I have a pair of Mackie S225 speakers. They were working fine. I moved the stereo from my garage to the shop and hooked them up and now they are both muffled. I hooked them up to another crossover and the problem is still there. Is it possible that the HF amp went in both at the same time? Any suggestions?
  • 3,320 Answers
Check the impedance of the wires at the point they enter the speakers 4 ohms.
is the polarity the same on both speaker connections?
Posted on Nov 20, 2014
Benimur
  • 6966 Answers
SOURCE: karaoke speaker,no woofer or midrange working, only tweeter
Hi, it's probably that the 8" woofer and the midrange of the "amped" enclosure is open. One way to test is to remove just one wire from the inside of the enclosure to the woofer or midrange in question and with the use of a continuity tester (or a VOM), check for the resistance of the coil of each the 2 speakers. Both should read anywhere from 4-8 ohms, if there's no reading (VOM needle will not move) then the coil(s) are open. In the absence of a tester, a single AAA or AA battery would do (pls. some would argue that this is not a sound practice, however this should be enough for you to be able to determine the condition of the coil(s)). With the use of the battery and a single short length of electrical wire, apply power from the battery to the terminals of the speaker, if the cone moves, then chances are it is good, if they don't then you would have to replace it. Am not sure if available in your area, but there are some trained people who can rewind the coil should a replacement speaker be not readily available. Hope this be of help. Please let us know how things turn up. Regards.
Posted on Apr 15, 2007
SOURCE: bypassing the 150 watt blown amp with passive crossover
3/4 update: i bypassed the 300w amp on my first ovtr3 with a cs3006 crossover i purchased on ebay. the input wires at the base of the speaker were connected to the input of the crossover, the bass output of the new crossover was connected to the yellow/yellow-black lf+/lf- wires that used to leave the old 300w amp. the high freq output of the new crossover was directly connected to the leads coming from the speaker's tweeter (running the midfreq outputs from the new crossover to the input of the speaker's old crossover is no good, since the midfreq output of the new crossover would rolloff and provide little high freq to the tweeter). The mid-freq output from the crossover was connected to the input of the old crossover that came with the speaker (alternatively, i could have wired the mid freq output from the new crossover directly to the midrange speakers, but i figured the old crossover might have had some characteristics that would have been helpful. the result is better than i hoped for! true, the bass is not quite as floor shaking as before (and you need an amp that can boost +5-+10db below 350Hz and rolloff the boost above 350Hz), but the end result is more than satisfying and gives these speakers new life. I am using a Sony receiver that puts out around 200W for the front speakers.
Posted on Mar 04, 2008
SOURCE: How to bi-amp wire a JBL EC35 speaker?
with help from a other site I bi-wired it using a bigger amp. It now gets 105w at 8ohm using a 18 octive slope filter set at 80hz.
Posted on Dec 12, 2008
  • 39 Answers
SOURCE: Suddenly, my outdoor speakers sound kind of "muffled"
If these speakers are two or three way speakers, it is possible that the tweeter(s) are blown in them.
Try and remove cover to check.
If the sound is not distorting, but just flat and muddy its the tweeters.
Put the other ones on this channel, to make sure it is not the amp.
Posted on Jun 14, 2009
  • 4 Answers
SOURCE: fried electronics in KLH ASW10-120B subwoofer
It is a 4 ohm nominal impedance woofer. If you put a new woofer in, it will last maybe half an hour and then fry/melt. The problem is the amp, not the woofer. Throw the amp out and use the box as a passive sub. Get a 100 hz sub crossover.
Posted on Sep 01, 2009
My Mackie HD1531 has a high pitched whistling sound, all other speakers work fine with the same power connection and desk connection. It whistles regardless of whether it has a sound input or not.
Sounds like a problem with the horn amp in that cabinet. This is not a user fixable problem and needs to go to the shop. Here is a link to the Mackie support page where you can find a link to the repair shop list.
Mackie Tech Support
Feb 19, 2015 | Mackie HD1531 3-Way 15" HD Powered PA...
Hi im sorry if this sounds a little dumb!!! last weekend while i was on a gig i tried to hook up my lap top to my mackie mixer (cfx12) but i wasnt able to get winamp to play through it, which channels...
With a stereo splitter cable that takes the stereo 1/8 plug of the computer into two RCA plugs you could go into the "Tape Input" of the mixer... OR take a 1/8 stereo splitter cable from the PC splitting to a pair of 1/4 inch plugs go into one of the 4 stereo input pairs on the mixer... like 7 and 8 or 9 and 10 for example.
Dec 22, 2010 | Mackie 1202vlz3 12 Channel Mixer
Need to find out which is the proper speaker wires for hook up yellow to tweeter or sub? And striped one is positive or negative?
You can probably trace which colors go to the smaller of the amps... Yellow is often used for tweeter but there really is no standard. Striped wire is probably the minus lead. If a pair is heavier, that would be the pair for the woofer... and red is often positive for woofer and black the minus. Searching the Mackie schematics doesn't really show colors. You could call their service dept.
Dec 14, 2010 | Mackie Th15a Power Speaker Pair 15 Two Way...
Im trying to hook up two sets of passive speaker, one pair is connected to a QSC amp and the other pair is connected to a Kenwood amp. Is this possible without using another mixer like a mackie 1402.
you should be fine, you can get splitters, little adapters to split the input cables into 2, so that you can use one ouytput to run 2 channels. just hook up the output cables to the output on the numark, and use the splitter adapter to split the sound between the 2 amps.
Oct 05, 2010 | Numark CD Mix2
Hi I have a mackie sr series 24.4.2.b bus miximg console in for repair,most of it is working except that the right channel output is misssing on on sub outputs 1 and 5 and 3 and 7,i do not think its...
Remember that the subs are each MONO outputs. They do not have stereo outs. They can be used as pairs like 1-2 for stereo and those should PAN with the pan control at each channel assigned to a sub.
For mono's, the left channel is the one used.
Refer to the signal flow diagram for the Mackie mixers to analyze this. It probably is on page 28 of your manual.
For the subs, you can pan AT THE CHANNELS ASSIGNED between for instance sub1 and sub2. Note these work together as odds and evens.
Jul 14, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
I want to hook up a an interface to a mackie mixer. What is the common denoinator to hook up, let's say a digi 002 and a mackie mixer so i can have a mac computer with pro tools operational with also the...
you can just piggyback the mixers - take the outputs from the mackie mixer (assuming it is NOT a powered mixer) ... those should be line level outputs - send them into a line level input on the digi 002 and then set that channel on the digi 002 and once set, just leave it, and control the mackie channels individually ... should work fine ...
For audio expertise and PA system help with feedback and noise, try our new DVD "PA Systems for Small Groups" at www.rexark.com
Oct 14, 2009 | Digi 002 Rack FireWire-based Pro Tools LE...
Hooking up sound system
The RSQ player goes into the input section of the mixer.
The mixer effect send goes to the Quadraverb input and the output of the Quadraverb goes back to the effect in on the mixer. Now the Main out on the mixer goes to the EQ then the EQ goes to the compressor/limitor to power amp to speakers.
Apr 02, 2009 | Stanton Sa3 DJ Mixer With Eq System
No sound from M-audio BX5a monitor
I have a pair of BX5a monitors hooked up to a video editing suite. One of the monitors is off. They are powered to a working electrical supply. They are driven off a Mackie DFX-6 with a 1/4" unbalanced connection. No blue light on the monitor, no sound or hissing on that...
Jan 31, 2009 | M-Audio BX5a Speaker
I have a pair of mackie srm 450 and one swa 1501 the bass output in one of the 450s has no sound. i hear sound only from the high frequency part of the speaker
you have one of two problems.1) the woofer is blown(most likely) or 2) the crossover is fried(rare). Take the woofer out and press on the speaker cone(softly). If there is a scratchy feeling when you move it or if it doesn't move at all, you'll either need a new woofer, or get that one reconed.
good luck.
Dec 04, 2008 | Mackie SWA1501 Subwoofer
Aftermarket 6 x 9's
What type of car is it? You can purchase speaker harnesses at any car audio shop that will allow you to snap into the factory plugs. Also, beware if your system was designed for 8 ohm speakers - using 4ohm speakers instead could cause some problems. Most aftermarket stereos are designed for 4ohm speakers, but some factory stereos designed for 8ohms could be damaged if you give them a smaller ohm load.
Sep 15, 2007 | Car Audio & Video
55 people viewed this question
 Grubhead
Grubhead
