Question about PfaFF Sewing Machines
I have pfaff 2046 and the bobbin case will not face upwards. it is tilted to right side a little
I off the machine and still the bobbin case will not face up. before this happened there was some noise and the thread cut off.
  • 86 Answers
Have you got your bobbin case and the area around it cleaned? This sort of thing often happens because there is a bit of lint stuck in the bobbin mechanism. Also, oil it! All sewing machines need a bit of a lube, even the new computer driven ones.
Posted on Nov 25, 2014
1mrchris
  • 15 Answers
SOURCE: Anna had this problem with her Pfaff 332 sewing machine, I do too
I believe that the bobbin case holder has become unlatched, for lack of better terminology. I have one of these machines, and my first experience with one was exactly as you are describing. A friends grandmother brought it to me because it kept breaking needles and wouldn't complete a stitch.Put the bed table in the lowered position, leaving the free arm exposed. Remove your needle, presser foot, and bobbin case, leaving the bobbin door open. Next remove the two screws that hold in the feed plate, and remove the feed plate. Looking down into the bobbin area, manually turn the bobbin case holder. There is a small slot in the top of the bobbin case holder, look for it as you turn. A small latch protruding from the bed plate is supposed to be clipped into that slot, and if the latch is still there, you likely will not be able to rotate the holder into place: This is good news, it means nothing is broken. Loosen the three screws (two silver on the top of the bed plate and one black in the area where the feed plate goes) which hold the bed plate in place, but do not remove them. You should be able to lift the bed enough to get the holder into place, and then set the bed back down and tighten the screws. Reassemble everything, throw in a new needle and see how it goes!
Posted on Mar 24, 2009
Mimito7
  • 128 Answers
SOURCE: Tension Problem on Pfaff 2034, bobbin loops
Rule of thumb.. Loops on the bottom, problem on the top. Loops on the top, problems on the bottom.
Set your upper tension at 4, and rethread the machine from the top. Just before you thread the needle, but the presser foot down. If the thread pulls right thru easily, then the thread is not thru the tension wheel right. Because, if you can't pull the thread thru with the presser foot down, you have it threaded right.
Posted on Apr 25, 2009
Mongo32
  • 111 Answers
SOURCE: Sewing machine will not pick up bobbin thread.
needle's in backwards
Posted on Jun 11, 2009
  • 192 Answers
SOURCE: Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Posted on Feb 16, 2010
  • 300 Answers
SOURCE: My machine will not thread any bobbins.
Your bobbin winder has seized. Remove the top cover and oil the area where the bobbin winder shaft goes through the bobbin winder assembly. You might need to force the winder to turn with your fingers for a while, but it will begin to turn smoothly once the oil gets in there.
If the black bobbin winder tire has a flat spot worn into it, you will need a new bobbin winder tire. Costs around a dollar.
Posted on Apr 08, 2010
Needle hitting bobbin casing on Pfaff Quilt Expression 2046
If you have installed a brand new needle and it is still hitting, then the machine needs an adjustment. Take it for service.
Apr 01, 2017 | PfaFF Sewing Machines
Bobbin case inserting wrong
hi, Can i ask what model Pfaff it is ?
Regards
Rob
www.electronicrepairs.co
Dec 29, 2013 | PfaFF Sewing Machines
I have a Pfaff Quilt Expressions 2046. The bobbin casing is turning and not staying still. I can rotate and get it to snap up at the top but it will not stay in that position. I have cleaned and oiled,...
I suggest that the sewing machine be checked to see if there
is something wrong with the hook & hook race or if the bobbin
casing needs to be replaced
Oct 08, 2012 | Sewing Machines
How to remove and fill bobbin
Locate the bobbin access panel to the right of the presser foot. Place thumb tip in the oval hole and pull to the left, (It might also tip up, but I doubt it.) Reach in and lift and grasp the little lever on the bobbin case, pull it out. Remove bobbin from case. Select the thread you want to fill the bobbin with. Place it on the thread spindle. Pull thread trough the small round tension disc on top of the machine and back toward the short spindle on the right top of the machine. If your bobbins have holes.. thread a hole and place the botton on that short spindle. Slide the bobbin and spindle toward the metal "fence". Loosen the hand wheel by turning the center knob counter clock wise. Grasp the little thread on the bobbin and start winding a few revolutions with you holding the thread. Stop and clip that short thread close to the bobbin then continue winding until full.
When the bobbin is full. Return the hand wheel knob to it's original position. Slide the bobbin winder spindle away from the "fence" and remove the bobbin. Place the bobbin in the case with the bobbin facing you... the thread when pulled should rotate the bobbin itself clockwise (VERY Important!) Hold the lever open and replace the bobbin.
For your convenience I have located this PDF for your machine. (be patient, it takes a while to load)
http://s2.vsmgroup.com/VSM/Pfaff/pfaffmanual.nsf/1fd5659e6f37141041256697003e64c0/38ca989591640b1a852575f30058c8ff/$FILE/Pfaff%20260%20.PDF
Aug 09, 2012 | PfaFF Sewing Machines
Pfaff 260 bobbin thread not picking up
Hi. This can be terribly frustrating, but the most likely cause for the bobbin thread not catching is that the needle is inserted wrong. There is a flat side on the shank of every needle and that has to be facing a specific way on your machine or the needle's grooves can't make the stitch. On most modern machines, it's my experience that the flat side goes to the rear, facing away from the operator, but some of my older machines need the flat side facing to the left or to the right.
Another thing that can cause the bobbin thread not to pick up is a bent needle, but in my experience it's usually the needle not in correctly.
(Cost me $85.00 to find this out!)
Let me know if this works, ok?
Happy Sewing!
Robbie
Apr 01, 2010 | PfaFF Sewing Machines
I have a Pfaff 2046. When I press down on the
Probably the belt tension needs adjusting, it is slipping like a car fanbelt and needs the same relative "give" when correctly tightened.
Remove the side cover where the handwheel is and loosen the motor fixing to adjust and increase the tension on the belt ....needs some slack, if you can move the belt 10mm with light pressure then it will be fine NOT TOO TIGHT or you will overload the motor. NOTE: If the side panel is not easily removed, ie 2 piece casing split in the middle, take it to a service centre or risk breaking the casing trying to get in....if it is more than a few years since last service, let someone do it all and get a sweet machine back, with no risk for not a whole lot of time or money
Aug 27, 2009 | Sewing Machines
An old Pfaff machine has been donated to my project but I cant work out how to insert the needle.
If the machine bobbin area opens at the front then the flat side of the needle needs to be facing the back. If the machine opens at the side then the flat side faces into the machine to the right. There should be a little screw to the side of the needlebar to keep the needle in.
Jun 17, 2009 | PfaFF Sewing Machines
Apr 24, 2009 | PfaFF Tiptronic 2030
Sewing Machines Logo
128 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
