I'm having a problem with my thermoheat propane heater 30,000-60,000 btu. It acts like it's stuck in low even with the knob turned all the way up. How can I fix this?
    New Friend:
  • 8 Answers
Sounds like thermo coupler. Check to see if it got bent or moved From flame . If not replace it.
Posted on Nov 20, 2014
4 Suggested Answers
SOURCE: propane shuts off after releasing start button.
I have the same problem with my Reddy heater 55-f. Is it thermal coupling or relay?
Posted on Dec 08, 2009
koolbreezes
  • 540 Answers
SOURCE: raw propane fumes and burning eyes
Ours didn,t burn liquid propane too well, so ccheck your connections on your tank for vapor or liquid.
Posted on Dec 18, 2009
  • 58 Answers
SOURCE: cant get my heater to stay ignited
THERMO COUPLER, COPPER PEICE INSIDE TUBE MAKE SURE THE FLAME IS IN CONTACT WITH THIS PEICE, 99 PERCENT OF THE TIME IF A UNIT HEATER, WATER HEATER ETC WILL NOT STAY ON AND DOES WHEN YOU HOLD IT IN IT IS THE THERMO COUPLER
Posted on Jan 20, 2010
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
I HAVE A THERMOHEAT CABINET PROPANE HEATER...... LATELY IT SMELLS....NOT OF PROPANE ..BUT LIKE A RICH BURN ..WHY?
If it hasn't been cleaned and serviced on a regular basis (at least annually), that more than likely the problem. The dust, lint and/or pet hair as infiltrated the heater and is clogging things up. Particularly, the burner. Thoroughly cleaning the heater inside and out will more than likely solve your odor issues. Also, check your propane tank to make sure it's not running low on gas. That can also cause the odor issue.
Hope this helps to solve your problem. Please let me know.
Feb 14, 2011 | Heating & Cooling
30000 btu reddy heater is throwing flame way out of the heater
The gas pressure is way to high... you need to adjust the regulator to a low pressure or replace the regulator...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Dec 10, 2010 | Reddy Heater-30,000 BTU Propane Forced-Air...
Cant get my heater to stay ignited
Jan 20, 2010 | Reddy Heater-30,000 BTU Propane Forced-Air...
HEATER WAS WORKING FINE TILL I HAD PROPANE TANK TOPPED OFF
The Pressure Regulator may be stuck, Try closing the propane valve releasing the pressure,, gently tap the regulator( on the propane inlet side) and Very Very slowly open the propane tank valve, and attempt to light
Jul 30, 2009 | Hayward H Series
Pilot valve will not turn
Hi do not remove the screws it will be safer to change the gas valve
Jun 05, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Heating & Cooling Logo
119 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
