Question about Frigidaire Fra18emu2 Air Conditioner
My Frigidiaire air conditioner will not turn off. It will run the a/c no matter what setting I put it on. The only way to stop it from cooling is to unplug it. I spoke with a technician over the phone and they said the best thing to do was replace it. I bought this new and only used it for one summer before this started happening. I have seen other posts on here regarding the same model with the same problem. Hoping someone can help.
  • Official Brand Answer
  • 2,267 Answers
Hello Christopher Welch, thank you for your inquiry!
I see that your Frigidaire air conditioner is continuously cooling until you disconnect power from it. It sounds like a possible problem with your sensor, thermostat, or control panel. Are you currently under warranty? If so, I would speak to your manufacturer for a resolution to your current issue. Best of luck! -Matt
Posted on Nov 21, 2014
My 12000btu spliter air condition start and stop in 5 seconds
24
EN
TROUBLESHOOTING
CAUTION
If any of the following conditions occur, stop the air conditioner immediately, turn off the main power switch and contact the
dealer.
• The indicators flash at short intervals (5 Hz). Reset the circuit breaker 2 to 3 minutes after the power main switch is turned
off.
Despite the resetting operation, the indicators still continue turning on and off.
• The main power fuse often blows, or the circuit breaker is often activated.
• Foreign matter or water has fallen inside the air conditioner.
• Any other unusual conditions are observed.
Before asking for servicing or repairs, check the following points.
Recheck
Inoperative
• The power main switch is turned off.
• The circuit breaker is activated to cut off the power supply.
• The main power fuse has blown.
• The electric current has stopped.
• The batteries in the remote controller used up.
• The ON timer is set.
• As a protective mechanism for the air conditioner, it does not operate for 3 minutes
immediately after restarting operation or turning on the main power.
Poor cooling or heating performance
• The air inlet or outlet of the outdoor unit is blocked.
• Doors or windows are opened.
• The air filter is clogged with dust.
• The louver is not at the correct position.
• The fan speed is set to low.
• The air conditioner is set
to the DRY or SLEEP MODE.
• The temperature setting is too high (during cooling operation).
• The temperature setting is too low (during heating operation). (heat pump models)
Feb 01, 2015 | Samsung AS18A6RB Air Conditioner
Whats wrong when my unit coll good and runs good but when I turn it off the compressor keeps on running
Good Afternoon Friend,
I understand the compressor to your Frigidaire air conditioner, model# FAM187S2A, runs all the time. I also see that no matter what option you put in on, including "OFF", the compressor will stay on, unless you unplug the appliance. There could be a couple different possibilities with this occurring. It could possibly be the switch behind the control board. It could possibly be the control board. It could possibly be something completely separate that is causing the compressor to stay on when you plug your air conditioner in. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine the exact cause. Hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Frigidaire FAM187S2A Air Conditioner
Ac fan not running, but compressor runs on and off
switch/ fuse possible if it has one, if not one of the wire going to the motor was severed, or the start up capacitor of the motor if it also has one.
Jun 04, 2013 | Frigidaire FAX054P7A Wall/Window Air...
My A/C freezing its coils, while the fans keep running. The AC unit (outside) keep running and never stop caused the coils freezing. It doesn't matter when I turn off or set it to Cool position, the...
Sounds like the contactor in the condensing unit is stuck. That is why it will not turn off when the thermostat is satisfied. If the inside air handler is not blowing and the outside condensing unit is running, then this will cause the inside coils to freeze up rather quickly.
The contactor is located in the outside condensing uni in the electrical compartment.
If it is sticking it will need to be replaced.
Sep 07, 2011 | Heating & Cooling
My heater never stops working even if i turn it off
There is a several minute delay from the time you turn this device off until it actually goes off. Reason for this is for the air conditioner to properly cycle off OR for the heater to properly cool down and shut off. This is not a light you are turning on and off, it is a complicated (for good reason) heating and/or cooling device.
Every time you change the setting, you add more time for the thing to take the proper action.
There is also a setting on most Goodman devices that will keep the fan going ... no matter what (well, almost no matter what)
I'm sure your instruction manual will explain these things in detail, after some number of pages of legal notices. Im equally certain your installer can be of further assistance with these concerns.
Thank you for your interest in FixYa.com
Please vore
thanks
a
Dec 11, 2009 | Goodman CLJ30AR32 Air Conditioner
Thermostat does not stop
THE T`STAD IS SHOTAGE REPLACE THERMOSTAD, IF IT`S A ELECTRONIC THERMOSTAD REPALCE IT
Aug 19, 2009 | LG LWHD1500ER Wall/Window Air Conditioner
Running Compressor Intermittently
replace the thermastat it has a bad set of contacts
May 05, 2008 | Goldstar R8000 Air Conditioner
Frigidaire Fra18emu2 Air Conditioner Logo
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
