Question about Samson MDR624 Mixer
<!-- from fixya rte -->No sound to my headphones with Samson mdr624 - Samson MDR624 Mixer
  • Samson Master
  • 3,368 Answers
First be sue the headphones are good. The C/ROOM + PHONES control is used to set the level sent to the control room outputs, and also to the head-phone jack.
Posted on Nov 27, 2014
How to unmute a samson meteor microphone
Just press in the switch in the middle of the dial for the headphone levels on the mic.
https://www.youtube.com/watch?v=byun8WG2y1U
Jul 06, 2014 | Samson Meteor Microphone
The left tweeter from my Mediaone 5a monitors is not working
Have your tried switching the speakers to make sure the lack of high frequencies travel with the speaker?
Mar 08, 2014 | Samson Mediaone 5a Active Monitors
Can a Samson g track mic be used with the new iPad?
Yes, but the iPad doesn't supply enough power for the G Track to run headphones, so you will need to use a powered hub between the mic and the iPad.
Jun 26, 2012 | Samson G-TRACK USB RECORDING MICROPHONE...
Getting distorted sound when connecting from mac pc headphone jack to 1/4" line in input
You are connecting a NOISY unbalnced line to a balanced input. Buy a DI box and then use an XLR to XLR to the mixer inout and run the MAC into the DI with "ground lifted". You will need to make a resistive mixer between the headphone jack and the DI as well. The headphone jack is STEREO. You COULD try a STEREO 1/8 inch splitter to 1/4 inch left and right cable... you MIGHT get away with that. Right now the left and right amps in the MAC are fighting eachother.
Sep 25, 2011 | Samson New Samson Mdr-1064 10 Channel...
I can only hear one side of my headphone with the Samson S-Amp! wheni pull the headphone cable out i can hear on both ears. what kind of connection do i need to listen in stereo?
Are you using a STEREO input cable? Is the source of the audio stereo? The stereo cable will have three connections on the plug... the sleeve, the ring and the tip.
If you only have mono source or using a mono cable you will only get sound in the left headset. Pulling the plug part way out will sometimes contact both connection so you will hear both.
If your source is mon, you will need a special cable that connects the mono signal to both sides of the input plug, that is the ring AND the tip.
Mar 29, 2011 | Samson Samp Headphone Amplifier
What are some of the common reasons that my Samson S-amp headphone amplifier isn't working?
Most common reason probably would be incorrect or failed power adapter. It appears the unit requires a 18 VAC (not DC) adapter. Dead batteries if that is the power source would be the other cause to suspect.
Feb 28, 2011 | Samson Samp Headphone Amplifier
How do you open earpiece for troubleshooting no sound from right side and something rattling around
What you do is peel back the cusion of the ear pad. You might need to tear off the foam covering. You can glue it back on when your done with Bostick white glue. With the coverings gone you should see access screws.
Jan 30, 2011 | Samson CH700 Professional Headphones
Samson 3o1u has a delay in my headphones
The delay is due to the time it takes to digitize the audio and pass the data through your computer to the audio board.
Depending on your system and software, you MAY have a setting for ECHO which loops the sidetone directely to your headphones so the delay isn't present/
Sep 14, 2010 | Samson C01U Consumer Microphone
My speakers are both working fine, but I am only getting sound from my left headphone
Ok..,then try the headphones on another system to see if the problem is a loose wire or the driver on the right side. of those headphones.. If the problem is in the headphone amp section of whatever you are using{hi fi amp/mixer or computer interface],it could be a simple dry solder joint[which anyone with basic electronic and soldering skill can attempt]  Try a different pair of headphones on that system or the above and find out who is to blame first...Hope this helps ...
Mar 15, 2010 | Samson G-TRACK USB RECORDING MICROPHONE...
Samson Stereo Headphones RH100 - no more sound
first u have to check the wire from pc to headphone whether any wire is damaged ,next u check whether the volume in the headphone is mute, and then check the pc volume whether it is in mute .rate as u like
Oct 16, 2008 | Samson RH100 Headphones
Samson MDR624 Mixer Logo
406 people viewed this question
Top Samson Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Jerry Umali
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
