Question about GE Kitchen Ranges
How do I remove the cooktop from a GE Profile Dual Fuel J2S968SHSS? I need to replace the Spark Module. Where is that located? I already replaced the wiring harness but cannot get the cooktop to re
See above
    Prodigy:
    An expert who has answered 500 questions.
  • GE Expert
  • 650 Answers
Check in the control panel. GE sometimes puts the spark module up in the control panel. I would look there first. Sometimes they put it in the side panel.
Posted on Nov 22, 2014
SOURCE: Help in Removing Frigidaire Smooth Cooktop Burner
What holds the spring assembly onto the bar assembly is just two small prongs. Use a pliers on the end that protrudes through the bar, squeezing the prongs together, and it should come out fairly easily.
Posted on Mar 02, 2008
IFIXALL
  • 868 Answers
SOURCE: Replacing Glass Cooktop on GE JPB82
1st....You have to pull out the cook top first.2nd...remove the 1/4 inch screws that hold the top down(they are mounted on the side os cook top ) ,you dont remove the lowest ones.remove the burners from the top and your there :) Please Rate This !
Posted on Jun 07, 2008
  • 4 Answers
SOURCE: I have a GE profile
To remove the top on this range, remove burner knobs and face plate, then remove 2 screws from control panel one at each end. Fold panel down out of the way, remove 5 screws accross front of control panel and release 2 quick connect plugs for burners, then lift to remove glass top. Flip over remove 2 screws and clips from each burner and the indicator light assembly just pops out. Transfer this to new top and reverse your steps for removal.
Posted on Mar 28, 2009
  • 105 Answers
SOURCE: I have GE Profile glass cooktop. After cleaning
you can safely use a razor scraper such as you would use to scrape paint. It will not harm the surface and then you can polish it with the cleaner.
Posted on Apr 07, 2009
SOURCE: I need to replace the bake element on my GE
You can access from the frontbut you have to be careful when you unplug the wires. If there is tension on the wires , they slip behind the back panel..
If the wires go through the slot then you have to remove back cover.
I just learned this 08/25/09
Posted on Aug 25, 2009
The igniter on my GE cooktop wont stop clicking, only if i unplug it.
Spark module part no 318 at parts diagram it may be wet and by using a hair dryer or leave it unplug for some days can dry out and stop. If not then the electric contacts are stuck and need a new spark module
Aug 27, 2011 | GE Profile JGP636 Gas Cooktop
Piezo igniter won't quit
Possible stuck burner switch or failed spark module. Unplug unit. Remove wires from burner switches at module and plug back in. If it starts sparking, replace module. If it stops, then replace switch harness.
Jan 18, 2011 | GE 30 in. Profile JGP932 Gas Cooktop
When I try to use my gas cooktop, it makes a loud "pop" sound and has a big electrical spark that smells like fireworks then it flips the breaker.. Any ideas??
The electrical wiring under the burners has been short
probably from liquids leaks during cooking.
That is why you had the spark. The only electrical part you
have to your coo top is the electric ignite nothing else. So you should remove
all burners' assemblies from the top so to reach the bottom part where the gas
pipes are located and the ignite part no 318 in drawing Spark module
Part Number:
AP3778816made by GE.
So first you can use a hair
dryer do try it out and be sure there is not and liquid in it and put
electrical plug again to test it. If you still have the same problem, replace
the Spark module with a new one.
Here below you will find the
parts layout of your range for all the help you might need.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5235927&diagram_id=25698825#d25698825
Dec 13, 2010 | GE 30 in.Profile JGP945 Gas Cooktop
Where is the spark module for the GE Monogram Gas Cooktop Model ZGU375NSD1SS located? All 5 burners work, but there is a constant click, click, clicking that sounds while they are in use... :( So I already...
Hello, refer to the next web page: partselect.com/. then select the part blow out for cooktop box components, I believe item number 28 is what you're looking for. Hope this helped.
Jun 28, 2010 | Cooktops
GE profile gas cooktop - sparker firing with knobs turned off?
replace your spark module
have you spilled liquid on the cooktop recently?
if yes let it dry for a couple of days and see what happens.
sometimes when you spill liquid on the cooktop it grounds out the spark module and it will continue to spark until it drys.
let me know if you need more help
Feb 15, 2010 | Cooktops
Have a four burner gas GE Profile cooktop. How do
The igniter module is working fine. One of the switches (which are on each valve shaft) is stuck or shorted out. Pull a wire off each one at a time to determine which one is bad. Careful! 120 volts to each wire. Also, this can happen after you spill water into the valve area, if that sounds right, let it dry out.
Jan 29, 2010 | GE 30 in. JGP328 Gas Cooktop
GE Profile nat gas cooktop, Model No JGP636BEV3BB won't ignite
If you can hear the clicking sound but are not getting a spark then there is probably a short in the ignition system. Check for any loose wires on the ignition system. Make sure all the wires are properly seated. Make sure the spark module is properly grounded. As far as testing the spark module it should be generating a spark of course. The problem is that the average voltage for the spark module is 15,000 VDC so actual testing of that voltage can be difficult. Is the spark erratic?(should spark evenly). An erratic spark timing is a sign of a bad spark module. Is the spark slow? Check the polarity of the electrical plug. If it is clicking evenly then it is probably arcing somewhere inside the cooktop and you just need to find out where. Also be aware that if you get water into the cooktop that can cause possible grounding of the spark module or ignition system.
Jan 18, 2010 | GE Profile JGP636 Gas Cooktop
GE Cooktop burner doesn't click or light.
Remove all the burner heads and lift the top. Sometimes easier said than done. How do you know it is the module? It could be a cracked insulator on the ignitor. To verify you can swap two of the connections on the module and if it lights then it is the module.
eric
Jun 20, 2009 | GE 30 in. JGP328 Gas Cooktop
Kitchen Ranges Logo
87 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
