How can I start when Default boot device missing
    Sergeant:
  • 320 Answers
If you are getting default boot device missing it may be due to failing hard drive or misconfigured boot options.
First check boot options.
If you are on a dell computer boot options may be reached by pressing the F12 key during the computers boot up.
If this is a non-dell computer it may show another key during the initial power on should say something like F12 to enter setup "F12 being a different key"
Other keys to try may include F2, ESC, F10, F11, some systems you may have to hold down "Shift + F11"
Once in the Setup screen you should see "Boot" or "Boot Options" at the top, use the Arrow keys to navigate to "Boot"
Make sure first boot device is set to cd/dvd
Second boot device should be hard drive
If this is correct press ESC and close without saving (options will be listed on the screen when you press Escape)
Generally this error is caused by hard drive failure, or a disk left in the drive (floppy, cd / dvd, or usb flash drive plugged in during boot)
You may need to seek physical help if you think the hard drive is at fault. You want to get the data recovered form your drive as soon as possible and refrain from any attempts to use the hard drive as this will lead to further damage.
Posted on Nov 20, 2014
    New Friend:
  • 22 Answers
Good day Ken Markham
If your "Default Boot Device" is your hard drive and it is missing, then your machine will not start, you may need to have a technical person look on your machine for you.
Missing Boot INI File when starting a Dual Boot Machine , Win 7 64 bit and Win 10 64 Bit
Windows 10 is the default and will be looking for a EFI file that is probably not set up on your old hdd. Change the format of the old hdd to accommodate the new type of boot file.
Sep 29, 2015 | Computers & Internet
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
My packard bell is saying that default boot device is missing or failed, insert recovery media and hit any key
If you are using an operating system with a start disk, insert the start disk and reboot. You will then have to recover the software installation.
If you have your OS CD, you can start the computer using it, and then repair the software installation from it.
Mar 18, 2015 | Packard Bell Computers & Internet
My boot devices are disabled
Hi
Normally for Pcs and laptops the booting devices can be found in the CMOS/BIOS settings, when you start up the pc/laptop you normally press esc f1 f2 etc, this allows the user to enter into the CMOS/BIOS setting.
Under the Boot tab you will see all the devices you boot from they will be enable/on or disabled/off check them to see which devices are on and off.
The last tab has a load default option if you select it and exit and save these changes it will automatically enable all the default devices in order.
Your pc/laptop should boot up normally now
Cheers
Apr 16, 2014 | E-Machines eMachines Desktop PC
Getting the following error on boot up right after the ibm splash screen: ERROR Resource conflict - PCI Serial Bus Controller in slot 7 Bus:15, Device::00, Function:01
If it is not making it to Windows at all...Generally occurs when two devices are using the same IRQ or memory allocation. This can sometimes be set in BIOS depending on the manufacturer etc. I would start by going in BIOS and restoring the default settings. There should be a menu item in BIOS usually something like "Restore Default".
If it is making it to windows then you probably just have a missing or corrupt driver. Generally this would fall under a chipset driver which can be downloaded for free from hp's site. You can also download and run Everest or SIW to properly id the device in question.
Comment back with for findings results or for more assistance.
Aug 24, 2011 | HP OmniBook XE3 Notebook
No sound at all
1) Go to: Start > Settings > Control Panel > Sounds, Speech, and Audio Devices > Audio tab 2) Check what's under "Sound playback: Default device" and "Sound recording: Default device". It these fields are grey and non-clickable, then most probably the audio card driver is missing or less probably the audio card itself is broken. 3A) If you have an original CD of your computer, motherboard, or audio card, insert the CD and install the driver from it. 3B) Or alternatively insert the CD and go to: Start > Settings > Control Panel > Performance and Maintenance > System > Hardware > Device Manager, find any unidentified device in the list, or expand the "Sound, video and game controllers" branch, identify the Audio card > Right click > Update driver... > Install the software automatically > Next 3C) Or alternatively download and install a free driver updater software, e.g. http://www.innovative-sol.com/drivermax/index.htm - let it scan and update all your missing drivers. P.S. These steps mentioned above are for Windows XP, but will be quite similar on other Windows versions, too.
If you tell me your laptop's model name, I could find its website where you can download audio drivers. For example if you have HP laptop, go to www.hp.com and enter your laptop's model number and look for driver downloads offered.
Mar 07, 2011 | Computers & Internet
Missing NTLDR message, cd does not start ,have no floppy, this is a 503gr. F8 does display but does not continue to selected item, get black screen. Does a processor cause this failure?? Have original...
Your CD is not starting as it is not configured for first boot device. I am not sure on which function should be used to get to Boot Menu however you may want to try using either F2 or F12. Then its all about changing the Boot device fromHard Drive to CD. Once Changed follow the steps mentioned below,
  • Insert the Windows XP CD-ROM into the CD drive, and then restart the computer.
  • Click to select any options that are required to start the computer from the CD drive if you are prompted.
  • When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  • Press 1 (One) to select windows XP and then hit enter.
  • When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
  • At the command prompt, start typing
COPY D:\i386\ntldr C:\ (Considering that D is your CD Rom Drive)
COPY D:\i386\ntdetect C:\ (a file that may also be missing)
Then rebuild the boot configuration boot.ini file by
Attrib -H -R -S C:\boot.ini (if not found skip the next line)
DEL C:\boot.ini
BootCfg /Rebuild
Once all these steps are completed make to change the boot device to hard drive from CD rom.
Jan 07, 2011 | Gateway 503GR PC Desktop
''BOOTMGR is missing'' I can't boot from Windows XP CD
Open cpu cabinet and Refix RAM some times bootable files not load on ram properly so this error comes.
So refix RAM memory clean dust from circuit and RAM .
Also pull cmos cell from motherbord for 5 minutes so all settings are defaults then check.
Aug 01, 2009 | Computers & Internet
Computers & Internet Logo
99 people viewed this question
David Payne
David Payne
