<!-- from fixya rte -->How do I remove the front door of the washer - Washing Machines
  • 25 Answers
There should be screes on the door hing that you would have to remove. then yoou may have to lift the door up a little and out
Posted on Nov 26, 2014
What does error code F29 mean for a whirlpool duet sport front load washer?
F29 is a Door Latch Unlock error. This occurs after the door attempts to lock 6 times. With no successful lock achieved, the error code will be generated. Check the following:
1.First, UNPLUG the washer in an attempt to reset the Central Control Unit (CCU). Sometimes this is all that required in order to clear momentary glitches with the unit. If the error code reappears, proceed to step 2.
2.Check the door switch/latch for foreign objects that may have become lodged in the mechanism and may be preventing it from operating.
3.Check the wiring harness from the CCU to the door latch. The harness can be accessed by removing the washer top panel. Remove the panel by removing the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, and then off.
If you determine the door latch to be defective, the following steps will give you the necessary information needed to replace it:
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
NOTE: An alternate method to replace the door latch is to remove the top panel and work from the top and down behind the front panel. Due to the limited space, removing the front of the door bellow can be a better option.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Tip
F22 Error Code on Whirlpool Duet & Kenmore Elite Front Loader Washers
This advice is for Kenmore Elite and Whirlpool Duet Front Loading washing machines displaying the "F22" error code.
This is an indication of a door latch failure and/or interconnecting wiring problem. The first step in troubleshooting the problem is to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). This is the main "brain" of your washing machine. Sometimes these error codes are erroneous and can be easily cleared by resetting the CCU. If the error code reappears following a CCU reset, then you have a genuine problem. In addition, if the door latch remains locked following this procedure, there is a manual release you can use to open the door. Follow these steps:
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with a 2 x 4, it makes access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
If you still have the error code displayed, inspect the door latch mechanism for any broken, loose, or missing components. Next, open the top panel of the washer by removing the three screws in the rear of the washer that hold the panel in place. With the screws removed, the panel will slide back, then off. Locate the door latch on the right hand side behind the front panel. Inspect the wiring harness from the door latch to the to CCU. The CCU is located directly behind the wash tub in the top rear of the washer. Make sure all the connectors are snug and not loose or broken. In the majority of cases, a persistent error is a failed door latch. If all these preliminary checks are unsuccessful, replace the door latch. Follow these steps:
1. Unplug washer.
NOTE: Another method is to access behind the front panel from the top with the top panel removed. Either method works, but I have found that going through the front offers better access.
I hope you find this information helpful. If you have questions please "Ask Me".
on Apr 12, 2009 | Kenmore Elite 45986 Front Load Washer
Tip
F29 Error Code on Whirlpool Duet & Kenmore Elite Front Loader Washers
This advice is for Kenmore Elite or Whirlpool Duet FRONT LOADER washing machines displaying the F29 Error Code.
  1. First, UNPLUG the washer in an attempt to reset the Central Control Unit (CCU). Sometimes this is all that required in order to clear momentary glitches with the unit. If the error code reappears, proceed to step 2.
  2. Check the door switch/latch for foreign objects that may have become lodged in the mechanism and may be preventing it from operating.
  3. Check the wiring harness from the CCU to the door latch. The harness can be accessed by removing the washer top panel. Remove the panel by removing the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, and then off.
1. Unplug washer.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Good luck and I hope this information is helpful.
on Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
Front Loader Washer show code F22
1. Unplug washer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.####
Apr 03, 2010 | Whirlpool GHW9400SU Front Load Stacked...
Door lock on my Whirlpool Steam front loading washer unlocks!
1. Unplug washer.
Mar 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have lost a "washable" bear in my HE2 front load washer. I paid sears nearly $200 last month when a small "beanie" hat got stuck somehow behind the gasket. I did nto see how the sears repairman removed...
Door Gasket Removal Procedure
  1. Unplug the washer for your safety.
  2. Open the door and locate the door gasket retaining hoop. Stretch the retaining hoop spring and remove the hoop from the perimeter of the door gasket.
  3. Peel back the door gasket from the lip of the tub into the drum.
  4. Remove the door switch from the front panel.
  5. Remove the top panel/cover of the machine.
  6. Remove the console.
  7. Remove the front panel.
  8. Carefully pull the door gasket from around the inlet and window washer tubes.
  9. Remove the door gasket retaining clamp by loosening the clamp screw on the upper right of the tub opening.
  10. Peel off the door gasket completely from the tub. Be careful not to tear or punch a hole on it.
  11. Reassemble the parts in reverse order of the removal procedures given.
Door Switch Removal
  1. Remove the screws holding the door switch on the right side of the door opening.
  2. Lift the door switch and pull it away from the front panel.
Top Cover Removal
  1. Remove the screws securing the top panel at the back of the machine and lift it off.
Console Removal
  1. Disconnect the ribbon connector from the left side of the central control unit which is located directly above the rear of the tub.
  2. Release the ribbon connector from the wiring harness brackets on the right side of the washer top.
  3. Pull the detergent dispenser drawer out and press down on the release tab at the back of the drawer then pull it completely out of the washer.
  4. Remove the screw in the recessed hole next to the drawer opening.
  5. Open the door and insert a flat-bladed screwdriver into the slot in the bottom center of the console.
  6. Push the console up to release the center tab and remove it from the washer.
Front Panel Removal
  1. Remove the three screws holding the toe panel to the front of the washer.
  2. Lift the toe panel slightly then pull it to the front to remove it.
  3. Remove the two bottom screws and two top screws holding the front panel to the washer.
  4. Remove the front panel from the washer.
Jan 21, 2010 | Kenmore HE2 Plus Front Load Washer
I close washer door but it wont go through cycle
Check to see if one of the two tabs on the door latch assembly are broken. If one is broken, replace the door latch. If the door latch is ok, you might have to replace the door switch and the door latch. To replace the door switch you have to remove the front panel. Remove the two screws holding the door switch assembly in place and drop the door switch assembly down into the bottom of the washer. Remove the wires and transfer to the new switch. Reach up and line up the new switch and install the two screws. Remove the two screws on the door latch assembly on the door, and remove old door latch. Install the new latch and replace the front panel. I hope this helps.
Jan 21, 2010 | Frigidaire Affinity ATF7000E Front Load...
I have to fit this washer through a door smaller than the machine. How do I take the front panel and door off so it fits through this bathroom's door?
I would suggest it would be much more simple to remove the bathroom door, as it is not a straight forward job to remove the washer front panel
Carefully check the measurements of the opening with the bathroom door removed.
Hope this assists you.
Dec 14, 2009 | Kenmore 44042 Front Load Washer
Fit a new door hinge
Remove the wire clamp securing rubber seal to front of washer, pull seal of front of washer, this will give you clear access to tjhe door hinge, ondo the 2 screws securing the door hinge, remove door ,and seperate the 2 door halves by removing the screws securing it together
Replace with new hinge, fit back in reverse order.
Please rate my solution.
Thanks.
Nov 12, 2009 | Creda W120VW Front Load Washer
Door boot seal on a front load washer how to change
front gasket/door boot.... replacement isn't easy but do-able. first remove three screws that hold front lower panel on and remove panel (where lint filter is). then remove 3 screws that hold on top panel (screws located at rear of top of washer), next remove 3 screws on top front of washer, then remove 4 screws that secure the contol panel. you must remove the washer door at this point, just a few screws and pin hold the door on. now, remove control panel by gently pulling the top away from the washer, it's held by a few plastic snaps. then, remove three screws that secure front panel of washer. now you're ready to remove the old boot/gasket. first look toward lower right side of gasket and pull the spring and remove wire that secures front of gasket. next... at about 3 o'clock on the gasket you'll find a longer screw (about 3 inches) that secures the rear of the gasket. loosen this screw until you can remove the gasket. remove the water inlet and hose from the boot/gasket.... now remove gasket from washer. you're ready to install new boot/gasket. find the small triangle on the new gasket and line this up w/the triangel at the top of wash tub. begin working the gasket onto the lip of tub, make sure to align the triangle and water outlets of the gasket w/the triangle and outlets of the washer tub. once back of gasket is on install the rear wire holder and tighten screw to former tightness. now work front of gasket onto the lip of washer, install spring wire to secure the front. place water inlet and hose into respective holes on the gasket. put front panel back on, put door on, put control panel on, put top on... and wash. like i said, not easy but do-able... i completed it in 1.5 hrs w/no instruction.
Nov 11, 2009 | GE WSXH208A Front Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
