
Canon 9080C not scanning 11x17 pages
The problem is probably in your scanning software, you have to tell it if you want to scan legal size, and if you leave it set for legal all the time it might put dark bars under the letter size docs. It depends on the version of software on your computer.
Sep 03, 2009 | Canon DR-9080C Path-Through Scanner
The scanner only scan one side fully
If the bottom is vertically split, then there could be some problem in the hardware (bottom scanning module) Check for loose contacts. If it is cut horizontally, it must be definitely loose contat problem.
S. Mohan, India
Aug 16, 2009 | Canon DR-3080CII Path-Through Flatbed...
Getting vertical lines on scanned pages when duplex scanning on canon dr-3080c II scanner Only on duplex side of pages, though. Front page still shows up clean.
It is dust on the glass, clean it thoroughly. You will find it at the same location for all drawings and may get faded for lower brightness!
S. Mohan
Jul 10, 2009 | Canon DR 3080C Path-Through Scanner
If I put a large amount of paper in my canon dr-9080cscanner, it only part of the page until ti gets to a specific part. For example I put in 100 pages and it scans the middle inch and a half until it gets...
I could not understand your problem clearly.
If I am right, you are saying that if you scan 100 pages, about 80 pages are scanned properly and the there is problem with the balance 20. Clean the rollers throughly with a damp cloth and also the ****** rollers. Please swithc of the scanner when you are cleaning the ****** rollers as they are in a 'locked' position in power on position.
If your problem is different, please explain it clearly.
S. Mohan, India
Jul 08, 2009 | Canon DR-9080C Path-Through Scanner
S. Mohan
Nov 19, 2008 | Canon DR-9080C Path-Through Scanner
S. Mohan
Jun 22, 2008 | Canon DR-9080C Path-Through Scanner
Scanner inserts vertical line on some documents
Clean the glass with IsoPropyl Alcohol. Dont use any other solvent. A speck of dust stuck to the glass can give a continuous line in the output
S. Mohan
Sep 29, 2006 | Canon DR-1210C Scanner
Canon imageFORMULA DR-G1100 Production Document Scanner Logo
128 people viewed this question
old marine
old marine
