Question about Whirlpool Washing Machines
Electronic board for AGI SS 50 whirlpool washing machine
Model: AGI SS 50,Whirlpool washing machine- electronic board spoiled by rat-where to get new board or compatable board
Need to show ser manual whirlpool washing machine agi ss 50
Posted on Dec 31, 2014
    Problem Solver:
  • 21 Answers
Find the part number for the board and go on ebay to look for a new or used one boards our usually expensive so i would look there first
Posted on Nov 25, 2014
catriver
  • 878 Answers
SOURCE: Maytag Neptune Washing Machine electronic malfunction.
barry, sounds more like the keypad is stuck or shorted. You can try to do a membrane test by putting it into the service mode. Have the unit on, press and hold the delicates and heavy soil key together until it shows 00 on the display. Then press the wrinkle free key. This will let you test every key on the keypad. You can toggle them off and on and see if they are responding. If they are not responding then you can assume that the keypad is your problem. At repairclinic.com you can order the part you need and if it doesn't solve the problem they will take it back no questions asked. A lot of people are not too fond of these washers because of the many issues they had with them. You would have to weigh the price of the part versus a new washer. The keypad is not hard to install. Just a ribbon that plugs into the board. You may want to try to clean the end of the ribbon with a eraser and see if that fixes the problem. Make sure the unit is unplugged before going in there.
Posted on Mar 07, 2009
  • 240 Answers
SOURCE: F50 error code and Whirlpool Cabrio
this code would indicate rps sensor at motor. whirlpools are very bad with electronics and control boards. New rps sensor requires new harness as well.
Posted on Mar 14, 2009
  • 6 Answers
SOURCE: code f23 for whirlpool washing machine
It means that there is a fault in the heating circuit and the heater is not working
The listed site deals with this problem so take a look and if you are fully capable of testing, follow the troubleshooting instructions but always double check that the unit is unplugged or disconnected from the electrical supply.
http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
And remember kindergarten rule #1 "If in doubt, don't" with everything that is potentially dangerous. Electricity kills so a service repair bill may be a better solution.
Hope this helps.
jenni.
Posted on Sep 09, 2009
  • 132 Answers
SOURCE: agitator for whirlpool washing machine
The plastic dogs are stripped inside the center of the agitator. To remove agitator pop off the top center cover(slot for screwdriver) There is a 7/16 inch bolt with standard thread, remove it and pull out agitator. Pull the agitator apart, you can stand on the bottom half and pull on the top, you have to reassemble it with the new dogs replaced(there are four in a package) Fairly simple, no special tools needed,
good luck.
Posted on May 27, 2010
blueextc3221
  • 15935 Answers
SOURCE: whirlpool washing machine model wfw9500tw01
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
How do I fix my whirlpool duet washer that is showing a F20 code . We recently installed a new water softener, could there be residue or something from the old that is causing this?
F20 Control relay for motor controller faulty This fault code is only displayed on washing machines that have a CIM, BPM or Direct Drive motor fitted and an external motor control unit is used.
The main electronic control unit has failed to detect the relay that switches the motor control unit on and off has operated correctly. This relay is fitted on the main electronic controller and it is highly unlikely that there is an issue with the electronic board that controls the drive motor.
  • Check wiring and all connectors between the motor and main electronic control units
  • Replace main electronic control unit
Jul 20, 2016 | Whirlpool Washing Machines
On Whirlpool duet steam front loading DRYER...What does the error code F70 mean?Do you have to have a certified whirlpool appliance service professional to repair?
F70 code says...
Replace the machine control electronics. You should first unplug the machine and then remove and plug back in all connectors on the front panel model as well as the electronic control module.
If that doesn't take care of the problem then it may be time to consider replacing the rear board. The FSP # 8183259
The control board is part # 14 in the link below.
Sears parts direct /Whirlpool-Parts/Model-WFW9400VE01
Mar 13, 2015 | Whirlpool Washing Machines
Off balance cabrio!
Check your 4 struts, you only had to re-fix your load when it became unbalanced. Better still check on 'youtube' with brand model for solutions. There are possibilities for re-selling the board. Hope this helps......
Apr 30, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool du1048 won't do anything; has power & door switch ok. I changed the fuse, the electric cord and the electronic control board. I live in Argentina and in my house I have 110 V and 50
1) the frequency had many decision in the fault. You must use some transformer for to connect to the machine and adjust the frequency equal to the machine.
2) however you have another option to exchange the motor by frequency.
3) will be a good idea to call your supplier factory and get the support via ONLINE via chat or phone for return parts and NOT paid nothing for this inconvenience.
God bless you
Sep 26, 2012 | Washing Machines
Why do i get F1 notice and machine stops working
Whirlpool uses the F1 code for some of their front load washers when there is a problem with the electronic control board (the brain of the washer). You can try unplugging the washer for 30+ minutes.
However, it's likely that you need a new control board. (If the washer is still under warranty, contact Whirlpool.) Otherwise find the model number of the washer (usually inside the door). Then use the model number to find a replacement. The last time I checked the part is ~$175.
I hope this helps. Please add a comment with the model number of the washer for specific information.
May 15, 2012 | Whirlpool Washing Machines
I need an owners manual for my wacher whirpool cabrio agi WTW 6200 SWO
Have you tried WWW.whirlpool.com , at the bottom of the home page for whirlpool is a section labeled Owner Center, in that section is an area labeled Manuals and literature. Try there.
Dec 31, 2011 | Whirlpool Washing Machines
Dishwashing machine whirlpool electronic control ADP 4520
Check the Water Indicator (WI).
When you think it should be enough water, unplug WI connector from control board and check if on WI connector is closed contact (WI written on the control board housing). If not, try with some more water. And so on. When too much water with no contact on WI, it is the one to be replaced by new one.
NOTE: by every check UNPLUG the machine
Jan 03, 2010 | Electrolux Dishwashers
Feb 21, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool washer stops during cycle
Do a visual inspection on the electronic module. To do you need to removed it. Follow the manual for this. I got the manual from, it's pretty big, about 44MB: https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/07e2c9ebdcf04a3085256f38004f9b84/$FILE/WPWASHER1.pdf
I had the same kind of issue on mine, no spinning and occasionally it did not want to start. I decided to remove "electronic control module" and do quick visual inspection on the board.
I find out that the board was full of little (microscopic) lead (plumb). I cleaned it with a toothbrush and ALCOHOL on both side, re-installed it and since then the machine worked find... Finally after a year I have a working machine.
I think you should test this solution before spending $400 on a new "electronic control module".
Let others know if it work on your side too.
Aug 07, 2008 | Whirlpool LHW0050PQ Front Load Washer
Washer machine drains while filling
If the pump is actually coming on at all times, then I imagine this machine has a completely electronic control system ? - i.e. No mechanical timer ? - If this is the case, then the switch that controls the pump is an electronic solid-state device, or, more rarely, a relay on the board. Looks like you'll need a new power board.
Sep 15, 2007 | Washing Machines
Washing Machines Logo
117 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
